Editing 8 tracks of drums in Cubase?
Postby lovesexy » Wed Jul 25, 2012 1:50 pm
Hi All
I have to edit 8 tracks of drums on 6 songs. Generally there are 4-6 takes. I'm using Cubase 5 and would like to know the easiest way to edit the tracks.
Obviously I'm using the 'lines fixed ' option for the kick, snare, hi hat, overheads etc but it will take forever to solo each take. Any ideas?
Any help would be greatly appreciated.
lovesexy
Re: Editing 8 tracks of drums in Cubase?
Postby Exalted Wombat » Wed Jul 25, 2012 2:35 pm
Well, unless the drummer was VERY accurate and consistent (in which case, why did you need 6 takes?) you'll be choosing between the various multi-mic recordings of each take, not picking snare from take 1, overheads from take 2...etc. I'd make a Folder Track for each take, each containing the 8 tracks of that take. I think Cubase 5 had Folder Tracks?
Exalted Wombat
Postby The Elf » Wed Jul 25, 2012 3:36 pm
And if you at all want to keep editing multi-mic kits simple I'd STRONGLY recommend considering an upgrade to C6.
Firstly, you'll get multi-track phase-aligned audio quantising.
Secondly, you can edit multi-track takes in 'lanes'.
Thirdly, the '=' button synchronises all editing within a folder track to each track it contains.
Essentially you can work with a multi-track group of drum mic's as if they were a single audio track. It's worth the price of admission alone.
Postby Mixedup » Fri Jul 27, 2012 3:26 pm
The Elf wrote:And if you at all want to keep editing multi-mic kits simple I'd STRONGLY recommend considering an upgrade to C6.
+1
You can drag and drop takes onto different lanes in C5, but its a PITA and easy to make bad-sounding mistakes. C6.5 makes things much, much easier.
Mixedup
Postby ef37a » Sat Jul 28, 2012 4:37 am
Cheapskate alarm here!
If you can get the job done inside a month you could download the demo of Cubase 6. You need a dongle but even if you had to buy another one, still a good deal!
A couple of years ago I had 50 sides of punk 45s to clean up and pulled the same stroke with Sony Soundforge. I reckon I have "paid them back" by my reccomending the software at every opportunity since on forums!
Postby C.LYDE » Tue Jul 31, 2012 11:24 am
+2...
C.LYDE
