Power Amp selection for PA system (500w FOR 8 OHMS)
Postby gogi » Tue Dec 24, 2013 8:59 pm
Hello Folks. I own one QSC GX5 power amp (500W for 8ohms both channels and 700 W for 4 ohms both channels driven). I am attracted to this amp because it matches my current Yamaha S115 mains speakers and JBL S118 subs. Most importantly it has a simple crossover switch that allows me run the mains and subs in crossover mode without using a crossover unit.
I need to buy another amp to achieve the same effect (i.e. I need the inbuilt crossover switch) but have a low budget as the QSC GX5 amp aint cheap. Can someone recommend some more affordable power amp with similar features i.e. 500W for 8 ohms/700 W for 4 ohms /AND BULT IN CROSSOVER SWITCH???
gogi
Re: Power Amp selection for PA system (500w FOR 8 OHMS)
Postby Sam Spoons » Tue Dec 24, 2013 11:25 pm
TBH the QSC QX5 looks pretty reasonably priced at around £330, I doubt there's a better quality amp with the features you require for the price.
Mr G J Guitarist
Postby James Perrett » Thu Jan 02, 2014 12:34 pm
I know that some of the Peavey amps have crossover options but the crossovers are additional plug-in modules. They probably aren't any cheaper than the QSC either. I've had good experiences when using the GX range so I'd echo the advice to find another one.
http://www.jrpmusic.co.uk
Postby Sam Spoons » Thu Jan 02, 2014 3:30 pm
I'd add that if you plan to use them for left and right channels of a PA you'd be better off having two matching amps.
Mr G J Guitarist
Postby shindigger » Wed Jan 08, 2014 12:57 pm
Just bought a Yamaha P2500S.
Very pleased with it.
shindigger
Postby Sheriton » Sun Jan 12, 2014 5:03 pm
Even though it only delivers 250W in to 8ohms rather than the 500W that you wanted?
Sheriton
There's nothing we can't face... Except for bunnies
