Partition Magic
Partition Magic
Postby twotoedsloth » Wed Jul 31, 2013 5:38 pm
Greetings kind folk,
I stupidly installed my OS on the 1.5 terabyte partition of my 2 terabyte drive. Is there a current equivalent to the old Partition Magic that can resize the partitions for me?
Thanks,
Peter
twotoedsloth
Re: Partition Magic
Postby Scramble » Wed Jul 31, 2013 6:03 pm
Acronis Disk Director, or for a good freebie, Easeus.
Scramble
Re: Partition Magic
Postby twotoedsloth » Wed Jul 31, 2013 6:31 pm
Well, Easus looks like it will do what I need... but I'm kind of hesitant to use free software. Have you used it? This is likely a stupid reservation, as I use Fedora linux at home, and that's all free software.
Thanks for your response. I guess I'll take a ghost image of the drive in case anything goes awry.
twotoedsloth
Re: Partition Magic
Postby DGL. » Wed Jul 31, 2013 6:53 pm
twotoedsloth wrote:Well, Easus looks like it will do what I need... but I'm kind of hesitant to use free software. Have you used it? This is likely a stupid reservation, as I use Fedora linux at home, and that's all free software.
I've used this http://partitionlogic.org.uk/ free software before (it's live cd based on Linux) and worked perfectly.
DGL.
Re: Partition Magic
Postby zenguitar » Wed Jul 31, 2013 7:49 pm
I used Partition Magic in the past, but for the last few years I've been using GParted with the Live Distro on CD.
Re: Partition Magic
Postby Exalted Wombat » Wed Jul 31, 2013 8:26 pm
Maybe Disk Management in Windows will do it.
Exalted Wombat
Re: Partition Magic
Postby twotoedsloth » Wed Jul 31, 2013 8:39 pm
You might be right... One can shrink a volume, so maybe the leftover space from shrinking will let one expand to use up that space.
I'll do a ghost backup and give it a shot.
Thanks!
twotoedsloth
Re: Partition Magic
Postby Folderol » Wed Jul 31, 2013 9:23 pm
zenguitar wrote:I used Partition Magic in the past, but for the last few years I've been using GParted with the Live Distro on CD.
Another GParted user here. It's never let me down yet (dangerous thing to say, I know)
Re: Partition Magic
Postby Scramble » Wed Jul 31, 2013 9:48 pm
Yes, I have used Easeus, and it worked fine, although I mostly use Acronis Disk Director because I already had it and it's slightly better. But if I didn't have DD I wouldn't bother buying it now, I'd use one of the freebies.
I think maybe Windows Disk Management can do it, at least on W7, but it's a lot harder to use than the third-party software.
Scramble
Re: Partition Magic
Postby Trevor Johnson » Wed Jul 31, 2013 10:10 pm
EaseUS Partition master, home edition, is very similar to Partition Manager in look and operation and I have used it on a number of Windows PCs, over the years, without problem.
GParted is also very good (I use it on my Linux box), although it has a different look and feel to Partition Manager/EaseUs.
Always back up your data first on the disk whose partitions you are resizing. Also, with the PC powered off, physically unplugging the data cables (SATA or IDE) from any disks not involved in the process is sensible. Using different partition sizes is also an aid to being able to positively identify which disks you are either resizing or partitioning.
TJ
Trevor Johnson
Re: Partition Magic
Postby Exalted Wombat » Thu Aug 01, 2013 10:01 am
Scramble wrote:Yes, I have used Easeus, and it worked fine, although I mostly use Acronis Disk Director because I already had it and it's slightly better. But if I didn't have DD I wouldn't bother buying it now, I'd use one of the freebies.
Not a LOT. There's a limited range of functions, no way it can get THAT complicated.
Don't be frightened of free software. I trust Eset, Ccleaner, Malwarebytes a lot more than I do Norton, McAfee. LibreOffice does all that 90% of us use Office for, and doesn't try to suck us into a subscriprion-based licencing model. And then there's the whole Linux thing. Applications can be quirky, but sytstem utilities are generally excellent.
Exalted Wombat
Re: Partition Magic
Postby Kounoupi » Fri Aug 02, 2013 1:02 am
I use Mini Tool Partition Wizard - Home for cloning my C and data drives.
They call cloning "copy". Also good to manage partitions.
http://www.partitionwizard
Plus can get a bootable disk.
The home edition is free! :)
Kounoupi
Re: Partition Magic
Postby Martin Walker » Mon Aug 05, 2013 9:05 pm
Hi twotoedsloth!
Sorry, only just noticed this thread. I've been using the free Home Edition of EASEUS Partition Master since 2010 when I first discussed it in my PC Notes column, and haven't had any complaints yet:
www.soundonsound.com/sos/nov10/articles ... s-1110.htm
Re: Partition Magic
Postby John Reid » Mon Aug 05, 2013 9:43 pm
Wombat is right -- you can shrink/expand volumes in Windows 7 and 8 via Computer Management/Disk Management.
John Reid
Re: Partition Magic
Postby jasmine » Thu Sep 26, 2013 8:15 am
why there are so many people like to employ partition magic to do resize and similar tasks? i tried that program years ago, failed several tims to split my C drive. i know you some of you are posting advertisement.i use another assistant, read this you will know everything.http://www.extend-partition.com/free-pa ... nager.html
jasmine
Re: Partition Magic
Postby zenguitar » Thu Sep 26, 2013 11:29 am
No one is posting advertisements here jasmine, the SOS forum rules forbid advertising.
When someone uses software (or hardware) and finds it useful they are allowed to tell other forum members, which is what you are reading here.
Re: Partition Magic
Postby Pete Kaine » Thu Sep 26, 2013 11:42 am
Partion Magic has been industry standard since way before I care to remember, I assure you that if you failed to get it working, then it was user a problem specfic to your configuration and not a wider issue.
But yeah, that said these days I keep a gparted live disk on my keyring pendrive for situations that windows can't resolve natively.
Pete Kaine
ScanProAudio - Studio Kit
Scan 3XS Audio Workstations
