New acoustic panels - air gap or no?...
Postby Gadget13769 » Thu Nov 29, 2012 12:01 pm
I have two new fibreglass panels (1150mm x 575mm x 50mm) to go on my back wall...
... so, following on from recent discussions elsewhere on the subject, will I see any real benefit from spacing the panels with a 50mm air gap from the wall? Or will this be so subtle in this case as that I might as well just fit them flush?
Discuss... :D
Gadget13769
Re: New acoustic panels - air gap or no?...
Postby Gadget13769 » Thu Nov 29, 2012 12:08 pm
Here they are...
Gadget13769
Postby Hugh Robjohns » Thu Nov 29, 2012 12:34 pm
Spacing them from the wall will extend the absorption to a lower frequency and it is worth doing if you can.
hugh
Postby GIK Acoustics » Fri Nov 30, 2012 4:50 am
Hugh Robjohns wrote:Spacing them from the wall will extend the absorption to a lower frequency and it is worth doing if you can.
hugh
+1. Though, two panels likely won't make a massive difference in the room. I would certainly suggest enough to hit the reflection points as well as some corner bass traps, and if its necessary, add from there.
GIK Acoustics
Shelly Williams | GIK Acoustics USA (770) 986 2789 | GIK Acoustics Europe +44 (0) 20 7558 8976 (UK)
Postby Gadget13769 » Fri Nov 30, 2012 9:32 am
GIK Acoustics wrote:+1. Though, two panels likely won't make a massive difference in the room. I would certainly suggest enough to hit the reflection points as well as some corner bass traps, and if its necessary, add from there.
Indeed.
I already have two corner chunks to go in the back corners, two panels for the back side wall, two panels for left/right reflection points, two larger front corner chunks and a large ceiling cloud.
I'm also going to get a couple more panels to go behind the monitor speakers, a panel on the back angle of my console and possibly an angled panel between the front wall and ceiling.
This is the front of my room so far...
Gadget13769
Postby sheggs » Fri Nov 30, 2012 12:25 pm
Looking Good :lol:
sheggs
David Shevyn General Manager GIK Acoustics Europe http://www.gikacoustics.co.uk
Postby Gadget13769 » Fri Dec 07, 2012 6:32 pm
sheggs wrote:Looking Good :lol:
So, to slightly alter the question...
If I'm now using 100mm of space from the wall (ie: 50mm panel + 50mm air gap), would I get better performance by just having a 100mm thick panel and no air gap?
(I realise 100mm panel + 100mm gap would be even better, but 100mm total is pretty much the maximum I can afford to use in this small room).
Gadget13769
Postby Hugh Robjohns » Fri Dec 07, 2012 6:46 pm
Not really, and it would be a lot heavier and a lot more expensive.
Postby Gadget13769 » Fri Dec 07, 2012 6:56 pm
Hugh Robjohns wrote:Not really, and it would be a lot heavier and a lot more expensive.
I can get the 100mm thick panels for about 1/3 more cost than for the 50mm, so the cost isn't prohibitive, but if there is no likely performance gain, then perhaps I should go with 50mm panel + 50mm air, as you suggest.
The weight isn't too bad. The panels I am using are fibreglass surrounded by 2mm MDF, so a 1150mm x 575mm x 50mm panel is only 3kg.
Gadget13769
Postby GIK Acoustics » Tue Dec 11, 2012 4:31 am
Sorry Hugh but I must disagree. There is a significant difference between a 2" panel with a 2" gap and a 4" panel from what I've seen(especially in corners, for obvious reasons). And fiberglass/mineral wool isn't all too heavy anyways :).
I recommend making 100mm thick panels as a minimum unless your goal is only to tame reflections.
GIK Acoustics
Postby Gadget13769 » Fri Dec 21, 2012 6:35 pm
*Update*
I have ordered 100mm thick panels for the back wall. I have used my 50mm panels on the side walls, with a small air gap... http://www.4x12.com/side_panels.html
I have also just put up a new page about my folding door bass trap... http://www.4x12.com/door_trap.html
Gadget13769
Postby RitchieM » Sat Dec 22, 2012 12:40 am
Wow!!!!!
That room looks amazing! I wouldn't get anything done, just sit in it with a sense of serenity and feeling of pride!
I don't think I can step into my own little box anymore, you have ruined me.
:shock:
Ritchie
RitchieM
