Different Patchbays
Different Patchbays
Postby pianolife » Thu Nov 29, 2012 2:56 pm
Dear members of SoundOnSound,
I'd like to know something more about the advantages and disadvantages of having these sets of patchbays
- normalled
- normalled with listen jacks
- half-normalled
- double-innered
I basically got the principles, but I can't understand which may be the relative (dis)advantages.
Thank you very much.
All the best!
pianolife
Re: Different Patchbays
Postby Hugh Robjohns » Thu Nov 29, 2012 4:23 pm
If you understand the principles then their relative advantages and weaknesses should be obvious.
Try reading these articles:
http://www.soundonsound.com/sos/mar98/a ... hbays.html
http://www.soundonsound.com/sos/dec99/a ... tchbay.htm
Hugh
Postby pianolife » Thu Nov 29, 2012 4:57 pm
Dear Hugh, thanks for your quick reply, I was reading your articles, and they are great!
I'm just not sure about one thing: is the double-innered the same that double-normalled?
Thank you very much!!
pianolife
Postby Hugh Robjohns » Thu Nov 29, 2012 6:47 pm
There is much confusion and alternative meanings when it comes to jackfield normalling, but my understanding is that double-innering is the same as double-normalling -- and that you need to plug leads into both sockets to break the signal path completely.
hugh
Postby GIK Acoustics » Fri Nov 30, 2012 4:47 am
The different setups of patchbays makes it possible to use all sorts of different equipment however you use it. There aren't really "advantages" and "disadvantages" but just different setups for what you need.
For example, I designed a patchbay for a friend who had multiple synthesizers. If the synths were just going to be plugged in straight to the mixing board, then normalled would be fine. However - we are hooking up all of the CV inputs - and have a Sherman filterbank that he will be routing things through as well. For this set up, non-normalled was best since we can plug any output into any CV input, route whatever we needed through the Moog filter or the Sherman filter and throw it to any output.
Though, the articles linked above clearly explain the differences excellently, so I'll just let those shine!
GIK Acoustics
Shelly Williams | GIK Acoustics USA (770) 986 2789 | GIK Acoustics Europe +44 (0) 20 7558 8976 (UK)
