Help with awkward room!
Postby copey12 » Mon Jan 09, 2017 7:03 pm
Hello all, I've recently moved into a new house and would like to set up a basic studio in a bedroom. I've got a big room but its an awkward shape so wondered if anyone could suggest where I should set up my monitors for the best mix position?
Hopefully a basic diagram should appear below....
copey12
Re: Help with awkward room!
Postby Martin Walker » Tue Jan 10, 2017 5:35 pm
Hi copey12, and welcome to the SOS Forums! 8-)
Oooh, that's not an easy space is it? :headbang:
Years ago I would have attempted to set up my monitors either side of that window, so that I had an outside view in front of me to look at. However, after the experience in my current small studio doing this, I found the flatness of the frequency response (even before adding any acoustic treatment) was significantly better below a couple of hundred Hz by firing the loudspeakers down the longer room dimension.
So, in your case I suspect that placing your loudspeakers on the 2.55 metre wall (rhs of your diagram) would probably give the best results, keeping each one the same distance from the 'top' and 'bottom' walls and placing your listening spot half way across the room.
Postby copey12 » Tue Jan 10, 2017 6:52 pm
Thanks Martin, much appreciated! I now have to win an argument about a wardrobe and a sofa bed :)
copey12
Postby Martin Walker » Wed Jan 11, 2017 3:53 pm
copey12 wrote:Thanks Martin, much appreciated! I now have to win an argument about a wardrobe and a sofa bed :)
Just try to keep their positions vaguely symmetrical about the 'loudspeaker firing axis' :beamup:
Would the sofa bed fit into that alcove on the 'left hand' wall? (i.e. at the back of your listening space)
Postby copey12 » Wed Jan 11, 2017 7:01 pm
Yes it would, the wardrobe is the more problematic item!
copey12
Postby Martin Walker » Thu Jan 12, 2017 12:15 pm
You could always give your clothes away, and then you wouldn't need a wardrobe - music is far more important! :mrgreen:
Postby ore_terra » Thu Jan 12, 2017 1:49 pm
... our give your clothes away and fill the wardrobe with mics and stuff
The Petra Flowers
ore_terra
We are The Petra Flowers - Facebook - Youtube - Bandcamp
Users browsing this forum: DGL., julesebbs007 and 2 guests
