Another Audio Interface Safari
Postby Trumpetman1234 » Thu Jan 04, 2018 10:47 pm
Hi all,
Happy New Year and all that!
I'm looking to update my Alesis io|14 and wonder if you good people can help me on my search?
The interface is great with good preamps and converters, but Alesis hasn't updated drivers for it so I am still running Mavericks and would like to upgrade my OS in order to get certain upgrades/plugins etc.
I have a mid 2011 iMac and need no more than 2 inputs but like the dual headphone output on the Alesis as well as the speaker outputs. My thunderbolt port is running a second screen at the moment but I'm sure I can free that up if needed, so I'm not particularly fussed about how it connects (thunderbolt, FireWire or USB).
I'm happy to spend £300 for the right interface but will stretch to £500 for something special!
Anyone got any recommendations?
As ever, thanks everso much!!
T-Man
Trumpetman1234
Re: Another Audio Interface Safari
Postby ConcertinaChap » Thu Jan 04, 2018 11:03 pm
You can get a second hand Apollo Twin (Thunderbolt) for £500 or slightly less on ebay quite easily, and it's a very fine bit of kit that also opens the wacky world of UAD plugins to you.
ConcertinaChap
Disclaimer: I don't claim to know anything at all.
Postby Trumpetman1234 » Fri Jan 05, 2018 5:57 pm
Brilliant, thanks CC - I shall definitely put that on my list of potentials!
Any other suggestions from anyone?
Trumpetman1234
Postby blinddrew » Fri Jan 05, 2018 6:06 pm
The RME stuff is just out of your price range but might be worth looking at for second hand / sale stuff?
Postby Watchmaker » Mon Jan 08, 2018 1:10 am
I'll recommend the UAD Apollo Twin too. Killer pres.
Watchmaker
"one feels most reassured hearing an expert's opinions on the matter..."
Postby Trumpetman1234 » Mon Jan 08, 2018 9:31 am
Brilliant - thanks so much for the recommendations. Looks like I’m going to have to up my budget a little!!!
T-Man
Trumpetman1234
Postby ConcertinaChap » Mon Jan 08, 2018 2:28 pm
I don't think you'll regret it.
Cheers,
ConcertinaChap
Postby James Perrett » Mon Jan 08, 2018 8:39 pm
If you are upping your budget I would seriously think about RME.
Postby Trumpetman1234 » Tue Jan 09, 2018 10:02 pm
Me again!!
Still tirelessly researching all of this!
Could anyone advise me if I would be able to daisy chain the following interface:
https://www.gear4music.com/Recording-an ... rbolt/1SWI
via thunderbolt on my mid 2011 iMac:
https://support.apple.com/kb/sp623?locale=en_GB
which already has a second display on that port?
Or is there an alternative solution?
As ever, thank you!!!
T-Man
Trumpetman1234
Postby ConcertinaChap » Tue Jan 09, 2018 10:18 pm
Thunderbolt is all about daisy-chaining. The Apollo Twins only have one Thunderbolt port. Therefore they have to be at the end of a Thunderbolt chain. So if your display has two Thunderbolt ports you can do it, otherwise you can't. For instance I have an LG 27MB85R Thunderbolt display which is daisy chained to an Apollo 8 which is in turn daisy chained to an Apollo Twin. But both the display and the Apollo 8 have 2 Thunderbolt ports so they can be daisy chained. The Twin has only one so it is the end of the chain.
ConcertinaChap
Postby Trumpetman1234 » Fri Jan 12, 2018 8:57 am
Morning all!
Just as a follow up to all of this. It turns out there was a workaround for getting the io|14 to work in a more recent OS. Apparently the issue is due to the Alesis kernel extension for the device being rejected by the "System Integrity Protection" (which was introduced with El Capitan) because it is unsigned.
A little fiddling in terminal sorted it out and means that it's still up and running - for now....!
I'm still researching a new Interface but slightly less urgently!
Thanks again for all your advice
T-Man
Trumpetman1234
Postby blinddrew » Fri Jan 12, 2018 2:35 pm
:thumbup: good stuff :)
Postby ConcertinaChap » Fri Jan 12, 2018 9:56 pm
Trumpetman1234 wrote:I'm still researching a new Interface but slightly less urgently!
Great to be able to take your time. I would say that the more upmarket interfaces from UAD, RME, Apogee and the like cost more but really do tend to be better. And because that sort of kit doesn't tend to be mishandled then it's usually a good bet for second hand too. Best of luck and have fun in the search.
ConcertinaChap
Users browsing this forum: hank_mesmerizo
