New Monitor Query?
New Monitor Query?
Postby TheBev » Sat Feb 09, 2013 11:44 am
Hi -
I am wanting to upgrade my 17" monitor to the Dell Ultrasharp U2412M but have one niggling query. As well as PC duties I'd want to hook it up to a Panasonic freeview recorder as I've been without TV for 3 years or so. Can't say I've missed it but as the football season hots up I'd like to be able to watch Spurs glorious march to the top of the league.
Well... that's what I'd like.. ;)
Anyway, as the monitor doesn't have a suitable connector would a convertor cable do the trick from the freeview box to the monitor. Eg; a HDMI to DVI convertor cable, just don't want to make some silly mistake.
Oh - & just noticed now that they come in either LED or LCD flavours, is it an either / or situation or is one of them inherently a better choice?
Many thanks if you can help, & apologies for yet another monitor Q.
TheBev
"The tech gets better, the user error remains the same.." Roberts Plant
Re: New Monitor Query?
Postby mick.n » Sat Feb 09, 2013 3:22 pm
Not sure of the answer to your main question, but i bought one of THESE a few months ago. I bought it mainly to fill up a space in the spare bedroom ( Shh, don't tell osborne :protest:)
The picture quality is stunning & i have been promising myself for a while to try it as a pc monitor.
Oh, and you can use a USB stick to record programs. When my existing pc monitor finally dies i think i will be looking at something like this. ;)
mick.n
Postby mooblie » Sat Feb 09, 2013 6:54 pm
TheBev wrote:..... a HDMI to DVI convertor cable......
Careful: that MIGHT be OK, but two things occur:
- the monitor is 1920x1200, the HDMI output will probably be sending 1920x1080 - so that screen might distort your image (too tall) or maybe not even sync at all. It is unlikely to (correctly) letter-box it with black bars. You might be better off buying a native 1920x1080 monitor - lots of THOSE around,
and
- don't forget about audio - the monitor won't take the audio from HDMI. Maybe your Freeview box has analogue audio out of some phonos (or SCART, even) that you can deal with separately?
mooblie
Martin at HeadSpin
Postby TheBev » Sat Feb 09, 2013 11:17 pm
Thanks guys.. looks like it's back to the drawing board then, pity as it seemed a good solution / great monitor.
mooblie - I'd have had the audio covered, by, as you say, phono outs from the freeview box into a DAC & onto some monitors. I've not yet bought anything so words of warning about resolution much appreciated.
mick.n - I think I had a mental block on the Freeview TV / USB record option as it's primary function is.. as a TV. Or.. I could kid myself I still didn't own one. :beamup: Looks like I need to revisit that scenario. I think I was also put off by not being able to get full HD in the 24 inch-ish range. Now I (re)think it I can't remember why it seemed important, probably something I misunderstood somewhere along the way.
Anyway.. horrible mistake averted by the sounds of it, & Spurs are gonna mess up anyway.. so it's all good.
TheBev
Postby chris... » Sun Feb 10, 2013 11:53 am
Why not get a 1920x1080 monitor, around 24", as moobile suggests ?
chris...
Postby TheBev » Sun Feb 10, 2013 1:21 pm
Hi - Chris,
yeah I'll re-look into all choices again I guess. The Dell UltraSharp U2312HM, a 23 inch monitor is 1920x1080 I believe, & 50 quid cheaper, so it seems it may be a good alternative. I like the fact these monitors can tilt for my endless re-reading of manuals & the like as well. Again no HDMI on it but if the convertor cables play nicely not really an issue.
TBH I hadn't even considered the resolution to be a potential problem, so it's caught me on the hop somewhat. All I can see on the freeview box specs are 1080/24p Playback - which I guess is the standard & hopefully compatible with the above, still not sure though.
Anyway - thanks again mooblie for pointing that out.
Back to looking at specs etc - anymore comments about potential pitfalls gratefully received. :)
TheBev
Postby Skerrick » Mon Feb 11, 2013 6:29 am
LED definitely gives better clarity, colour, brightness and i imagine it would save massive amounts of power based on the general applications and properties of a regular LED bulb..
Skerrick
Postby Ojustaboo » Mon Feb 11, 2013 9:04 am
Most LED monitors use PWM to control the brightness. This means that to have it on anything but 100% brightness (which is way too bright), the brightness is dimmed by the LEDs being turned off and on very very quick.
Most people have no problems with it but if you suffer from eye strain or headaches, these can be unbearable. I found out about this after I bought an Asus PB278Q that had a superb pic but gave me constant eyestrain and headaches. Googling LED monitors and eyestrain/headaches, turns out it wasn't only me.
I returned it for the Dell U2713HM
I have had zero eyestrain or headaches since.
If you look at the panel and backlighting part of these reviews you can see the effect of PWM and no PWM. They have pics showing the effect.
http://www.tftcentral.co.uk/reviews/asus_pb278q.htm
http://www.tftcentral.co.uk/reviews/dell_u2713hm.htm
There's also an article about PWM on the same site
http://www.tftcentral.co.uk/articles/pulse_width_modulation....
Ojustaboo
Postby TheBev » Mon Feb 11, 2013 8:01 pm
Thanks for jumping in guys..
Ojustaboo - sorry to hear about your issues & glad you found a workable solution. I've never had a problem with my monitor tbh but tis an LCD. I guess it'll be suck it & see time if I decide to buy the Dell 23", there only seems to be an LED version of that monitor.
Thanks for the heads up though.
TheBev
