programming 'wobble' bass in reason
Postby RishiP » Tue Jan 18, 2011 1:19 am
Hello
I am trying to program a dubstep type bass in reason on the subtractor. I want the LFO low-pass filter to start on the low end on keypress (to get the "woowoowoo" sound. It seems to start wherever, is there anyway to make it start on one end of the filter on every kepress?
Rishi
RishiP
Re: programming 'wobble' bass in reason
Postby forumuser695516 » Tue Jan 18, 2011 1:28 am
forumuser695516
Postby RishiP » Tue Jan 18, 2011 7:35 am
almost,
I understand how to create a wobble, but I want to make sure on every key press it starts on the low, so it sounds like "wowowow" instead of starting with "owowow", if that makes any sense (try sounding it out). On the microkorg there is an LFO key sync, but it starts on the high end of the filter (i.e. owowow), but Ive made a perfect sounding patch on the subtractor in reason except for the "key sync", i.e. it starts on the "ow" sound. I hope what I'm asking makes sense although i do understand when describing these sounds it may not be perfect.
Thanks for your hekp,
Rishi
RishiP
Postby vinyl_junkie » Tue Jan 18, 2011 9:41 am
Well I don't know Subtractor or any of the synths is Reason for that but can you adjust the LFO start phase?
If you can problem solved..
vinyl_junkie
Postby SecretSam » Wed Jan 19, 2011 2:35 pm
... and another reply from someone who also doesn't know Reason well :-)
If you record the sound, then import into a sampler, you should be able to adjust the start position used when the sample is played back, thus chopping off the first bit of the LFO shape and effectively changing its phase. Or if the Reason samplers don't support adjusting the start position, then you could do the fiddling in a wave editor.
A bit of a drag, but probably better than watching telly.
SecretSam
Postby ElectronicMusicMaker » Thu Feb 10, 2011 12:48 am
Did you find a solution? Know its a bit late but I've just read this post - would it be something as simple as adjusting the filter envelopes? Push the attack slider up a bit to slow the attack to get your 'wow' on the start of the note. Hope this helps.
Postby forumuser695516 » Thu Feb 10, 2011 4:10 pm
TrayElectric wrote:Did you find a solution? Know its a bit late but I've just read this post - would it be something as simple as adjusting the filter envelopes? Push the attack slider up a bit to slow the attack to get your 'wow' on the start of the note. Hope this helps.
Since this post was made, i've had a few goes at doing it myself on various synths. Both hardware, and software, including Reason. It's not difficult 8-)
The James Bernard tutorials are well worth watching, because what he shows you in there doesn't just go for Reason, or even just Thor in Reason. You can apply it to most synths.
It basically boils down to a tempo synced LFO, that is assigned to filter cut off. You can also assign that same LFO to other sound changing parameters, like resonance or wavetable movement.
So rather than manually adjusting the filter cutoff, which you'd rarely get quite in time. The tempo synced LFO takes care of that for you. You just adjust the LFO rate knob instead, which works in various musical timings.
There is another trick Reason users can use though.. James Bernard made an 'automation toolbox' Think of it as pre recorded LFO's that you can dump on an automation track for anything you want (usually filter cutoff)
The good thing about these files, is that if the LFO doesn't start exactly where you want it to, then you just shift the automation file back or forwards by the required amount. Easy!
Youtube link and toolbox download are here on the Props forum:
https://www.propellerheads.se/forum/showthread.php?t=131949&highlight=automation+toolbox
Reason or not though. The key is basically having an LFO that syncs to midi clock. Many but not all synths can do this..
Paul
forumuser695516
Postby stevengamel » Mon Mar 21, 2011 2:56 am
This is much easier on something like the Native Instruments Massive. It seems to be designed for Dubstep. Or maybe thats the other way round. ;)
stevengamel
Postby FatherSonAndAlcohol » Thu Mar 24, 2011 5:03 pm
http://www.youtube.com/user/MrBillsTunes#p/u/15/rSOqqmnbgZM
I don't think this will work in Subtractor since the LFO rate has to be displayed in Hertz. I think you can use Thor for this.
What he does is he calculates synced rates in Hertz using a formula that utilises the BPM of the track. You may not get spot on values but it enables you to slide between synced rates smoothly rather than instantly. It's not something I would use for every sound, but it sounds pretty cool sometimes.
Cheers.
FatherSonAndAlcohol
Users browsing this forum: VOLOVIA and 3 guests
