M-Audio Audiophile 2496 PCI, £37 delivered at Maplins
Postby Agharta » Sat Mar 30, 2013 6:06 pm
There used to be a forum for deals but no longer so I’ll post it here.
Use this code for an extra £3 off which brings it down to £37 with free postage:
AWINDIS7
http://www.maplin.co.uk/audiophile-2496 ... i-o-224756
Agharta
Re: M-Audio Audiophile 2496 PCI, £37 delivered at Maplins
Postby Agharta » Sat Mar 30, 2013 9:47 pm
Try this instead - Link
Agharta
Postby ef37a » Sat Mar 30, 2013 10:27 pm
Thanks A!
I have reserved one and will pick it up Monday.
The sad part of all this is that this seems the death knell of M-Audio PCI production. I would bet there will be no Win 8 support for the cards. Some of you might recall I tried to buy an AP192 in UK with no joy. This card will give me a chance to try 4 in 4 out sync'ed. I know some have said it does not work that well but I shall give it a shot! If it works it will be most useful to swop tracks to and from my Teac A3440.
Postby ef37a » Sun Mar 31, 2013 12:34 pm
"Don't buy unless you have older motherboards. PCI on newer motherboards is a kludge: PCIe is implemented in hardware, but PCI only emulated from the PCIe bus." (from another place)
Is that ^ a bother? I can see it might be for an old gazillion track RME card but 2 annie's plus SPID plus MIDI and 96k top whack?
Postby Goddard » Sun Mar 31, 2013 2:50 pm
It seems to depend upon the particular motherboard and interface card.
The "bridged" PCI on recent motherboards using Intel socket 1155 (Sandy and Ivy Bridge) chipsets lacking "native" PCI support has been problematic for many PCI interface cards. In some cases a card just won't work, in other cases a card works but with degraded performance, and in a few cases a card works just fine.
Intel do still offer some current SB/IB desktop chipsets with native PCI (B65/75, Q67/77) though.
Goddard
Postby Pete Kaine » Tue Apr 02, 2013 1:55 pm
ef37a wrote:"Don't buy unless you have older motherboards. PCI on newer motherboards is a kludge: PCIe is implemented in hardware, but PCI only emulated from the PCIe bus." (from another place)
I always found M-audio to be the biggest arris in these regards. If you have one in the currently that works however then a second shouldn't be a big deal. Also most win7 drivers work perfectly fine in win8 so the might be more legs in this than you think.
(not an promise that it'll work, but worth a punt if you need the options)
Pete Kaine
Postby ef37a » Tue Apr 02, 2013 2:13 pm
Thanks Pete,
Can I prevail further upon your good nature?
I intend to install the card and use two of them for 4 in 4 out sync'ed but I am not sure what will happen on boot up(do I/will it run drivers again?) or what the control panel will do/look like?
If there is a link to any information about this I should be most grateful.
Postby Moroccomoose » Tue Apr 02, 2013 2:35 pm
I run 2 Delta 1010s (Breakout box versions) in Win 8 with the Win7 drivers with out too much hassle, I do get the occasional Win8 blue screen crash but I'm not doing anything too serious with them, so doesn't worry me too much.
Crashes occur if the buffer is too small or when I change the buffer size (typically down to improve latency) from the delta control panel and Cubase is running. It is normally fine, but if it does crash, that is when it seems to happen. (Setting the 'release drivers when Cubase window not active' option helps)
BTW I'm running Cubase 4AI - so there could be a bit of 32 bit/ 64bit incompatibility going on too. Hoping to get Cubase Artist 7 shortly which may bring with it better Win 8 stability.
Moroccomoose
Postby Martin Walker » Wed Apr 03, 2013 7:23 pm
ef37a wrote:Thanks Pete,
Hi Dave,
As long as the 2496 has multi-client drivers then you'll simply need to connect the S/PDIF output of the first to the S/PDIF input of the second, run the first as Master (internal clock) and the second as Slave (external clock) and you should be fine 8-)
Most muti-client drivers that I remember tend to provide drop-down menus so you can choose which card you're currently controlling in the Control Panel.
Postby Pete Kaine » Thu Apr 04, 2013 8:47 am
Thanks Martin, its been a while since I've had my hands on a pair of Deltas but I recall that once the second one is inserted it should just enumerate itself with the drivers already installed for the first one althrough worst case senario would be it asking for the driver setup to be run through again. Either way it should be fairly stright forward and I do recall multicard assignments being accessable via the standard M-Audio control panel so the shouldn't be anything major in the process to cause any issues.
Pete Kaine
Postby Goddard » Thu Apr 04, 2013 10:37 am
Is syncing multiple M-Audio cards even still possible (except perhaps 2 cards connected via S/PDIF)? Iirc, they mungled that capability in their Windows drivers along the way (along with the wordclock i/o on the 1010?). Used to be that you could install up to 4 cards, but dunno about now.
Of course, used to be that they bundled Logic for Windows with M-Audio cards, so... ;)
Goddard
Postby Pete Kaine » Thu Apr 04, 2013 2:20 pm
lol... errr. Good question. Last time I did it with two cards was possibly on XP and I can recall setting up a 4 card rig for someone once with no issues.
You Win 7 comment through could be well deserved. I recall seeing the function was still in there but I don't recall ever trying it out on that platform.
I think I'm going to close this thread with "YMMV" and leave it there ;)
Pete Kaine
Postby ef37a » Thu Apr 04, 2013 3:11 pm
Thanks Pete et al.
I am running XP Home on the relavent PC so all should be cool!
I hope to rig it at the weekend but want to build a breakout box first.
Will report back.
Postby ef37a » Sun Apr 07, 2013 9:46 pm
Well they are in and running...Sort of!
I had to run the install disk and uninstall everything since the driver install stopped asking for a "Delta sys" file which apparently was not in the original drivers that had been working this 4 years!
Reboot and then the drivers run twice. Played a song in Sam se8 (my default, always bloody works, DAW) and I had replay on delta 1/2 and on delta 1/2, 2, on different channels of my monitoring mixer. So far. So cool. But, I only have one control panel. I cannot set sample rates, bit depths, S/PDIF routing, latency or jack else on one of the cards and at the mo' I can't tell which card the visible control panel refers to!
"Properties" reports one card in PCI slot 9 (PCI bus 2, device 5,function 0) The other: PCI slot 10 (PCI bus 2, device 6, function 0) Is that all ok please?
Postby ef37a » Mon Apr 08, 2013 5:45 am
ef37a wrote:Well they are in and running...Sort of!
Doh! There is a box marked hash AP1, AP2 etc! I have linked the cards via SPDIF but find card 2 gives me only right channel and sounds weird, sort of out of phase. More investigation tonight!
Postby Martin Walker » Mon Apr 08, 2013 4:47 pm
Oh dear Dave - I should have posted this screenshot for you that I made for my SOS review of the Audiophile 2496 in 2001 :bouncy:
There you are - the #1 to #4 AP where you choose which to control of the four possible AudioPhile cards you may have installed is on the right hand side :smirk:
Postby ef37a » Mon Apr 08, 2013 5:39 pm
Thanks Martin,
Yeah, as you see the Old Fool got there in the end!
Y'know? I have had two cards now for about 4 yrs in two computers and I am STILL not all that sure what all that panel means! THEN! They go and change it!
