Recording live from my ipad into Adobe Audition
Postby Frog » Mon Dec 24, 2012 11:06 am
Hi All
I have Propeller-head Figure on my Ipad and would like to record some of the stuff i am doing into adobe audition on my laptop. Please could you give me some ideas on the best way to do it with minimal background noise as I have tried going from headphone socket on the ipad to mic socket on the laptop with a jack to jack but there is quite a bit of hiss.
Any ideas?
Sean
Frog
Re: Recording live from my ipad into Adobe Audition
Postby Exalted Wombat » Mon Dec 24, 2012 11:21 am
Frog wrote:Hi All
Any ideas?
Sean
It seems that Figure can export an audio file. Doubtless, being Apple, it will want to put it in your iTunes library. Get it to your laptop that way.
Exalted Wombat
Postby Frog » Mon Dec 24, 2012 12:10 pm
Yes it does but its only a couple of bars worth, I was trying to play along live with some other audio files I have already in my DAW.
Frog
Postby Exalted Wombat » Mon Dec 24, 2012 8:59 pm
OK. Well, you're probably stuck with the headphone output of the iPad. You could add an audio interface with a proper Line In - which will like the iPad output much more - to the laptop. Worth it, if you take music production at all seriously.
Exalted Wombat
Postby ef37a » Tue Dec 25, 2012 1:04 am
What you need is the Behringer UCA 202, about £25 and an RCA/PHONO to 1/8" stereo jack lead.
I have had 2 202's and they both had a noise floor of better than -80dBFS, better than an iThingy I bet?
You can also hook it up to a hi fi amp and dub tape or vinyl. Add a properly buffered pedal and a usb stick with Reaper on it and you can jam guitar into any PC you find.
Postby Frog » Tue Dec 25, 2012 8:42 am
Many thanks Dave
Merry Christmas all
Frog
Postby Frog » Tue Dec 25, 2012 4:05 pm
Well would you believe it, I opened a Christmas parcel from my dad this morning and inside was said beheringer 202!! In fact he bought me the one with the extra phono pre amp as well so I can transfer some of my vinyl as well if I want to......
Frog
Postby ef37a » Tue Dec 25, 2012 4:40 pm
Frog wrote:Well would you believe it, I opened a Christmas parcel from my dad this morning and inside was said beheringer 202!! In fact he bought me the one with the extra phono pre amp as well so I can transfer some of my vinyl as well if I want to......
Reeeesult! Well done Dad! Some might sneer at the humble 202 but for the price I think they are great. FAR better than most On Board Sound systems and being line in, far more flexible. They ARE only 16bits and don't quite make even best use of that but as I say, neg 80 (we would have killed for a neg 75 tape recorder!) and you must watch that the top end never gets closer than -6dBFS. But that is plenty of dynamic range for tape and vinyl duping and electric guitar.
You might also consider a simple DIY addition. Stereo pot in a tin? All can be revealed post festivities.
Postby Frog » Fri Dec 28, 2012 3:04 pm
Sorted :-) Used the 202 with a ipad to phone cable bought from amazon. Tried with the std USB driver to start with but Adobe wanted an asio driver otherwise the signal was very high. Used beheringer asio driver and now adobe lets me select the ipad and I can record direct in the daw.
Many thanks for your help. Sean
Frog
