is it worth waiting for Haswell to upgrade?
Postby Wheelie » Tue Apr 30, 2013 12:55 pm
I'm needing to upgrade my 4 year old DAW computer.....
Do you think its worth waiting for the new intel processors to come out? Haswell and the new socket LGA 1150... I'm not completely up on the new technology and if it would be significantly faster, or does the 22nm chip architecture already available mean that there wouldn't be much difference?
I know to upgrade or not is usually answered with, if you need it now then buy it now, but I'm in the middle of a couple of projects and am looking towards upgrading in downtime in about a months time, so just asking the question as I don't fully know what current setup speeds are like and if the difference between Haswell and what is currently available is small....
Martin has a paragraph or 2 occasionally in SOS PC notes about upgrading, but I haven't noticed any info of late....
Wheelie
Re: is it worth waiting for Haswell to upgrade?
Postby Scramble » Tue Apr 30, 2013 1:15 pm
Haswell was expected to be anywhere between 5-15% faster. Some preliminary reports suggest it's very much faster in regard to audio, but we don't know for sure yet, and there are heat issues that need to be sorted out.
See here
Intel has now announced that Haswell will be officially unveiled on June 3. I don't know if that's also the date they become available for sale. The quad-cores should be available first up.
If you can wait 2-4 months then I would wait, but even then there's a small risk that early boards with Haswell will have unexpected issues as happened with Sandybridge.
Peter Kaine and the other system builders on this forum might be able to tell us more now that Intel has announced Haswell's unveiling date, but it depends on what their non-disclosure agreements lets them say.
Scramble
Postby Wheelie » Wed May 01, 2013 12:32 pm
thank you for your reply scramble, this was exactly the sort of info i was looking for....
Wheelie
Postby Agharta » Wed May 01, 2013 4:52 pm
I’d wait until June 4th and see if they are officially benchmarked then and also to see when the actual availability will be.
If you don’t upgrade very often it’s generally worth waiting a month or so for the new platform.
The main downside of buying into a new platform around launch time are these:
The motherboards BIOS’s can be a bit flaky although the odds are slim that you will actually have a serious problem.
The same goes for drivers but less so.
The choice of motherboards is relatively small and the prices are high. CPUs prices at launch tend to be fairly similar to the outgoing platform.
There is a bug in the chipset for the new platform but it’s not serious enough to delay the launch although a new revision will arrive soon. It affects certain USB 3.0 storage device when the system resumes from sleep if you had certain file types located on such a drive in use when entering sleep. It’s a very minor bug.
Agharta
Postby Goddard » Wed May 01, 2013 9:44 pm
Agharta wrote:There is a bug in the chipset for the new platform but it’s not serious enough to delay the launch although a new revision will arrive soon. It affects certain USB 3.0 storage device when the system resumes from sleep if you had certain file types located on such a drive in use when entering sleep. It’s a very minor bug.
Let's just be clear here. Any "bug" on account of which Intel undertakes a revision of its silicon is clearly not considered by Intel as "a very minor bug".
For reference, Intel's Sandy Bridge chipsets ("Cougar Point" PCH) as initially launched had flawed SATA2 controllers, and although it was still possible to avail of the chipsets' remaining 2 SATA3 ports Intel revised its silicon, yadda yadda, B3 stepping, replaced motherboards, a billion or so bucks later...
Which is not to say that there weren't still bugs affecting SATA ports (and PCIe and USB interfaces) in Intel's revised Sandy Bridge processors and chipsets and in their newer Ivy Bridge counterparts, as anyone may see from looking through the "errata" detailed in Intel's technical product specification updates.
At this stage, all that is publicly known about the Lynx Point PCH (Haswell chipset) USB3 bug is from an Intel notice apparently sent out to its manufacturer customers:
http://qdms.intel.com/dm/d.aspx/C79FC2E6-6B75-4063-8687-660F...
For anyone contemplating to use USB3 devices with a new Haswell system, it might be prudent to ensure that the system offers USB3 ports controlled by an add-on (non-PCH) PCIe USB3 controller chip, although those won't likely be found on any laptops, only on some higher end desktop motherboards.
Goddard
Postby Agharta » Thu May 02, 2013 6:01 pm
Goddard wrote:Let's just be clear here. Any "bug" on account of which Intel undertakes a revision of its silicon is clearly not considered by Intel as "a very minor bug".
I never suggested that Intel considered it a very minor bug as that is just my take on it. The context for me is that for a bug that requires a new chip revision that this is very minor. No stability issues, no performance issues and the workaround in practice is simple and quick. If it was significant Intel would have delayed the launch. Let’s not argue over semantics.
Agharta
