One pair of speakers to replace JBL EON 15G2's + EON 518S subs?
Postby dickiefunk » Fri Aug 19, 2011 12:05 pm
Hi,
I thought I'd ask this question out of curiosity.
Is there a pair of speakers that could replace my JBL EON 15G2's and EON 518S subs but still be light weight and under £2000? I would be looking to put 3x vocals, keys, bass, kick drum and sometimes an overhead for the whole kit in venues around 200-300 people.
I've seen the JBL PRX625 and 635's which look like a possibility but these cost around £2300 and weight 27kg which wouldn't be fun mounting on stands on a very regular basis!
Is there anything else out there that could do a similar job but weigh less?
dickiefunk
http://www.richardpenrose.com
Re: One pair of speakers to replace JBL EON 15G2's + EON 518S subs?
Postby dickiefunk » Sat Aug 20, 2011 6:28 pm
Any thoughts on the JBL PRX 615 vs my rig?
I noticed that these have an SPL of 135dB max compared to the 129dB of my rig.
They are also 2000watts compared to 1800 of my combined system!
dickiefunk
Postby Ace-Audio.co.uk » Sat Aug 20, 2011 10:33 pm
I've had pretty good experiences with the QSC K12's yes a sub would enhance there performance but give them a demo in store see if you can put them up against your current setup.
http://www.qscaudio.com/products/speakers/k_series/K_series_K12.php
Of course if you did decide to get the matching k sub then it has castor wheels attached which might make life a little easier.
Ace-Audio.co.uk
Postby TSH-Tim » Sun Aug 21, 2011 12:14 am
If you want something smaller, louder and sounds better look out for some used d&b E9's with E15 subs.... your need around £2000 - £2500 but your NEVER look back :) or loose money buying them.
TSH-Tim
Postby dickiefunk » Sun Aug 21, 2011 8:17 am
Thanks for the replies guys.
I'm guessing the 15" JBL PRX 615's would be able to cope with bass and kick drum better than the QSC K12's? I'll try and audition these at some point!
The D&R rigs have always been on my dream list but these would also need amps to drive the speakers putting the cost well out of my budget! Also I am purely looking at one pair of speakers without subs.
The JBL PRX 615M's got a good review in last months SOS so I'm wondering how they would stack up next to my rig with the EON 518s subs?
dickiefunk
Postby TSH-Tim » Mon Aug 22, 2011 12:45 am
If your just looking for a one box system then the RCF 725a IS the box to buy and they sound like they have a active sub under them lol
Crazy box ! and worth every penny
TSH-Tim
Postby dickiefunk » Mon Aug 22, 2011 7:07 am
I heard the RCF 715a and that was bass light compared to the EON 315's that I A/B 'd in a store!?
dickiefunk
Postby TSH-Tim » Mon Aug 22, 2011 9:39 am
They are a beast and having played with most active tops / subs the 725a is stunning and like a said they sound like there's a sub in the room
TSH-Tim
Postby dickiefunk » Mon Aug 22, 2011 9:42 am
TSH-Tim wrote:They are a beast and having played with most active tops / subs the 725a is stunning and like a said they sound like there's a sub in the room
Thanks Tim. Have you compared them to the JBL PRX 615M's?
dickiefunk
Postby TSH-Tim » Mon Aug 22, 2011 12:55 pm
Not side by side but i have used both yes the RCF wins hands down.
TSH-Tim
Postby Falconhell » Wed Aug 24, 2011 5:25 am
I am probably a bit of a dinosaur compared to most here, but I would say any decent wooden box would be better than what you have.
I dont use any digital processing or self powered boxes at all. I have tried most of them. Only just came back to sound after a 10 year breke and built a system exactly the same way as I did 15 years ago.
As soon as word got out I got booked up till the end of the year.
Now I am regularly getting the punters coming up to me and saying that tonight was the best sound they had heard from that band at that venue(which i can never remember happening in the past. Plastic may sound "nice" it may sound "big" but frankly suffers severerly in a comparison with a properly setup wooden box system.
I did try QSC K12, (Quite nice)but I could hear the processing fighting to stop the thing exploding at high levels. The only way you would get 1000w out of one is to set it on fire!
Of course that would be heavier and more complex than your current system.
New stuff *may* be lighter and cheaper but there is a price for that.
Frankly speaker tech has hardly changed for the better since the early 80's.
I imagine that should stir up the troops a bit
Falconhell
Postby TSH-Tim » Wed Aug 24, 2011 7:54 am
I can see what your saying but speaker technology and amp technology has come along way in the last 10 years.....
Some people dont like DSP but there are many many pro's that out weigh the small cons that come with using DSP in speakers & amps.
Just look at d&b Audio.... stunning
TSH-Tim
Postby seablade » Wed Aug 24, 2011 11:02 am
Falconhell wrote:I am probably a bit of a dinosaur compared to most here, but I would say any decent wooden box would be better than what you have.
Yep, a LOT of overgeneralisations in that.
It is true that speaker enclosure design has only shifted so much in that time frame, and the classic enclosure design engineers are slowly being substituted out for DSP engineers(In other words speaker manufacturers are depending more on DSP than proper enclosure design as it is cheaper, not across the board, but enough so that it makes a difference). However you do imply that speakers(And by this I mean the driver and enclosure together) today don't sound much different from those in the 80s which is very much not true. Some designs from the 90s are still in use, but almost none that I know of from the 80s with the exception of maybe some clair bros systems, and for good reason. There just isn't to much comparison in general.
All this being said, when you get proper enclosure design combined with the DSP you can get some truly fantastic results that didn't exist in the 80s in any way shape or form(And really wasn't seen to often in the 90s). These include the top of the line solutions from Meyer and d&B audiotechnik for example, but you also get things like the digitally steerable line arrays and other solutions from Duran, Renkus Heinz, etc.
So speaker technology has hardly stood still.
Seablade
seablade
Postby TSH-Tim » Wed Aug 24, 2011 7:18 pm
MLA is the next thing everybody will be copying
TSH-Tim
Postby dickiefunk » Tue Jun 26, 2012 6:08 pm
Hi,
Thought I'd do a quick bump for this thread. The JBL EON rig I have is sounding nice but I don't want to have to keep carrying big subs around by myself.
An option that I hadn't come across before is the Yamaha DXR15 speakers.
http://usa.yamaha.com/products/live_sound/speakers/active_speakers/dxr/dxr15/?mode=model
I've read a couple of reviews on the Yamaha DXR15's and people comment on how big and fullrange they sound. One of the common comments is that they sound like there are subs in the room? They're 1100watts each which is an extra 200watts per side more than my EON 15G2 + 518 sub. Also, my EON15 G2's and 518's subs are quoted at 129db SPL but the Yamaha DXR15's are quoted as being 133dB!
Any user experiences of the Yamaha DXR15's here?
Any ideas as to how these would compare to my current EON 15G2 + EON 518 sub rig?
dickiefunk
Postby dickiefunk » Tue Jun 26, 2012 6:35 pm
TSH-Tim wrote:If your just looking for a one box system then the RCF 725a IS the box to buy and they sound like they have a active sub under them lol
Hi Tim,
Any ideas how the RCF 725a's compare to the Yamaha DXR15's?
At the moment the RCF's are totally out of my budget at £2200 a pair. The Yamaha DXR15's are £1200 a pair.
dickiefunk
Postby Dave.jj » Tue Jun 26, 2012 7:16 pm
FBT PromaxX 14a We have just brought some of these and they are excellent.... Might be worth a look for you?
http://www.fbt.it/ENG/PAE/PRODOTTI/SPEAKERS/ProMaxX/ProMaxX-14/index.asp
Dave.jj
Postby dickiefunk » Wed Jun 27, 2012 12:39 pm
Thanks for the reply. The FBT 14a certainly looks good on paper! Unfortunately I can only afford around £1200 and these cost £1800 per pair. If I had that budget then I would add the RCF 725amkII's to my list!
I tried the JBL EON 515XT's next to my old EON 15G2's and was very surprised to find that they didn't have as much bass as the 15G2's. They also suffered from port noise when pushed higher when playing bass guitar through them whereas the 15G2's were really clean!
So, after having a look around these are on my shortlist :-
Yamaha DXR 15 - £1200
EV ELX 115P - £1164
JBL PRX 615 - £1640 (would have to buy secondhand)
Turbosound Milan M15 - £1540 (been offered a good deal on these)
The Turbosound Milan is quoted at going down to 36Hz – 17kHz ±3dB, 23Hz – 22kHz ±10dB which is lower than my EON 518s sub!? This seems very impressive for a pair of 2 way speakers!! They have a continuous spl of 125db and max spl of 131db. This is a little lower then the others on my list which are between 133db to 135db spl. Of course in real world situations this may be different!?
One of the downsides of the Turbosound Milan M15 and EV ELX 115P are they're slightly heavier than my current EON 15G2's. Really I would prefer to get something a little lighter if possible unless the performance is far superior!
Has anyone on here been able to compare any of these? Which of these would be most suitable for putting kick drum and bass through in venues of around 200 people?
dickiefunk
Postby Bob Bickerton » Wed Jun 27, 2012 9:17 pm
It's occurred to me you won't be able to go by specs alone. The 515XT has the same frequency response as the G2s, at least on paper, yet from what you've said, there's quite a noticeable difference in real life.
Bob Bickerton
http://www.bickerton.co.nz
Postby dickiefunk » Wed Jun 27, 2012 10:43 pm
Bob Bickerton wrote:It's occurred to me you won't be able to go by specs alone. The 515XT has the same frequency response as the G2s, at least on paper, yet from what you've said, there's quite a noticeable difference in real life.
Hi Bob. Yes specs on paper are very different to real world performance!
Because of where I live I can't get to demo these and even then the nearest stores don't stock all of these!!
I would really value peoples opinions/experiences of these speakers.
The Turbosound Milan M15 and Yamaha DXR15 are said to sound as though there is a sub present so this is why I shortlisted these. I spoke to someone earlier who has used both the DXR15's and PRX 615's and he said the Yamaha's had slightly better bass response!?
In the SOS review of the Turbosound's the reviewer said that these are possibly the most full range 2 way speakers he has ever heard?
dickiefunk
Postby dickiefunk » Thu Jun 28, 2012 7:26 pm
Just found the video a/b's of the Milan's vs QSC K12, FBT Pro Maxx 14a and RCF 725a.
Obviously this is not exactly a realistic test the Milan's sounded way better than the QSC K12's!
In the comparison between the FBT14a, RCF 725a and Milan's it's harder to choose. They all appeared to sound good in the clip but with different sounds.
http://www.youtube.com/watch?v=Xzk7roEeagM
http://www.youtube.com/watch?v=begcHt1P8Gw
Would love to hear the Turbosound MI5's, FBT 14a's and RCF 725a's for real!!
dickiefunk
Postby dickiefunk » Thu Jun 28, 2012 9:19 pm
Just heard a video of my EON 15G2's vs the PRX 615M and on listening to this clip I preferred my 15G2's!??
If you fast forward to around 3 mins you can hear the a/b.
http://www.youtube.com/watch?v=86-4lcbtwew
Starting to think my EON 15G2's may better than I realize!
dickiefunk
Postby dickiefunk » Fri Jun 29, 2012 11:25 am
Just noticed that the FBT Promaxx 14a's are selling for £1500 a pair which is putting them closer to my price bracket.
Because of this my shortlist is looking like :-
Yamaha DXR15
Turbosound Milan MI5
FBT Promaxx 14a
Has anyone been able to compare any of these speakers?
Anyone :?
dickiefunk
Postby dickiefunk » Fri Jun 29, 2012 5:39 pm
Found some more info and a shootout between FBT 14a, RCF 725a, JBL EON 515XT, EV ZXA5 and DB Technologies 605D amongst others!
http://issuu.com/fbtelettronica/docs/fbt_promaxx_comparison_test#download
The FBT 14a's came out very favorably!
dickiefunk
Postby Dave.jj » Fri Jun 29, 2012 6:07 pm
Those are all the links I found when we were looking into getting our new PA. As you say the FBT's looked great.
We then went to hear them at The London PA center (who were very very helpful) and loved them. We have now played a couple of gigs with them and they are fantastic.
Dave.jj
Users browsing this forum: adeshady13 and 4 guests
