PA mic systems
PA mic systems
Postby theabstractarts » Tue Apr 29, 2008 11:14 am
We are hoping to buy a PA speaker system to cater for events in medium-sized venues (such as medium-large chambers of the House of Commons). We will predominantly be relying on radio mics to pick up quiet orators.
I am wondering if anyone can recommend a budget to mid-level radio mic and receiver system and a complimentary, active PA system (at around 200 watts) for the job.
One other question:
Do common radio mic systems tend to output an automatically mixed version of all radio channels received or do they allow for basic level mixing?
Thanks!
Matt
theabstractarts
Re: PA mic systems
Postby John Willett » Tue Apr 29, 2008 12:33 pm
theabstractarts wrote:I am wondering if anyone can recommend a budget to mid-level radio mic and receiver system and a complimentary, active PA system (at around 200 watts) for the job.
The K+H PAS 100 may be suitable.
It's a portable PA system (battery or mains) and can have built-in radio receivers.
These are compatible with the Sennheiser G2 series.
You can have several units, all with receivers tuned to the same channel, keeping everything cordless.
John Willett
Re: PA mic systems
Postby John Willett » Tue Apr 29, 2008 12:43 pm
theabstractarts wrote:Do common radio mic systems tend to output an automatically mixed version of all radio channels received or do they allow for basic level mixing?
All radio systems need a separate receiver for each transmitter - so if you have 4 mics you will need 4 receivers.
All these have to work on separate frequencies. You will also need antenna splitters to feed all receivers from a single pair of aerials.
There are some receivers that have several in one box - these do not mix, but have separate outputs for each channel as they are all separate receivers, just all in one case.
And - you will therefore need an external mixer as well.
You could use several radiomics - mix together at the mixer and then send by radio to the PAS 100 mentioned above.
John Willett
Re: PA mic systems
Postby ROLO46 » Mon May 05, 2008 10:59 am
Shure do some excellent auto mixers that do work
8 mic ips, last mic lock on
They can be daisy chained
SCM81OE
Roger
imho
:angel:
ROLO46
Users browsing this forum: Luke W, Martin Walker, paul tha other, Random Guitarist
