M-audio Audiophile 2496 - When I record/bounce down my track it loses some quality - How do i overcome this?
Postby biffcheeze » Wed May 07, 2008 1:02 pm
As titled please
biffcheeze
Re: M-audio Audiophile 2496 - When I record/bounce down my track it loses some quality - How do i overcome this?
Postby Zukan » Wed May 07, 2008 1:03 pm
A bit more info would be handy: what DAW are you using and are you bouncing using the DAW, what bit res and sample rates are you working with etc?
Zukan
Postby biffcheeze » Wed May 07, 2008 1:12 pm
Using ableton live 7
Using 48000 sample reate.
Not sure on bit res, what should the settings be on.
Should i be losing some quality because its not an expensive card?
biffcheeze
Postby Zukan » Wed May 07, 2008 1:14 pm
No.
When you export what settings are you using:
48kHz, stereo interleaved, PCM?
And what are you playing back on (because I have a feeling it could be a sample rate playback issue)?
Zukan
Postby biffcheeze » Wed May 07, 2008 1:17 pm
recording 48khz, Not sure bit rate not at home.
playing it back on windows media player.
What are the typical settings i would need fella?
biffcheeze
