Windows 8 £25 download upgrade questions
Postby Jez Corbett » Thu Jan 24, 2013 12:38 pm
Wonder if anyone can help with my current concerns!
1. Can the £25 download upgrade be used as part of a totally fresh install from a newly upgraded PC?
2. To use the upgrade I have to have W7 installed already, right? Just my Windows 7 install is also an upgrade so to install that I first have to install XP - except my XP disc is quite old and doesn't support SATA. Any way I'm actually going to be able to install this from a fresh install?
3. I have a dual-boot set up - is this download going to allow me to install it onto two boot drives, or will I have to buy it twice?
Thanks!
Jez Corbett
Re: Windows 8 £25 download upgrade questions
Postby feline1 » Thu Jan 24, 2013 1:49 pm
you have to run the setup.exe installer from within an eligable operating system... simplest thing if you wanna do a clean install is install a new copy of WinXP onto your hard drive, use MS Update to bring that up to Service Pack 3, then upgrade to Win8 from within that.
(You can select the "don't keep anything" option when you do the it, so it just shoves the whole WinXP gubbins into a folder, which you can then delete cleanly using the Windows Disk Clean Up tool)
Are you sure your WinXP won't install onto a SATA drive? You should be able to insert a floppy or USB with the SATA drivers during the install if you really need to.
feline1
~~~ A weasel hath not such a deal of spleen as you are tossed with! http://www.feline1.co.uk ~~~
Postby Jez Corbett » Thu Jan 24, 2013 2:04 pm
Ah, that's good to know I can upgrade from XP (you are sure about that, right?), that'll certainly save me hassle.
(although I just remembered my XP is also an upgrade version so needs a Windows 2000 inserted during install - which I'm not sure I have any more! Ahh fun times)
Definitely not - it's an original release XP disc that was pre SATA - I've been caught out by this before. *floppy drive?!?* People still have them? Not sure how to do it by USB though - the xp set up demands a floppy inserted - can modern bios' trick the installer into thinking a USB stick is a floppy drive?
Or wasn't there some thing that came with XP SP3 that allowed you to make a new install disc for a new XP SP3 install?
Jez Corbett
Postby DGL. » Thu Jan 24, 2013 2:07 pm
To install windows XP on a SATA HDD you either need a copy of the SATA drivers on a floppy disc (no other medium will work) or to slipstream the drivers on a new windows disc using something like nLite which by using the original windows disc and the motherboards' SATA drivers creates a new windows disc with the drivers included (you can also add service packs so as to have a sp3 already on the disc).
http://www.nliteos.com/nlite.html
You should not need the win 7 upgrade disc to install the update as you will be able to perform the update form windows XP.
DGL.
Postby feline1 » Thu Jan 24, 2013 2:11 pm
Jez (mahoobley) wrote:Ah, that's good to know I can upgrade from XP (you are sure about that, right?)
Yes, I have personally done it! It's officially supported. The only "gotcha" is that you need to be at Service Pack 3 before you can run the Win8 upgrade, but Windows Update no longer works unless you are at Service Pack 3 lol So you have to manually find the service packs on the MS download site and install them that way.
Oh fer flippsakes! :)
feline1
Postby Jez Corbett » Thu Jan 24, 2013 2:16 pm
Which is why I'm weighing up whether saving the hassle is worth the 4x price for the non-upgrade standalone installer disc. I'm actually considering it.
Jez Corbett
Postby Jez Corbett » Thu Jan 24, 2013 2:18 pm
DGL. wrote:To install windows XP on a SATA HDD you either need a copy of the SATA drivers on a floppy disc (no other medium will work) or to slipstream the drivers on a new windows disc using something like nLite which by using the original windows disc and the motherboards' SATA drivers creates a new windows disc with the drivers included (you can also add service packs so as to have a sp3 already on the disc).
But to get there I'll have to go back to XP somehow, right?
Ugh.
Theoretical question - would I technically be doing anything illegal, considering I have a valid license for XP, to just download err an image of a more recent XP installer disc of err 'alternative' origin and go from there? Am I allowed to even raise such an idea on this forum?
Jez Corbett
Postby Scramble » Thu Jan 24, 2013 2:30 pm
Microsoft say that you aren't allowed the upgrade deal if you want to continue to run the old OS on another partition. So, as long as you no longer run an XP partition you would seem to be staying within the spirit of things. (Don't see why you can't still run a W7 partition if you don't upgrade from that).
Scramble
Postby feline1 » Thu Jan 24, 2013 2:43 pm
As an aside - do you really need a dual boot if you run Windows 8?
It has a good VM environment (MS HyperV) or you can use Oracle Virtual box if you need a VM with support for soundcards & USB
feline1
Postby Billum » Thu Jan 24, 2013 3:52 pm
I'm a little confused as to what you now actually need to install, but if you're installing Windows 7 as an update from XP, you don't have to install XP first. You just install Windows 7, and at some point during the installation it will ask you to put the XP CD into the drive to verify you owned it already.
But it sounds like you can do the Win 8 upgrade from XP anyway!
(I'm looking into getting the cheap Win 8 upgrade, and then grabbing the free Win 7 Pro *downgrade*, to bring my laptop up from XP to Win 7 Pro for £25!) :blush:
Billum
Postby Scramble » Thu Jan 24, 2013 3:59 pm
I'm pretty sure they don't let you do this.
Scramble
Postby feline1 » Thu Jan 24, 2013 4:00 pm
Billum wrote:I'm a little confused as to what you now actually need to install, but if you're installing Windows 7 as an update from XP, you don't have to install XP first. You just install Windows 7, and at some point during the installation it will ask you to put the XP CD into the drive to verify you owned it already.
Ah! Good call, Billum!
Because this is the crucial difference with the Win8 upgrade: you can't just install it on a blank drive then present your old installer DVD mid-install as proof of purchase - you gotta physically run the Win 8 setup from inside the old OS.
But it sounds like in this case, the original poster can install Win7 on a clean drive, slip it the XP CD mid-install, then run the Win8 upgrade from Win7 - problem solved?
feline1
Postby Scramble » Thu Jan 24, 2013 4:15 pm
In theory it looks like he can do this. But the upgrade is supposed to remove the license for that W7, so he won't be able to run that W7 on another partition, as it looks like he wants to do. (Perhaps in practice he can, don't know, but he says he wants to be 'legal').
So if he wants to keep his W7 partition and comply with Microsoft then he needs to upgrade from XP. (I haven't come across anyone saying you can't upgrade to W8 from XP if you've already previously upgraded that XP to W7, but for all I know it is in the fine print somewhere).
Scramble
Postby Billum » Thu Jan 24, 2013 4:30 pm
Scramble wrote:>I'm looking into getting the cheap Win 8 upgrade, and then grabbing the free Win 7 Pro *downgrade*, to bring my laptop up from XP to Win 7 Pro for £25!
Hmm, I think it's still a bit ambiguous, but you might be right, it could just be for OEM versions of Windows 8:
http://www.microsoft.com/oem/en/licensi ... ights.aspx
Billum
Postby Scramble » Thu Jan 24, 2013 4:39 pm
I can't find info on this on Microsoft's site, but lots of forums are reporting something like what is on this page:
"Downgrade rights are only available on computers that come with Windows 8 Pro. Upgrade copies of Windows 8 Pro don’t include downgrade rights, so you can’t purchase the Windows 8 Pro Pack to get downgrade rights."
Scramble
Postby Jez Corbett » Thu Jan 24, 2013 6:31 pm
To clarify on some points of contention:
1. My Windows 7 upgrade disc DEFINITELY requires me to have Windows XP installed first. It does NOT allow me to install on a blank drive, verifying the old disc during installation.
2. I want to have two installations of Windows 8 on the same machine - can I definitely do that with the £25 upgrade? The purchase is just a setup.exe type app, right, that I can just run from what will be two fresh XP installs?
Jez Corbett
Postby Jez Corbett » Thu Jan 24, 2013 6:36 pm
Errrr .... hmmm. From Microsoft's website:
Upgrade to a 64-Bit Windows 8
If you want to upgrade a PC with a 32-Bit Windows operating system to a 64-Bit Windows 8, it’s necessary to do a clean install. The license we offer here qualifies for a clean install. But please note: we strongly recommend that you backup all of your data before, because you’ll lose all data and applications during this process.
A Windows 8 clean install demands a previous installed and activated version of Windows XP (SP3), Windows Vista or Windows 7. You’ll need the DVD for clean install. Please choose “ship it” above as delivery option.
MS website seems to be suggesting I can't do what I want to do with the £25 download.
Jez Corbett
Postby mhaigh » Thu Jan 24, 2013 8:35 pm
on a separate but related issue (sorry Jez) thinking about going from Vista to 8 on my laptop (non-music) - 5 year old Vaio with T6400 and 3gb - which will run 8 fine, it's in its pensionable years and will need a new one in 12 months or so (right now, off-charge battery life is about 60 mins)...is it worth the hassle to do this? as much as i hate Vista, and am hoping for quicker boot times, more responsive overall...worth it or not for £25?
mhaigh
Postby BraddersUK » Thu Jan 24, 2013 8:40 pm
I can confirm that you can do a clean install of Windows 8 from the £25 upgrade download.
It sounds silly but you install Windows 8, it will let you but you can't activate it. Then you UPGRADE Windows 8 to Windows 8 over the top!! Then you can activate it because you have "upgraded". Sounds crazy but I and many others have done it!
I installed it on Boot Camp on a Mac.
BraddersUK
iMac 27" 2012/13, 3.4Ghz i7, 3TB Fusion, GTX680MX 2GB. Dynaudio DBM50, Liquid Channel, Apogee Duet.
Postby Scramble » Thu Jan 24, 2013 8:46 pm
Do you have to prove at some stage in this process that you have XP/Vista/Windows 7?
Scramble
Postby BraddersUK » Thu Jan 24, 2013 8:53 pm
No, as I don't have XP/Vista/Windows 7! :)
BraddersUK
Postby Jez Corbett » Thu Jan 24, 2013 9:06 pm
BraddersUK wrote:I can confirm that you can do a clean install of Windows 8 from the £25 upgrade download.
Ah that's great to know, thanks! I also realised I could potentially install Windows 7 as 64bit and get round the restriction but this way sounds better!
Could you also possibly confirm if it's ok to do two installations on the same PC (i.e. dual boot setup) with this £25 license?
Jez Corbett
Postby BraddersUK » Thu Jan 24, 2013 9:10 pm
ooh, no idea I'm afraid.
I've been trying to find the website where I first read about it but I can't. I hope it still works!! Just warning you incase it was a loop-hole they've since plugged.
BraddersUK
Postby Jez Corbett » Thu Jan 24, 2013 9:13 pm
It shouldn't be against the terms of the license I expect, just concerned it might not be workable.
Jez Corbett
Postby Pete Kaine » Fri Jan 25, 2013 10:19 am
One licence is one install as far as the terms state, so no your not as far as the licence agreement is concerned allowed to do two installs using one key.
Pete Kaine
ScanProAudio - Studio Kit
Scan 3XS Audio Workstations
