Free Circuit Simulation Software
Postby DGL. » Sun May 13, 2012 8:37 am
Just though I should point all the DIYers on this forum to this piece of software
Yenka
It's a good free (for home use) circuit simulation software. Great for testing out simple circuits and microcontrollers.
It's basically a new version of the Croccodile Clips software that I used at school and it is very realistic.
As I have said before the home licence is FREE (the only limitation is that it cannot be used between i think 9:00 and 3:00 weekdays (to prevent schools form just using the free version).
It also does other things such as science sims Etc. but I think that the electronic circuits sim will be most useful (even does PCB's too! if I remember correctly)
To download go to http://www.yenka.com/en/Free_home_licences/
Works on PC, Linux AND Mac!
DGL.
Re: Free Circuit Simulation Software
Postby OneWorld » Sun May 13, 2012 9:40 am
Thanks for the heads up - looks very useful
OneWorld
Postby DGL. » Sun May 13, 2012 9:44 am
Yes is quite useful, especially when you blow something up!
Also the fact that you can have Mega Volt batteries!
Used the previous generation software crocodile clips at school and when I found I could get it for free I was well chuffed!
DGL.
Postby dmills » Mon May 14, 2012 1:05 am
Try also LTSpice from linear technology, IMHO a better simulator.
Got to be a little careful with simulations, they are only ever as good as the parasitics you set up.
Regards, Dan.
dmills
Postby Mixedup » Tue May 22, 2012 9:10 pm
I've also installed — but not yet checked out — Circuit Lab (circuitlab.com) which is a free app extension for Google Chrome. DroidTesla for Android is also worth checking out, though a bit fiddly on a mobile screen...
Mixedup
Postby Martin Walker » Thu May 24, 2012 2:22 pm
I just use a notebook for the electronic design process and a breadboard to try it out :beamup:
I can see the attraction of a virtual design process though, especially where expensive components are involved ;)
Postby dmills » Thu May 24, 2012 6:25 pm
That's fine Martin, but you try say calculating the noise spectrum of a multiple feedback filter that way......
Spice should never be allowed to over rule common sense, but it does have its place.
Regards, Dan.
dmills
Postby Folderol » Thu May 24, 2012 8:36 pm
I must say I'm another bread boarder. Most of the stuff I do is pretty simple and I can usually have an idea working and tested in a few minutes. Also I frequently take delight in using obscure features of components. Last time I used a simulator (admittedly quite some time ago) it failed miserably to account for this.
One of my 'classics' is this little beastie. For anyone who's interested, the prototype used BC108s and I made the point that C2 must be low leakage (that meant Tantalum in those days) and you should not fit a supply decoupler.
P.S.
An alkaline PP3 lasts up to 2 years :)
P.P.S.
Warning: SVG file. Some {cough} inferior browsers can't display it.
Postby Guy Johnson » Fri May 25, 2012 11:36 am
BC 108s ... wow, that brings it back!
Guy Johnson
Postby grab » Fri May 25, 2012 11:41 am
It doesn't have simulation tied in, but TinyCAD is a good schematic editor.
grab
Postby Martin Walker » Mon May 28, 2012 1:12 pm
Guy Johnson wrote:BC 108s ... wow, that brings it back!
I've got several hundred of the things still boxed away, although it was always the BC109D that got everyone excited for its higher gain and lower noise :beamup:
Postby Folderol » Wed May 30, 2012 5:08 pm
What is rather amazing is that these are still listed as 'current' types unlike many of their, um, replacements :shock:
Postby Martin Walker » Fri Jun 01, 2012 11:47 pm
I wonder if that could be because of the retro brigade still copying 1970 stomp box designs and searching for germanium transistors for better 'tone'? :beamup:
