How best to set up an AD/DA with OO2R?
Postby Iwan Morgan » Tue May 06, 2008 11:59 pm
Hi Guys,
I managed to snare an RME ADI-2 on ebay last night. It should be here by the end of the week.
I run a MAC/002R setup.
at the moment my mix room is setup like this:
002 > Mackie Big Knob > Adam A7'S
Which is all fine and simple.
To confuse things a little bit more I am having a small 6 channel transformer based desk refurbished at the moment, which I was hoping to use to sum 3 stereo channels from PT.
Which would leave me with a setup like this:
002 > 6 channel desk> Big Knob >Adam A7'S
I want to incorporate the ADI into this system. At the moment itseems that I could best use it to record A-D from the desk back to pro tools.
Would I be abe to clock Pro Tools to it?
I would like to make use of the D-A as well, as it is supposed to be significantly better than the 002, but this (if I am correct) only works in 2 channels so summing out the box would be ruled out.
Anyway this is my first external A2D/D2A and I would like to set it up to get the most benefit from it.
I Know many people are using the RME with 002's so would be interested in your setup advice.
Phew,
THX!
Iwan Morgan
Re: How best to set up an AD/DA with OO2R?
Postby Phil O » Wed May 07, 2008 10:13 am
You should be able to slave Pro Tools to the RME via the SPDIF embedded clock. Just remember to set the clock to SPDIF from the Set-up/Hardware menu.
If you decide to go the ADAT route, be aware that the 002 does not support SMUX so you're limited to a 48K sample rate.
http://www.myspace.com/philogg
Phil O
