iPad / External USB audio interfaces and control surfaces
Postby Richard Graham » Thu May 31, 2012 12:49 pm
So I bought a Camera Connection Kit because "the internet said" I could use 'class compliant' USB audio devices to get audio/midi into the iPad. It didn't work with my Zoom H4 or Korg NanoPad - what's going on? Wrong devices? Any help much appreciated! :)
Richard Graham
Re: iPad / External USB audio interfaces and control surfaces
Postby Richie Royale » Thu May 31, 2012 1:23 pm
Richie Royale
Postby mick.n » Thu May 31, 2012 6:43 pm
I bought the camera connection kit & the only thing i have used it for so far is to connect my Yamaha Motif (Classic\first version)via its usb out to play the "Garage band" instruments from the keyboard.
mick.n
Postby ezza » Thu May 31, 2012 7:45 pm
Try connecting a poweredUSB hub to the cck and connecting the h4 and nano pad to that. I have a zoom h4n and the nanopad and I have got them both working with the iPad.
/erol
ezza
Postby Richard Graham » Thu May 31, 2012 8:32 pm
Thanks Ezza, that's really useful info!
Richard Graham
Postby fleming24 » Tue Aug 28, 2012 6:38 am
Thank you ezza , this is really useful information. because i was suffering the same problem.
fleming24
Postby Richard Graham » Mon Oct 01, 2012 10:53 pm
Bought a Belkin 7 port powered USB hub, plugged everything into that. Zoom H4 now functions as external stereo microphone, mic/line/instrument input and headphone amp for GarageBand. Korg Nanopad Connected simultaneously handles drum duties. All works seamlessly. I am pleased as punch.
http://www.ebuyer.com/224107-belkin-usb-2-0-7-port-mobile-hub-black-
Richard Graham
Postby Marbury » Wed Oct 10, 2012 8:22 am
Ok, can anyone advise what I should use for connecting it to my PC running Cubase SX3, external Yamaha Motif, Roland JP8080 going through Edirol UM-2 (2 in-2 out midi)?
Marbury
Postby Richard Graham » Wed Oct 10, 2012 4:07 pm
What, an iPad? For midi, use the powered hub, camera connection kit, and any class-compliant Midi interface - then midi that to your PC via the edirol. For audio, much the same but with an audio interface feeding your edirol.
Or you can buy dedicated audio and midi interfaces for the iPad. E.g. The Alesis ioDock. I've heard mixed reports about those, though.
Richard Graham
Postby Goddard » Wed Oct 10, 2012 6:35 pm
Marbury wrote:Ok, can anyone advise what I should use for connecting it to my PC running Cubase SX3, external Yamaha Motif, Roland JP8080 going through Edirol UM-2 (2 in-2 out midi)?
Well, there's no perfect solution yet, but you might look at the Tascam iU2, which can dock with iPad via dock cable or connect via USB to a PC/Mac (but unfortunately, not at the same time) and has a coax S/PDIF digital output as well as MIDI I/O. So, can use S/PDIF to output digitally from iPad to your DAW (if your PC/Mac interface has a coax S/PDIF input). I like the iU2 very much as both an iPad and PC/Mac interface, but of course ymmv so recommend trying before buying if possible.
The Alesis IODock is also nice, but less versatile in some respects, working only as an iPad interface and lacking ny digital audio output (USB does MIDI but not audio I/O) and thus can only output analog audio (IODock's coax jack is only analog video out). The IODock's big advantage over the iU2 is that one can use MIDI devices connected to a PC/Mac with the iPad via the USB connection between the PC/Mac and IODock, a capability the iU2 lacks. I've had no problems using the IODock with an original iPad, but iPad2 users encountered problems when iOS5 first came out (since resolved?).
I'm not aware of any 2x MIDI port solution for iPad, although using the IODock's USB MIDI via PC/Mac a lot is possible (depending upon MIDI channels and app used). Korg Nano controllers connected thru a powered USB hub<>CCK work (as should any "class compliant" (driverless) USB MIDI device), but then audio I/O becomes a challenge (unless one is able/willing to use the iPad's analog in, possibly using something like a Tascam iZX). MIDI via WiFi (or maybe via Bluetooth?) is another option.
Goddard
Postby Richard Graham » Thu Oct 11, 2012 3:18 am
Its not a problem. You can connect both the NanoPad and Zoom H4 to the iPad using a powered hub. Do beats on the nanopad, monitor and record audio through the H4.
Richard Graham
Postby Goddard » Thu Oct 11, 2012 7:28 pm
That's very interesting to hear! Doh! Never thought to try that, Don't use an H4 but will try it with the iU2 via USB when I get home. Does it matter what app?
Goddard
Postby Richard Graham » Thu Oct 11, 2012 9:58 pm
Only tried GarageBand so far, it's all I really use!
Richard Graham
Postby Marbury » Fri Oct 12, 2012 9:41 am
Some of the options above are a lot more expensive than I thought. What I am doing at the moment (just to get audio into the mixer) is out from the headphone jack.
I have external my instruments going into my Yamaha AW4416 digital mixer and the audio out from that into the EMU 0404 soundcard via the digital in/out. I would hope to do the same with the ipad but outing the audio into the mixer (analogue) but still being able to control via midi.
Marbury
Postby ezza » Fri Oct 12, 2012 11:27 am
Take the audio from the headphone jack and use an iRig midi or similar for midi in out. Not too expensive.
If you really aren't happy with the sound quality of the headphone out you'll have to look at some of the solutions above.
Do you have a USB audio interface lying about? If it's class compliant there's a chance that it will work with the camera connection kit. There's a list of know working interfaces somewhere on the internet.
/e
ezza
Postby Richard Graham » Fri Oct 12, 2012 6:49 pm
Marbury wrote:Some of the options above are a lot more expensive than I thought. What I am doing at the moment (just to get audio into the mixer) is out from the headphone jack.
If you have a USB audio/midi interface already, the camera connection kit plus USB hub won't break the bank.
Richard Graham
Postby Marbury » Sat Oct 13, 2012 3:44 pm
The only USB I have is the usual front and rear on the PC. Is that where you mean to connect them ?
Marbury
Postby Richard Graham » Sat Oct 13, 2012 6:04 pm
Marbury wrote:The only USB I have is the usual front and rear on the PC. Is that where you mean to connect them ?
No, slight misunderstanding. You would need a standard USB audio/midi interface, plus the usb hub and camera connection kit. Once you have this, you can get both high quality audio and MIDI in and out of the iPad.
Afaik there is no way to digitally connect the audio and midi streams *directly* from the iPad to the pc and vice-versa.
Richard Graham
Postby Marbury » Tue Oct 16, 2012 6:43 am
Ok, thanks for that. Just to confirm: I need a camera kit (which has the USB hub) a USB interface (for PC ?)
Would this be the right thing ?
http://www.ebay.co.uk/itm/5-in-1-Card-Adapter-Apple-iPad-1-2-3-Camera-Connection-Kit-USB-TF-SD-MS-/160829207485#vi-content
Cheers.
Marbury
Postby ezza » Tue Oct 16, 2012 11:17 am
If you are not going to buy the official Apple Camera Connection Kit I would do some research before buying. They aren't all equal.
BTW, you have to jailbreak your iPad to use the one from eBay that you linked to.
ezza
Postby Marbury » Tue Oct 16, 2012 3:34 pm
I have no idea what you mean by Jailbreak. I have looked on the Amazon site and various types are sold with mostly 5 star reviews for under a fiver. Apple's are £21.50 !
Marbury
Postby Richard Graham » Tue Oct 16, 2012 6:18 pm
Marbury wrote:I have no idea what you mean by Jailbreak. I have looked on the Amazon site and various types are sold with mostly 5 star reviews for under a fiver. Apple's are £21.50 !
Apple's one works though, and I didn't see any mention of audio and midi interfaces on the reviews the cheap alternatives. I did see a lot of reviews reporting the iPad throwing up "this device is not supported" messages and people struggling to physically fit the adaptor into the iPad.
Let us know if you get one that works though - it's too late for me as I've gone and spent me 22 quid (and I'm very happy to have done so), but someone else might benefit!
Richard Graham
Postby Richard Graham » Tue Oct 16, 2012 6:40 pm
Richard Graham
Postby ezza » Wed Oct 17, 2012 7:41 am
Google is your friend! :-)
ezza
Postby mick.n » Wed Oct 17, 2012 9:49 am
I must have been lucky (for once) when i bought my camera connection kit for a fiver from ebay. Works perfectly..............so far. ;)
EDIT, This one.
mick.n
