MS20 Controller under OS X 10.5 / 6 ?
Postby waxwobbler » Thu Dec 02, 2010 6:14 pm
Hi All, just wondered if anyone is using this ?
Since the MS20 plugin has just been released as an individual purchase & the controllers are still knocking around I wonder if it would work ?
I guess it all depends on the driver for the USB midi connection ? or not ?
Any ideas ?
waxwobbler
Re: MS20 Controller under OS X 10.5 / 6 ?
Postby Dave B » Thu Dec 09, 2010 1:21 pm
Worked on 10.5 last time I checked - I can plug it into a 10.6 machine tonight. Think I've done it before an it worked ...
At the end of the day, it appears as a simple usb midi input device..
Dave B
Veni, Vidi, Aesculi
(I came, I saw, I conkered)
Postby Stephen Bennett » Thu Dec 09, 2010 9:45 pm
Mine is fine here with 10.6
Regards
Stephen
Stephen Bennett
New Henry Fool album (Feat: Phil Manzenera and Jarrod Gosling of iMonster.) New Tim Bowness album (Feat: Peter Hammill, David Rhodes, Pat Mastelotto.)
Postby waxwobbler » Fri Dec 10, 2010 7:01 am
Cheers guys, really fancy one of these even though they seem to be slightly toy like. Does it need a driver install or does it just work ?
waxwobbler
Postby Stephen Bennett » Fri Dec 10, 2010 10:14 am
It's USB class compliant, so needs no drivers. To be honest I only use it with the MS20 software - and it's brilliant with that. The keyboard is useless except for trying out sounds.If you're looking for a controller, something like a Novation SL is a much better bet.
Regards
Stephen
Stephen Bennett
Postby waxwobbler » Fri Dec 10, 2010 8:16 pm
Cheers Stephen, It would be specifically for the MS20 as I have always fancied one but not ready to fork out £1k ?
I did try the software years ago & thought it sounded really nice so if I can find a cheap controller I'll pick one up.
Thanks all,
waxwobbler
Postby waxwobbler » Fri Dec 10, 2010 8:43 pm
Neither of you guys fancy selling yours ?
waxwobbler
Postby Voodoo Raymond » Mon Dec 13, 2010 7:02 pm
Does anyone know how the patch cable detection works on the controller? Is it as simple as each output sending a different voltage, which tell the inputs what is plugged in?
Voodoo Raymond
