EQ guides and tips?
EQ guides and tips?
Postby JordanE » Wed Jul 18, 2012 11:17 pm
Hi,
I am looking to see if anyone happens to have any links or information for EQing? I am starting a new gig soon and one of my main jobs is to EQ. EQ is not really my strong suite and I wanted to start learning more about it. Does anyone have any links where I can read more about it and hopefully get some better knowledge on it?
JordanE
Re: EQ guides and tips?
Postby Mike Stranks » Thu Jul 19, 2012 9:12 am
Hi Jordan
IMHO the most important thing about EQ is to train your ears and brain as to what frequencies need some attention. THIS is a useful tool to get some practice.
Any of the standard books on sound recording/live-sound - eg Paul White's offerings - have useful sections on EQ and explain all about shelving, variable Q, swept mids, high-pass filters etc etc etc.
The older I get, the better I used to be
Postby Bob Bickerton » Thu Jul 19, 2012 12:46 pm
There are three main aspects of EQing that spring to mind.
One is EQing a system to a room.
Second is EQing monitors for foldback
Third is EQing individual elements (channels) to make them sound right.
It's a hugely complicated topic that can't be covered in a post.
Have a read of Hugh's very informative article Here
But here's a few thoughts to get you going.
Room EQ: if you have access to a system and a 32 band graphic EQ, play some of your favorite tracks through the system and then bring up each band on the EQ to see how it effects the sound. This is now my preferred way of EQing a system. I have a handful of tracks I know inside out that cover a full frequency range. If they send good through the system, the system will sound good full stop!
Monitor EQ: is often a compromise and a means of (often almost deaf) performers hearing themselves on stage. Feedback can be an issue so it's a good idea to be able to recognize frequencies as they feedback.
Channel EQ: the first step in adjusting the EQ of a channel is to know what the instrument should/could sound like. So often I've heard sound engineers degrade an instrument's sound simply because they really don't know how it should sound. Ever heard a string quartet where every instrument sounds like a violin? Once you know how it should sound, then you need to learn what is required to adjust the EQ to get there. If you don't know how it should sound then it's a little like having a map with no destination in mind!
Random but hopefully useful thoughts.......
Bob Bickerton
http://www.bickerton.co.nz
Postby JordanE » Sat Jul 21, 2012 5:16 am
Thank you both for the answers, they were extremely helpful.
JordanE
Postby Dave Gate » Sat Jul 21, 2012 7:31 am
I'd just like to add, in respect of monitor EQ, that for some reason 4kHz seems to be a problem frequency with any monitor that's got a vocal mic near it, in my experience. No idea why this is, but my first action when ringing out the wedges tends to be pulling 4k down!
Dave Gate
Gear List: reverse only.
Postby Sheriton » Sat Jul 21, 2012 10:06 am
I suspect that's because most vocal mics have a bit of a presence peak around 4k. There's a huge bump there on a 58 so that will inevitably be the first frequency to feed back.
Sheriton
There's nothing we can't face... Except for bunnies
Postby Dave Gate » Sat Jul 21, 2012 11:08 am
Sheriton wrote:I suspect that's because most vocal mics have a bit of a presence peak around 4k. There's a huge bump there on a 58 so that will inevitably be the first frequency to feed back.
That makes a lot of sense. Thanks!
Dave Gate
Postby DeLenover » Mon Jul 23, 2012 3:59 pm
Hey Jordan,
I've been reading this forum for a while but I think I should chime in here. I recommend you to take a look at frequency ear training software because it is quite very useful to learn what each frequency sounds like. There are basic trainers like Auricula and there are more complex (but powerful) trainers like TrainYourEars. I've used both and it's a great help. You can take a look at the video in their web to see how it works!
DeLenover
