Acoustic Treatment Help Needed - Placement and Size (Room Details inside)
Postby JamesNewmarch » Mon Nov 12, 2012 11:13 pm
So basically, through my mums work i can get hold of however much Acoustic Insulation i need for pretty much nothing.
I was wondering how many acoustic panels i will need to make and where i need to put them roughly in my room. I will be using 5.25in monitors in the position stated below. its a weird shaped room, with a window directly behind the speakers, which might not be great :/
Will probably be following this...
Youtube Link
What size panels should i make (depth, height, width)
Where should i mount them.
What corner traps are needed and where.
Would really appreciate some help on this. Thanks!
JamesNewmarch
Re: Acoustic Treatment Help Needed - Placement and Size (Room Details inside)
Postby zenguitar » Tue Nov 13, 2012 12:38 am
I'll move this thread to the DIY forum which also includes Studio Design and Acoustics. You'll get far more informed eyeballs there.
Postby James Perrett » Tue Nov 13, 2012 10:34 am
From an acoustics point of view I would be tempted to turn things around a bit so that the speakers are on the diagonal wall. This will mean that none of the other walls are reflecting sound straight back to the listening position and this is also the closest to a symmetrical arrangement that you can get in that room.
If you can't do that, I would at least move the desk as far away from the corner as possible.
James.
http://www.jrpmusic.co.uk
Postby JamesNewmarch » Tue Nov 13, 2012 2:31 pm
James Perrett wrote:From an acoustics point of view I would be tempted to turn things around a bit so that the speakers are on the diagonal wall. This will mean that none of the other walls are reflecting sound straight back to the listening position and this is also the closest to a symmetrical arrangement that you can get in that room.
James.
So whack the desk on the diagonal wall? Where would you recommend putting some panels if i were to keep the desk in the space or is it the window causing the problems.
JamesNewmarch
Postby thefruitfarmer » Wed Nov 14, 2012 10:50 am
Youtube Link
It is going to be a compromise because you are using the room as a bedroom as well and I would agree with James that having a speaker right in the corner is not good...
Ideally you would get everything out of the room and find the optimum position for the speakers, and then arrange teh kit and furniture around that.
The basic principle is to keep adding Rockwool traps until the acoustic problems go away...
Have you considered mounting traps on the ceiling/wall corners?
It looks quite full in there so that may be your only option....
thefruitfarmer
Postby James Perrett » Wed Nov 14, 2012 2:27 pm
The main problem is that your left ear is close to the storage while your right ear is in relatively free space. Reflections from the storage is going to be the biggest problem.
James.
Postby GIK Acoustics » Tue Nov 20, 2012 5:00 am
Youtube Link
Very good points above! This would be my solution as well. Let us know when you've found optimal position, and we can comment on treatment from there.
GIK Acoustics
Shelly Williams | GIK Acoustics USA (770) 986 2789 | GIK Acoustics Europe +44 (0) 20 7558 8976 (UK)
