DI Boxes - Active or Passive
Postby keeno » Wed May 07, 2008 4:06 pm
Hi all,
Put this in Live Sound already but as it concerns both I thought I'd put it here too! Can anyone tell me what applications I'd need an active or passive DI box for? Not too sure on what to pick for what?
Cheers!
keeno
Re: DI Boxes - Active or Passive
Postby RichD » Wed May 07, 2008 7:29 pm
A DI box is used to give you a line signal from an different level. A passive DI box will only reduce a high signal to line. An Active will increase the signal.
RichD
Postby Mike Stranks » Wed May 07, 2008 8:34 pm
Um... No
A DI takes a line level input and produces a mic level output.
The passive variety just uses a transformer, the active uses electronics.
An over-simplification (and doubtless someone will be along very soon to point this out) but unless you're paying a significant sum for a DI, I'd always go for an active.
Postby Guy Johnson » Wed May 07, 2008 8:43 pm
Use both. However, a good passive is a gem: Always works! And no noise. Quite often an active, even with reasonable figures, will have hiss. Art seem to be quite good
Guy Johnson
This is my few words.
Postby Blue Lizard » Wed May 07, 2008 9:01 pm
BSS AR133's are good, solid (active) performers.
Getting a bit more slutty, I usually opt for Radial (the JDI is a lovely passive box, and the J48 it's active partner). 8-)
Blue Lizard
"It's not pretty, also you can't dance to it." - Frank Zappa www.bluelizardstudio.com
Postby RegressiveRock » Wed May 07, 2008 9:03 pm
I always use passive although I'm planning to audition a couple of actives shortly, one valve and one transformer plus solid state.
I don't know if this is a rule of thumb or not, but my DIs are either Jensen or custom wound and cost around £200 each. However, that is for studio work where I can keep an eye on the little feckers! ;)
Reg
RegressiveRock
Smoking Goats
https://www.facebook.com/SmokingGoats
Postby monosyllabic » Wed May 07, 2008 9:18 pm
Ken I Cummin wrote:Um... No
Still not quite, but here's the answer to the original posters question.
GIYF
monosyllabic
Postby RegressiveRock » Wed May 07, 2008 9:20 pm
GIYF
Heh! I'm a contributor to that article... :crazy: :tongue:
RegressiveRock
Smoking Goats
