Graphics Cards & their possibly noisy fans
Postby Darclinc » Wed May 23, 2012 3:30 pm
Hey Guys,
Slightly OTT in terms of just audio related, but I've got a potential problem with my DAW.
I run a 64-bit Windows 7, Core i7 3.0gHz with 24Gb RAM. While it's a great machine for audio I also use it to run Adobe software, After Effects, Premiere, Photoshop, etc., for work purposes.
Having upgraded to Adobe CS6 recently, some of the new functions, i.e. ray traced 3D extrusions for example, really require a proper GPU 3D graphics card like a Quadro of Nvidia GTX card to work properly at all. It's unusable at present. They are probably very noisy though, considering the dual fan designs and increased heat generation.
Are they going to be too noisy for audio work ?
So my question is this, if I get a card like this, is it going to effectively run in "idle mode" when running my sound apps, i.e., will I still be able to record / mix in a relatively quiet environment or is this GFX card going to undo all my hard work in terms of sourcing suitably quiet components, case fans, fanless GFX card, fanless CPU heatsync, insulated case, etc. ?
Moving the PC is not an option unfortunately.
Any advice in terms of CUDA GFX cards, noise levels or replacing uber GFX card stock fans would be greatly appreciated. I don't know much about this stuff at all.
Thanks,
D.
Darclinc
Re: Graphics Cards & their possibly noisy fans
Postby Agharta » Wed May 23, 2012 5:45 pm
There are ways to use 150W GPUs in desktop PCs in relative silence under load and silence at idle and I recommend this website as probably the definitive reference source: http://www.silentpcreview.com/
Generally you want to use the latest GPUs (nVidia GTX 670/680; code name Kepler) as they are more power efficient (so easier to cool quietly) but there are debates on the Adobe forums as to how good these newer GPUs are for non gaming purposes such as CS6:
http://forums.adobe.com/community/premiere/hardware_forum
Agharta
Postby zenguitar » Wed May 23, 2012 7:18 pm
can't help with the card but....
Happy Birthday Darclinc
OC/DC - All the right notes in exactly the right places.
Postby Martin Walker » Thu May 24, 2012 2:34 pm
Damn- I missed it, so a belated Happy Brithday to Darclinc! 8-) :bouncy:
Postby Darclinc » Thu May 24, 2012 7:27 pm
Thanks ..
Turns out I share a birthday with Bob Moog.
Cool, right ?
D.
Darclinc
Postby Richard Graham » Fri May 25, 2012 3:01 am
I bought a Gigabyte GTX 560 SOC, it has heat pipes and two very large and quiet fans. The power consumption when idling (I.e. when using audio rather than 3d apps) is lower than other cards in the same price range, and the thermals a kept correspondingly low. It is not completely silent but it is a quiet as a proper gaming card with fans could possibly be. The fan speed auto-adjusts downwards when not working hard, and unless the rest of your system is completely passively cooled, I doubt you'd notice the cards fans. It's a fairly big card but it fit in my midi style ATX case quite comfortably, tho it does take up one additional slot. It will run 2 dvi monitors and has hdmi too, if that sort of thing is useful to you. Check it out! :)
http://www.maximumpc.com/article/reviews/gigabyte_gtx_560_super_overclock_review
http://www.ebuyer.com/279089-gigabyte-gtx-560-super-overclock-1gb-gddr5-dual-dvi-mini-hdmi-pci-e-gv-n56gso-1gi?utm_source=google&utm_medium=products
Note: You will need a decent PSU with two 6 pin power connectors, but this is standard crack with this class of video card.
Richard Graham
Postby Richard Graham » Fri May 25, 2012 6:13 am
I can confirm that the Gigabyte 560 SOC is silent when idling. Just tested it. There's no decrease in noise when I stop both of its fans.
Richard Graham
Postby Darclinc » Sun May 27, 2012 1:05 pm
Hey Richard,
Thanks for the post, it is really appreciated.
As it turns out, luckily, one of my work colleagues recently purchased a GTX 560, so I was able to go test it out as his house. Works great with After Effects, and not too noisy at all.
That being said, he has several case fans going, so it's quite hard to hear exactly.
Anyway, I guess I'll be ordering one ...
Thanks,
D.
Darclinc
Postby Richard Graham » Sun May 27, 2012 8:13 pm
Darclinc wrote:Hey Richard,
Thanks,
D.
Glad I could help. If its silent you're after, the Gigabyte GTX 560 SOC (or another Gigabyte 560 with the same "WINDFORCE" cooler and fan arrangement) is the one to go for. I can't vouch for other brands or versions of the 560: the fans and heatsinks can vary enormously on the same chipset, depending on who makes it.
Check out my second link above, I think Ebuyer are doing the exact same model I bought for less than £150.
Richard Graham
