Yamaha 01v96i USB interface with PC
Postby evaluna001 » Fri Sep 27, 2013 4:59 pm
Hi,
I am planning on replacing my old original Yamaha 01v mixing desk with a shiny new 01v96i (I was originally planning on getting an older 01v96 plus a lightpipe card, but that plan appears to be dead in the water - details in another thread).
Is anyone here using one of these desks with a PC, specifically the USB interface that allows 16 track I/O? I am mainly interested in the quality of the drivers, as this mixer is intended to replace my current sound card as well as my current mixer, and will be used for recording and soft synths etc. Is the latency of the drivers low enough for this type of use? As far as the functionality of the desk goes, it looks really impressive, especially the ability to patch any input to any output, and the VCM effects look really nice as well, but none of that is going to console me much if the USB drivers are unusable for playing synths. I'd appreciate any input from users of this desk. Thanks.
Regards,
Terry
evaluna001
Re: Yamaha 01v96i USB interface with PC
Postby twotoedsloth » Fri Sep 27, 2013 5:29 pm
Hello,
I have an 01v96i, but I've not had much luck using the USB ASIO driver. I went back to using the ADAT I/O, as Windows would consistently lose communication with the mixer, I would have to unplug the USB cable and plug it back in again. Other than that, the mixer is great. I have the AES card installed, and like the ADAT interface, it works flawlessly.
I'm using Windows 7 enterprise, on an Ivy Bridge (quad) Core i7 with 32 gigs of RAM and an RME Multiface 2. This is notable because the Multiface 2 is using at PCI slot even though my motherboard (Intel) does not support 'native' PCI cards.
twotoedsloth
Postby evaluna001 » Fri Sep 27, 2013 6:34 pm
Hi twotoedsloth,
Thanks for the response - this is good info (even though it shoots my 01v96i plans down). The main reason I would choose the 01v96i over the older 01v96 plus a lightpipe card is to cut down on the hassle and to avoid the kind of connection bugs/issues you have been having with the USB link between your desk & PC. I am also using an Ivy Bridge motherboard (Asus P8Z77-V). What MB are you having these problems with? The fact that you are using an old RME PCI card with a newer Ivy Bridge MB is good news, as my other option (substantially cheaper) is an RME HDSP 9632 PCI card hooked up to the ADAT port of the original 01v96.
Regards,
Terry
evaluna001
Postby twotoedsloth » Fri Sep 27, 2013 6:47 pm
Terry,
I'm using an Asus P8Z68-V (LGA1155) motherboard with an Intel Core i7-3770 Ivy Bridge CPU at 3.4GHz.
Very stable, to the best of my recollection it has not crashed or even suffered a drop out since I switched from the Yamaha USB 2 interface on the O1V96i. It didn't crash with the Yamaha driver, either, it just got lost, which was fixable by unplugging/replugging the USB cable, albeit at the expense of your current take.
twotoedsloth
Postby evaluna001 » Fri Sep 27, 2013 7:17 pm
Hi twotoedsloth,
I'm using the same CPU, and it looks like the two motherboards are quite similar. How many I/Os are you using on your RME card? It's possible that the reports of PCI cards not working correctly on the newer bridged PCI boards are from people using a larger number of inputs & outputs. I only intend to use the 8 I/Os of the ADAT interface on the HDSP 9632.
Thanks for the info.
Regards,
Terry
evaluna001
Postby twotoedsloth » Fri Sep 27, 2013 8:06 pm
Terry,
I'm using the 8 ADAT outputs from my 01v96i, as well as the AES output (with an XLR to RCA cable) of my rough mix. This rough mix is sent to a backup recorder, really just another computer but just running the very basic Sound Forge Audio Studio software, and also to a CD burner for quick copies right after the session/concert. Additionally for no good reason at all I am running the last AES output to a Fostex DAT machine, because it's there... That leaves the SPDIF output free and clear, if someone wants to record without me having to repatch, and the stereo RCA and XLR analog outputs. As you can see, even without the USB connection, it is a really comprehensive and flexible mixer.
twotoedsloth
Postby dadking » Fri Sep 27, 2013 10:02 pm
i am using an 01v96i for recording purposes, my latentcy is around 10ms at 48/24 at 64 samples through Cubase 7.06 so not really impresive. This is on win7 on asus motherboard (not sure on model as not at music computer), I have an myat adat card fitted which is used with a ADA8000 gives me 8 more inputs. One thing I can say is that it is rock solid no problems with dropout at all. I dont use the effects in the 01v96i on recording as I am pretty sure this will just add to the latency.
regards
dadking
Postby Hugh Robjohns » Fri Sep 27, 2013 10:47 pm
dadking wrote:I dont use the effects in the 01v96i on recording as I am pretty sure this will just add to the latency.
No reason why they should. They were designed for real-time live applications, after all!
Postby evaluna001 » Sat Sep 28, 2013 7:37 pm
Hi dadking,
Are you using the USB connection for recording to Cubase? If so, have you experienced similar connection problems (losing the connection between desk & PC)?
evaluna001
Postby dadking » Sat Sep 28, 2013 10:49 pm
I do use the 01v96i for recording in cubase and the figure i quoted above is the best i can get 10ms at 48/24 using the lowest setting which is 64 samples.
I believe that over the past 6 months i have had 2 dropouts between the mixer and the desk not enough to worry about and my 2 assistant engineers have not mentioned any problems so as i also said very stable.
You are right that using effects should not increase latency but if you read the spec it states the following:
Less than 1.6ms CH INPUT to STEREO OUT (@SampIing frequency = 48kHz) / Less than 0.8ms CH INPUT to STEREO OUT (@SampIing frequency = 96kHz)
I just dont want to see this number increase as 10ms is very borderline, I have had some drummers complain that they can hear an echo if their volume through the cans is to loud so i tend to keep them down as they dont really need to hear themselves much through the cans when recording. The other option is direct monitoring but personally I dont like this way of working as i like to hear what is being recorded.
Being able to patch any input to different outputs is definately very useful but it is very easy to mispatch something so i had some sheets printed up which we use to fill in like snake number to channel input number to USB output number, we also use 2 Behringer ada8000 one is used for 48v phantom power the other just for dynamic mics and talkback.
Studio Manager is very good for setting up the mixer although it would be good to have it set up permanently on a separate monitor as the yamaha display can be difficult to see at times.
All in all I am very happy with this mixer and would certainly not hesitate to recommend it for recording, I might add that I came from an 01v and even though you have the choice of EQ I dont find them very musical, so i tend to insert an external EQ.
regards and sorry for being long winded in my reply.
dadking
Postby chris... » Sun Sep 29, 2013 12:38 am
dadking wrote:You are right that using effects should not increase latency
Correct - using the effects will have no effect whatsoever on latency.
Right - changing the sample rate has a small effect on latency, but, what does that have to do with using the effects ??
chris...
