I need a VST plug-in for one-finger chords
Postby The Elf » Wed Jan 11, 2017 6:32 pm
I'm looking for a VST plug-in that will let me assign multiple MIDI notes to a single key press and send the resulting notes to another VST instrument.
I tried Chordz (http://www.codefn42.com/chordz/index.html), which almost does what I need, but it seems to be limited to 12 chords per instance, which is far too limited (albeit I realise that I could use multiple instances to get around this - at a push).
Can anyone suggest something like Chordz, but with the ability to assign many more note patterns across a keyboard? 64-bit ideally.
Ta!
Re: I need a VST plug-in for one-finger chords
Postby BJG145 » Wed Jan 11, 2017 9:16 pm
...never tried it, but I was curious to read this about Xfer Cthulhu:
"One Note Becomes Many. Cthulhu is firstly a chord memorizer and player, allowing you to experiment with creating and reworking chord progressions with single-note presses. Included are over 150 factory chord presets allowing for a near-unlimited amount of possible musical-sounding chord progressions."
https://www.xferrecords.com/products/cthulhu
They make a great drum machine called Nerve.
Postby The Elf » Wed Jan 11, 2017 9:27 pm
:thumbup: Thanks, my friend, I'll take a look at it!
Postby The Elf » Thu Jan 12, 2017 9:19 am
This one is looking the winner so far:
http://www.vst4free.com/free_vst.php?id=1642
Postby Richie Royale » Thu Jan 12, 2017 11:55 am
Doesn't the Cubase Chorder plug-in do this?
Richie Royale
Postby Martin Walker » Thu Jan 12, 2017 12:06 pm
Richie Royale wrote:Doesn't the Cubase Chorder plug-in do this?
It would seem it does, but The Elf's 'midiChords' appears to do a lot more, judging by the fact that it 'Imports Cubase/Nuendo Chorder .xml presets.'
It's also incredible value for money ;)
Postby The Elf » Thu Jan 12, 2017 1:41 pm
I also need this plug to be available outside of Cubase.
I'm happy with the one I mentioned above. It does the job nicely.
Postby Steve A » Tue Jan 17, 2017 4:06 pm
In a similar vein, and hopefully therefore not a completely shameless thread hijack, I'd be interested in a plug-in that takes polyphonic MIDI information in a track and can distribute it monophonically round robin style over multiple VST instruments if such a thing exists. Basically I want to try and coax the monophonic Roland Promars plug-in into behaving like a sort of polyphonic virtual Jupiter 4.
Steve A
Postby A Mole » Wed Jan 18, 2017 1:13 am
Steve A wrote:In a similar vein, and hopefully therefore not a completely shameless thread hijack, I'd be interested in a plug-in that takes polyphonic MIDI information in a track and can distribute it monophonically round robin style over multiple VST instruments if such a thing exists. Basically I want to try and coax the monophonic Roland Promars plug-in into behaving like a sort of polyphonic virtual Jupiter 4.
That is pretty seriously OT Steve. I don't know of a plug-in, but one way to do it would be to get the notes onto different channels. This'd be fairly easy in most DAWS, just select them and change the channel in bulk.
I guess you could also set up a bunch of virtual instruments which are only able to respond to a constrained set of note numbers on the same channel, but perhaps life is too short!
A Mole
Postby Jumpeyspyder » Wed Jan 18, 2017 2:26 am
Steve A - Q. does you want this to be played live or to pre-recorded MIDI ?
Jumpeyspyder
Postby Steve A » Wed Jan 18, 2017 4:12 pm
Jumpeyspyder wrote:Steve A - Q. does you want this to be played live or to pre-recorded MIDI ?
No, pre-recorded is fine. I know it's a bit extreme and it's not worth doing unless there is a reasonably easy hack to get it to work. I do a lot of eighties re-creations / soundalike stuff and JP4 sounds are very useful for certain tracks and very recognisable to my ears. The Promars plug-out is pretty close but it's always irritated me that they didn't give it a polyphonic option.
Steve A
Postby The Elf » Wed Jan 18, 2017 4:24 pm
Have a look at the offerings from the guys who wrote my chorder utility. I see something there that sounds like what you are looking for.
http://thepiz.org/plugins/
