Yamaha/Cubase Mismatch
Postby Dynamic Mike » Sat Jul 13, 2013 12:56 am
I've just suffered a long miserable day of installing & uninstalling software and drivers. Any advice & guidance would be much appreciated.
I'm currently using Cubase 6.5 on Windows 7 and having watched Yamaha's 'total DAW integration' claims for the MX series synths ordered an MX61. I dutifully detached everything USB, installed the latest Yamaha/Steinberg driver & the MX Remote Editor software. Initially it seemed to be successful so I re-attached everything and then the problems started. Device manager now claimed I had insufficient bandwidth (I assume USB) once I'd reconnected my Novation Nio interface. Cubase ran fine but it wouldn't see the MX61 anymore. Disconnecting the interface allowed the Yamaha/Steinberg driver to install, but then the second set of problems appeared.
Most notes play fine & I can record midi & audio output simultaneously via USB. But some keys do odd things, like opening media bay, adding an instrument track or changing the program on the MX61 whilst I'm playing. It's close to working, but essentially renders it useless. My old Evolution controller never did anything unpredictable. I've toggled everything on and off in Cubase & the synth and I'm out of ideas.
Also, even if I do get it running, how am I supposed to record any other audio? The only phantom power I've got is through the Nio. Surely I can't be expected to restart Windows & reset the drivers, inputs, outputs etc everytime I want to record something other than the synth? Have I made a schoolboy error here or am I just missing something obvious.
Dynamic Mike
Teeth will be provided
Re: Yamaha/Cubase Mismatch
Postby BJG145 » Sat Jul 13, 2013 7:22 am
Dynamic Mike wrote:Most notes play fine & I can record midi & audio output simultaneously via USB. But some keys do odd things, like opening media bay, adding an instrument track or changing the program on the MX61 whilst I'm playing.
Maybe as a first step you could try clearing out the Yamaha USB drivers, get the Nio working, and connect the Yamaha up to that via a standard MIDI lead? I don't know whether you'll get full "integration" this way though. Make sure everything's got the latest drivers and firmware.
I've not come across this bandwidth error and I'm not seeing anything helpful in Google...any more details on that one...?
Triggering unwanted actions with notes is a bit of a strange one...I'd probably use something like MidiOx to look at the MIDI data being sent by the keyboard to make sure nothing's amiss there, and make sure there are no old or unwanted control surfaces etc set up in Cubase. You might end up needing a clean reinstall, clearing out any old preferences folders, registry keys, etc.
Postby Dynamic Mike » Sat Jul 13, 2013 1:15 pm
I've switched USB sockets on the PC and now both drivers are loading happily together. I'd considered running standard midi thru the Nio & using the MX as a controller & multi-timbral sound module by connecting the audio outs to the line in on the Nio. I'm not that bothered about controlling Cubase from the synth buttons anyway. This is pretty much how I used to work with my Roland D5 & MMT8 many moons ago. Progress eh? The trouble is the Nio only has 2 inputs available, so I'd still be unable to record any other audio.
The synth comes with a free copy of Cubase AI6, so I'm also considering setting this up for the Yamaha drivers & Cubase 6.5 for the Nio & then exporting files between them. Would this be feasible? I'll download MidiOx as suggested & see if I can figure out how to use it.
Dynamic Mike
Postby Dynamic Mike » Tue Jul 16, 2013 10:59 pm
It appears you can only use the integration as advertised provided you don't require any other inputs. The MX61 is currently on it's way back to the shop. I now have a Piaggero NP31 connected by bog standard Windows 'come as you are' midi drivers in 5 minutes & £400 burning a hole in my pocket...
I could always try the free trial disc of Steinberg The Grand SE3 that came with Cubase 6 but £203 seems a bit steep.
Dynamic Mike
