bus freezing in cubase?
PostPosted: Fri May 09, 2008 9:21 am
by -Nightspirit
Hi
is it possible to freeze a bus i cubase 4.1?
I want to do this because I have just one uad card and want (need) to use more plugins than I can, on one uad card... of course I can use some other plugs but thay are not that fun to play with!
or I can not use busses,and put every thing direct on the channels, but thats abit pain in the ass.. and a lot more work...
any other tips on how to do this?
Cheers Dan
Re: bus freezing in cubase?
PostPosted: Fri May 09, 2008 9:38 am
by snipsnip
Im pretty sure you cant freeze group bus's in Cubase.
PostPosted: Fri May 09, 2008 9:49 am
by R. Spisketts
The way I usually do this is to solo the track, set the send to prefader, pull the fader for the channel down and then do an audio mixdown, importing the audio file to another track. Pretty tedious!
If you're doing a lot of this, then do a search for "senderella" - this neato little plugin allows you to do some routing tricks, one example is to route the output of a buss to the input of another track, which makes the above process a bit easier
by -Nightspirit
hmm any work arounds for my little problem?
I do not want to freeze evey track, theres like 50 of them... lots of freezing...
They should have some thing like a "fridge" button to freeze multible tracks at once! :smirk:
cheers dan
PostPosted: Fri May 09, 2008 9:52 am
by -Nightspirit
thanks for the tip malick!
I`ll check this out when I get home from work!
cheers
PostPosted: Sat May 10, 2008 8:48 pm
by Urthlupe
Hi Dan
Think you'll find that in Cub 4.1 it is already possible to choose group outputs as input sources for audio tracks.
Loopy
PostPosted: Mon May 12, 2008 2:23 pm
by -Nightspirit
hey thanks dude
that makes things very easy!
why dident I think of that my self? :headbang:
cheers dan
