Studiospares RED10 vs Primacoustic Recoil vs Auralex MoPads?
Postby dickiefunk » Sun Feb 12, 2012 12:49 pm
Hi,
I've just seen these on the Studiospares website :-
Studiospares Red10
http://www.studiospares.com/speaker-spares+accessories/studiospares-red10-monitor-isolator/invt/465250/?htxt=m4O%2F5L1kjuyXGUzXslaEzeAwf3liQc5fOD7oykszY9yMna4YAyDV%2F0JRWbrB7AsCLESio865bC1%2F%0AtNkS9m6u7g%3D%3D
They look like a copy of the Primacoustics Recoil Stabiliser's? They are made from foam, steel and rubber like the Recoils?
Does anyone on here know how they compare to the Recoils and if they will be better than MoPads?
dickiefunk
Re: Studiospares RED10 vs Primacoustic Recoil vs Auralex MoPads?
Postby Hugh Robjohns » Sun Feb 12, 2012 1:26 pm
The idea of the steel plate is to 'load' the foam slightly so that it is in enough compression to act appropriately as the spring in a mass-spring-mass damper system. Mo-pads on their own can be too stif to be effective when used with small, lightweight speakers. The steel plate in the Recoil and other designs addresses that issue.... although a heavy ceramic tile or slab of metal will work just as well on mo-pads if necessary.
Hugh
Postby Jonesd90 » Sun Feb 12, 2012 5:08 pm
Is there any info anywhere as to how much weight you do need on mopads to properly load them?
I tried to do a search but couldn't find anything relevant at all...
Dave
Jonesd90
Postby nathanscribe » Sun Feb 12, 2012 5:16 pm
I see the Silent Peaks isolators mentioned in the Studio SOS articles sometimes - presumably they're good too? At £65 per pair, they're a good deal cheaper than the Primacoustics, which is something that would tempt me.
nathanscribe
Postby Hugh Robjohns » Mon Feb 13, 2012 10:41 am
Jonesd90 wrote:Is there any info anywhere as to how much weight you do need on mopads to properly load them?
I don't think I've ever seen it mentioned either. Basically, you want the foam to compress a bit -- maybe 25% or so -- when the speakers are in place.
hugh
Postby . . . Delete This User . . . » Mon Feb 13, 2012 11:01 am
compression anywhere between 5-10% and maybe about 65% will be fine..... outside of that, the material does not act reliably as a spring.
large areas of foam become surprisingly hard to compress, especially when the load is not directly vertical...
the other way to do it if your load is insufficient, is reduce the area, but cutting mopads down along their length. so they present less of a square area to the load.
and it's not just cheap nasty lightweight designs that are a problem, for example, a set of NS10's is not really heavy enough to sufficiently compress a std set of mopads.
Postby Jonesd90 » Sun Feb 19, 2012 3:05 am
It seems weird that they wouldn't publish guidelines for how much weight is needed for optimum foam compression.
The monitors I have on the Mopads are VXT8s which, like the NS10s, have an 8 inch driver but are also active so have the added weight of the amp and crossover etc... Do you recon they are loading the Mopad properly?
Thanks, Dave
Jonesd90
Postby Martin Walker » Sun Feb 19, 2012 1:10 pm
Jonesd90 wrote:It seems weird that they wouldn't publish guidelines for how much weight is needed for optimum foam compression.
I suspect that might result in a lot of people thinking they are 'too complicated' and therefore not buying them :beamup:
Jonesd90 wrote:The monitors I have on the Mopads are VXT8s which, like the NS10s, have an 8 inch driver but are also active so have the added weight of the amp and crossover etc... Do you recon they are loading the Mopad properly?
. . . Delete This User . . . wrote:compression anywhere between 5-10% and maybe about 65% will be fine..... outside of that, the material does not act reliably as a spring.
That's all you need to know Dave - measure the thickness unloaded and then when your loudspeakers are on top measure them again to check that the compression is at least 5% but not more 65% ;)
Postby Jonesd90 » Mon Feb 20, 2012 2:14 am
Thanks to you both Martin and Hugh for the foam facts!
Dave
Jonesd90
Postby Martin Walker » Mon Feb 20, 2012 10:39 pm
Our pleasure I'm sure :bouncy:
