Nuisance neighbour evidence..Need some recording advice
Re: Nuisance neighbour evidence..Need some recording advice
Postby necromunger » Wed Mar 28, 2012 10:10 pm
after a week of my sleep being disrupted I'd finally had enough,came home on the friday/Early hours of saturday,after a real [ ****** ] week at work,decided it was payback time,so cranked my amps up to almost max,lined them up to the joining wall,of his bedroom and strummed away for half and hour on my guitars mostly playing power chords and using my distortion pedals to great extent,at 2.30 in the morning must have been a real shock to the clown next dooor I could hear doors slamming(obviously in frustration)and what sounded like someone with lead feet,funnily enough it had cured the problem,never had a peep out of him after that,thankfully the arse has now moved elsewhere!!!
haha the op should get something like this along his wall and let it rip for a few days and see how they like it 500% louder.
http://www.ebay.co.uk/itm/TurboSound-TSW-721-Speaker-soundsystem-1-speaker-only-not-funktion1-/140731525226?pt=UK_ConElec_SpeakersPASystems_RL&hash=item20c440a86a#ht_500wt_1413
necromunger
Postby Jimmy T » Sat Mar 31, 2012 4:57 pm
I'd record a video of a sound pressure meter using two omni mic's such as MKH20 and stick them 5 feet apart and record with a quality mixer and when played back through a decent system the sound of noise and footfall above will be startlingly realistic.
I recorded my flatmate (from front room below), upstairs dancing, just for fun and when listening to it back above her in the attic it was so realistic that I you could not tell it was a recording. Even when listening too it I thought she was at it again.
Was not a problem though, just a test.
Jimmy T
Postby ef37a » Sat Mar 31, 2012 5:03 pm
Jimmy T wrote:I'd record a video of a sound pressure meter using two omni mic's such as MKH20 and stick them 5 feet apart and record with a quality mixer and when played back through a decent system the sound of noise and footfall above will be startlingly realistic.
Actually! A dummy head recording would be the best possible answer. Downside is that it only "works" replayed on cans but these can go down to really low frequencies. No need for a fancy dummy head setup, just wear the mics!
Postby boymarsh » Sat Mar 31, 2012 5:48 pm
You mentioned that this vibrates the arms of your chair. Can this be seen? e.g., a glass sliding off the chair, or the vibration of a bit of tape stuck to the side. That might add some nice dramatic flair to your evidence...
boymarsh
Postby Creep_Joint » Wed Apr 04, 2012 3:31 pm
You could always have a go at remotely blowing up their speakers:
http://www.reddit.com/r/pics/comments/k62sc/i_feel_bad_for_this_guy/c2hyp6r
http://www.eetimes.com/electronics-blogs/other/4218221/noisy-neighbor-disruptor-circuit
(please, please, please try to remotely blow up their speakers)
Creep_Joint
Postby Meizy » Sun Apr 08, 2012 2:58 pm
You could contact these guys who may be able to help.
http://noiseabatementsociety.com/
I'm sure I read somewhere recently that they helped a lot in a case in London similar to yours.
Meizy
Postby Guest » Fri Jun 22, 2018 7:05 pm
Sorry to resurrect an old thread, but everything about it is what I am going through right now.
Is technomonkey around? Would love to know if he got any success, or how he coped in the end, I feel close to breaking point at the moment, it's been a bad week. I get disturbed during the night also, so I'm only getting around 4 hours every night and it's been going on for a couple of years.
I have decided to move but I can't do that right this instant.......and that's how bad things have got :-(
Thanks for reading.
Guest
Postby Guest » Fri Jun 22, 2018 7:06 pm
Sorry I got the OP's name wrong, techmonkey, not techno. :headbang:
Guest
Postby Hugh Robjohns » Fri Jun 22, 2018 9:46 pm
Techmonkey has not contributed to these forums for over six years. I know it's difficult and frustrating, but if you've pursued polite neighbourly requests without success and the council can't help, then relocating really is the best option.
Postby Guest » Fri Jun 22, 2018 9:51 pm
Thanks Hugh!
I found the thread on a google search and everything he's attempted is where I'm at.....and yes, at least due to reading about his efforts I'm realising I'm going to get nowhere with the council even if I complain (which is the impression I had anyway)
thanks again.
Guest
Postby Sam Spoons » Fri Jun 22, 2018 10:04 pm
Hugh is probably right but moving is not always an option. I have a little personal experience as I live in a Victorian semi with pretty thin party walls and have had some issues with neighbours (kids not music, and both ours and theirs TBF). The best possible option is always to talk to the neighbour causing the problem, most people do not like to cause upset to people they know and if you can get to the point where you are on pleasant speaking terms or even a cuppa every so often they may be much more inclined to be considerate. An angry attitude (however much it is justified) is counter productive (and, believe me, that was very much mine at one time), avoid it at all costs if possible. Should the neighbour be intractable then you options narrow so read back over the thread and approach your local EHO dept.
Good luck.
Postby Guest » Fri Jun 22, 2018 11:33 pm
thanks Sam
I've tried talking to the neighbour for over 2 years. I've been polite the whole time. I told him that the council will be looking into it further (as he's claiming not to know what's causing the noise), and I've kept an open mind that it might not be him but some kind of generator or something like that. So the council contact him as part of their investigating the problem and he gets annoyed at me, slamming doors, putting an angry note through the door, etc.
No more nice person from me. I won't argue, I'll just move, but I will let my landlord have my contact details so that their next poor tenant will have a witness to the problem.
But yes, in general I totally agree, it's always best to be polite with people, it's gets the best response usually (unless they have something to hide)
Guest
Postby ef37a » Sat Jun 23, 2018 7:06 am
Since the tread has bobbed up again...
No mention was made AFAICT in all the previous text that an A weighted SPL meter would probably not show the OP's noise levels with any kind of accuracy because of the severe LF attenuation. Image
A meter with a C curve would be needed.
Secondly, there has come onto the market a VERY cheap LDC mic. Generally known as the "BM-800" these mics are £20 or so and can be plugged directly into a laptop mic jack and recordings made with Audacity.
LDCs are notorious for picking up ground vibrations hence the "cat's cradle" isolation devices. I think simply laid on the floor, such a mic would grab a decent level I am sure, in fact I have a BM and will try it out later.
N.B. The mics ARE cheap and this reflects in the quality control. Lot of posts of them being noisy, low sensitivity or simple not working. I have been lucky and had two that work fine.
Postby John Willett » Sat Jun 23, 2018 8:39 am
There are various free apps for the iPhone that are a noise level meter.
I have compared the one on my iPhone with an expensive Neutrik one and they are pretty accurate.
So - I would suggest recording the noise and also getting a noise level reading - if you have two smart phones available I suggest also doing a video recording showing the noise level meter app in action.
This will help you with the Council and your neighbour.
John Willett
Postby Sam Spoons » Sat Jun 23, 2018 9:08 am
RoseQuartz wrote:thanks Sam
Apologies for my 'preaching to the choir' you have obviously taken all the reasonable steps you can.
Forgive me for asking this but do you actually know what the source of the noise it beyond any doubt or is it just possible that he is not responsible? If the former then you should carry out your threat of involving the council's EHO if only for the benefit of the next tenant (so they at least have a chance of starting off on the right foot with him)?
