Do you have a Mustang I or II V.2 ?
Postby Wimek » Sun Feb 10, 2013 5:09 pm
I bought myself a Fender Mustang I V.2 as a small practice amp. Out of the box it does what I expected it to do: it gives me a lot of reasonable sounds at a low level. And yes, here comes the problem: The Fender Fuse software does not sync with the amp. On the Fender forums I found out that I'm not alone.
Does any of you got a Mustang I or II V.2? Do you have the same problem ("No amplifier connected" in the Fuse software)
Wimek
Re: Do you have a Mustang I or II V.2 ?
Postby Wimek » Wed Feb 13, 2013 9:11 pm
OK, mystery solved: Fender is coming with a new version of the Fuse Software for the V.2 Mustang amps. The just "forgot" to tell that the V.2 Mustang amps are incompatible until that time... I.M.H.O. a bad choice of timing from the side of Fender :protest:
Wimek
Postby Wimek » Fri Feb 15, 2013 7:50 pm
Fender released version 2.7 of the Fuse software which is compatible with the V.2 Mustang amps :-)
Wimek
