Click here if your desktop/laptop audio contains strange noises
Postby Martin Walker » Thu Dec 08, 2005 2:56 pm
Since so many new posters on this forum seem to be suffering from 'funny background noises' in their laptop audio, here's a direct link to my two FAQs on the subject to hopefully save us pointing newcomers there by hand ;)
The first describes the probable cause of most problems, and suggests a couple of possible solutions (and one to avoid):
http://www.soundonsound.com/forum/showf ... er=1138326>/http://www.soundonsound.com/forum
The second discusses some specific laptop models that seem to cause problems due to a grounded power supply:
http://www.soundonsound.com/forum/showf ... er=1138328>/http://www.soundonsound.com/forum
There are lots of other FAQs as well - the full list can be found by following the link from our main forum page, or by clicking on the other sticky thread next to this one.
N.B. 02/09/2011 I've just added desktop to the title because so many desktop computer users are now suffering from similar problems. Ignore laptop-only advice relating to power supplies (all desktop PCs MUST be mains earthed), but the advice relating to tracing and eradicating ground loops is identical for both desktop and laptop computers.
N.B. 15/02/2015 Reinstated the two FAQs linked to above
Re: Click here if your laptop audio contains strange noises
Postby Gronow » Mon Dec 26, 2005 3:24 pm
oh thank you!!! New Tascam VLX5 monitors for Christmas but what a racket...I sorted all my cabling out and taped the plugboards to crossbars under tables and gave it all a good clean, got rid of the HiFi amp and speakers that had been on monitoring duties previously and connected up the Tascams - oodles of mains hum. Laptop is an Acer Travelmate 291LCi and yes it has a 3 pronged mains lead. If I remove its Earth connection and if this cures the noise is it safe to leave like that? The case is plastic mostly so I guess it's OK. Any advice would be gratefully received.
Trevor
Gronow
Once it sounds right stop!
Postby David Lewthwaite » Mon Dec 26, 2005 5:07 pm
You would probably have been best posting that under it's on thread, however my advice is NEVER remove the earth of a powersupply - it's there for a reason,
Borrow a DI box to go from the output of your laptop to monitors and ground lift it - you'll be surprised it works
David Lewthwaite
Postby Gronow » Tue Dec 27, 2005 11:43 am
Cheers & thanks for the reply. Could I pick your brains further please? I've disconnected the Earth lead in the laptop mains plug and the problem has gone, therefore it was a ground loop. BUT as you say, this was there for a reason BUT...surely..
1. The laptop is Earthed via the other equipment as that's why I got hum in the first place
2. The 3.5 mA at 19V from the supply is hardly life threatening although a lack of Earth could cause a static build up.
3. The difficulty is whenever the Tascam interface is unplugged from the laptop then the laptop becomes un-Earthed which I could cure by buying a spare power lead with the Earth still connected for these (rare) occasions.
4. The only place a DI box could go is between Tascam interface (unbalanced RCA Phonos) and monitors (Balanced XLR or unbalanced 1/4"). Therefore wouldn't the ground lift merely stop the signal as there would only be one connection?
Please forgive me if I'm being dim...
Trevor :?
Gronow
Postby David Lewthwaite » Tue Dec 27, 2005 12:10 pm
My laptop has a cheap and nasty creative MP3+ soundcard - unblanced phonos output
The DI balances the input onto XLRs and then ground lifts it - removing the ground connection in an unbalanced cable won't result in you losing the signal.
Borrow a DI from a friend and give it a whirl
Alternatively the Behringer DI20 which my laptop is flightcased with is only around £20
And you say you have an Acer Travelmate - are you sure its 3.5mA it draws on the output side of the PSU? My Travelmate draws 3.95A at 19V - which could actually kill you,
Finally, if somthing goes wrong with your laptop and power gets shorted to earth, it will find an earth path - through your audio interface and other connected equipment if need be.
David Lewthwaite
Postby Gronow » Tue Dec 27, 2005 12:30 pm
Thanks David, You're right, 3420 mA is 3.42A which is a whole different kettle of shocks (I must try reading things properly) What I'll do is exactly what you suggest and borrow a DI box and give it a whirl. Mind you if they're only £20 I might just buy one anyway.
Thanks for your help
Trevor
Gronow
Postby Gronow » Tue Dec 27, 2005 12:56 pm
More from me I'm afraid...have just ordered a DI20 from Dolphin music for £20 so I can try it out. Watch this space ( and anybody else who's having the same problem) and I'll post the results asap
Happy new year
Trevor
Gronow
Postby David Lewthwaite » Tue Dec 27, 2005 1:53 pm
Thats good, it should work - did perfectly for me, it enabled me to use my laptop live which is what i wanted it for in the first place!
And even if it doesn't a DI box is a handy thing to have knocking about, the only thing to watch out for is it doesn't have a mains adaptor, battery or phantom only.
But if you do what i did and get a 9V PSU from maplin or somewhere and just bodge it in it'll work fine
David Lewthwaite
Postby Gronow » Thu Dec 29, 2005 6:23 pm
David...guess what, DI box arrived, plugged it all in using a new (earthed) mains cable for the laptop, switched on and loads of noise....then I switched the ground lift switch and SILENCE (apart from the music of course). So thank you, have a beer you've deserved it. Anyone else with this problem ? Buy a DI box for £20 and there it is solved. I am going to sort out a 9V power supply, I've got loads kicking about and just need the pp3 connector which I'll steal from something or other. This set up also means I've got proper balanced XLRs going to my monitors which I like too.
Cheers and thanks again for your time
Trevor Gronow :beamup:
Gronow
Postby David Lewthwaite » Thu Dec 29, 2005 6:38 pm
No problem, i was forced to find a solution to it when i wanted to gig with my laptop as a keyboard sound module
Now its all prettily flight cased up with xlrs on the side, soundcard, di box psu etc in the bottom - i no longer get that look from whoever is engineering of "oh no, not another one" when i ask for an xlr and iec lead!
I was gigging once where there were quite a few bands on and one of them was doing what i do but had a laptop balanced on a bar stool, soundcard dangling off the side, mess of wires, it crackled had hum - was unbalanced, the engineer had to find a DI for them....unprofessional!
David Lewthwaite
Postby Martin Walker » Tue Jan 03, 2006 3:17 pm
Glad you got your problem sorted Trevor, and thanks to David for guiding you through the process!
As I said in those FAQs, a DI box will nearly always do the trick, and as you've found, it needn't be expensive either.
The problem with removing the earth connection on your laptop PSU is that in the event of a faulty PSU it's theoretically possible for mains voltage to appear on your laptop's metalwork (case, sockets, and so on), which could certainly prove lethal.
Postby Gronow » Tue Jan 03, 2006 6:06 pm
Thanks Martin for the reply. The laptop PSU is now safely earthed again and my system is lovely and quiet ...well until I start making a row anyway.
Cheers and thanks to SOS
Trevor Gronow
Gronow
Tracking Down Ground Loop Problems Guide
Postby Martin Walker » Fri Jan 13, 2006 12:37 pm
In addition to the above two links to FAQs on this forum, I also wrote a more general and extremely systematic 'tracking down ground loop problems' Q & A for SOS July 2005 that may help those with larger setups, and of course those without laptops:
www.soundonsound.com/sos/jul05/articles/qa0705_1.htm
Postby orangefunk » Fri Mar 03, 2006 2:16 am
I bought a lovely laptop over Xmas and finally got around to installing all my software on it and using it strictly as a music PC.
The laptop is a HP ZD8000 btw
I have the following gear:
Spirit Folio Mixer -> Laptop (Indigo IO input) - > Stereo Amp
with all my keyboards going into the mixer..
However I have a huge problem of noise... I'm not meaning hiss, I mean really horrible grinding/quantization style noise thats half as loud as the music I'm making...
If I just have my Promega 3 (balanced outputs) into the mixer, there are generally no problems, but if I start addng more then the noise appears...
In fact a lot of the noise appears if I haven't even got them plugged into the mixer and just have the mains pluf of those keyboards plugged in (yet the powered off!!).
Arrrgh...
I'm convinced its the laptop, as when I run it from batteries its quiet....
Anyone have similar problems?
I read the stuff about the DI box but I don't think that would help for me as I output all my stuff into an old Hifi amp...
orangefunk
Postby Martin Walker » Fri Mar 03, 2006 4:34 pm
Your Spirit Folio is no doubt earthed via its mains plug, as are your keyboards, and probably your laptop, so you're an ideal candidate for ground loop problems I'm afraid. Have you followed the steps outlined in my 'tracking down problems' link in my previous post on this thread? that should help you determine what's causing the problem.
I do find ithard to believe that just pluggin in your other keyboards causes problems if they are not connected to your mixer via audio leads, but as soon as you do (apart from the balanced outs of your Promega 3) you could get problems. I made up pseudo-balanced leads between all my keyboards and synths and my analogue mixer.
Postby orangefunk » Sun Mar 05, 2006 1:09 am
Thanks Martin
can you explain what exactly pseudo balanced leads are.. I typed it into google and was lead to an old SOS article which provided a link that didn't work anymore.
Cheers
orangefunk
Postby Martin Walker » Mon Mar 06, 2006 1:38 pm
I explain all about them in this feature from SOS November 2004:
www.soundonsound.com/sos/nov04/articles ... oblems.htm
Postby BillPayer » Sat Mar 11, 2006 1:24 pm
I have an ASUS W3a with an Edirol fa66, which I bought because of the balanced in/out and I actually got around to buying some balanced cables yesterday. Plugged it all in expecting that my background noises would go away 'cause the outputs on the fa66 and inputs on my EMU 1820 are balanced but WAMO the horrible little digital gliteches are right there! They go away when on battery power and go away when I plug in my cheap car ground loop isolator, but I thought I would not have to do this with balanced to balanced connections! Will I will have to get a DI or a Behringer hum destroyer then?
Any ideas anyone? :headbang:
BillPayer
Postby Martin Walker » Mon Mar 13, 2006 10:56 am
Balanced cables should solve all ground loop problems assuming that the gear connected to both ends of the cable is balanced. Here's a reasonably definitive guide to interconnecting equipment from Rane:
www.rane.com/note110.html
Postby BillPayer » Tue Mar 14, 2006 9:17 pm
Unfortunately Martin I seem to be one person that is still effected by horrible little electrical noises from my laptop when the laptop is operated from the power supply.
My emu 1820m has balanced ins and the fa-66 has balanced outs and I bought lynx balanced leads from Dolphin music http://www.dolphinmusic.co.uk/page/shop/flypage/product_id/3196.
:madas:
Any suggestions at all on this one?
BillPayer
Postby BillPayer » Tue Mar 14, 2006 9:57 pm
Oh and by the way, when I plug my EDIROL into the EMU via digital connection then there is no buzz or hum anymore!
BillPayer
Postby Martin Walker » Wed Mar 15, 2006 5:24 pm
Hmmmm....
Perhaps it's something to do with the chassis connections at both ends of those cables. As that Rane note link above shows, strictly speaking the screen of the cable should be connected at both ends, but sometimes this might result in noises remaining.
If you fancy the fiddle, try unscrewing the cable clamps at the output end of those cables and cutting the screen, or if you have a soldering iron unsolder it. The balanced connections only require the tip and ring parts, and the screen of the cable will still be earthed at one end, so this shouldn't affect its capabilities, but it might just kill those noises for you.
What you're effectively doing is converting your cables to number 8 wiring in the RaneNote.
The digital connection, being optical, also breaks the ground connection between the two items of gear.
Postby Pete Watson » Fri Apr 14, 2006 4:57 pm
Hi Martin
Thanks for your replies, just to make you feel better, i did read all those before posting!
I will continue to experiment to find the problem, but from reading all the posts I am very surprised the DI box didn't remedy it as that seems to fix 99%
The power cable is a round cable as you mention in your posts
Thanks, pete
Pete Watson
Re: Tracking Down Ground Loop Problems Guide
Postby Wurlitzer » Sat Apr 15, 2006 6:13 am
Martin Walker wrote:In addition to the above two links to FAQs on this forum, I also wrote a more general and extremely systematic 'tracking down ground loop problems' Q & A for SOS July 2005 that may help those with larger setups, and of course those without laptops:
Martin, I don't know whether it's just me but that article comes up all blacked out for me.
A few questions further to the above: Does one have to spec any particular kind of DI box for these duties? Or just get any bog standard cheapie one and insert it between audio output and mixer?
Also, I have problem with low level hum in my studio where I have a Flying Cow A/D converter connected to a Spirit Compact 4 mixer connected to Event TR8 monitors, ALL using balanced cables. The feed from the PC to the Flying Cow is digital, SPDIF. How can this be, if balanced cabling is supposed to solve such problems?
Wurlitzer
Postby Martin Walker » Tue Apr 18, 2006 10:07 am
Hi Wurli!
Now that's strange - Firefox informed me a few days ago that version 1.5.0.2 was ready for download, and when I viewed that article it was black for me as well. I assumed it was some quirk of the update, but if it's happened to you as well I'll inform Ian to see if it's a forum quirk (by the way, for anyone else who finds it 'blacked out', just use the Ctrl-A 'select all' keyboard shortcut and you'll be able to read it again).
The quality of DI boxes is the subject of various threads on the Music Recording Technology forum - plenty of people have bought Behringer DI-20 boxes and been happy; others swaer by more expensive solutions, but there are plenty of recommendations in the threads I mentioned.
Re your low-level hum - only Toslink optical will break a ground loop. S/PDIF on the other hand uses standard phono connectors, so plugging in such a cable can occasionally cause problems.
