EQ spheres for Line Audio OM1
Postby Ramirez » Mon Feb 19, 2018 12:42 pm
Has anyone used these? - https://www.shapeways.com/product/5KY2M ... arketplace
Looks interesting... but also looks more textured than expected - would this have an effect?
Compared to the cost of the mic itself, it's a bit expensive, but I'm still interested.
I gather this is supposed to make them more suitable for distant micing by creating an on-axis boost (or making the mic more directional at higher frequencies? Same net effect?)
Aled
Ramirez
Re: EQ spheres for Line Audio OM1
Postby Hugh Robjohns » Mon Feb 19, 2018 1:02 pm
Ramirez wrote:Has anyone used these?
No. But I've used 'acoustic pressure equalisers' or APEs from DPA, Gefell and other manufacturers from time to time.
Nothing significant at audio frequencies.
It's a lot of 3D printed substrate material! ;-)
If it was just an HF boost you could replicate the effect with EQ... but it does rather more than that. (Edited for accuracy and understanding).
The sphere acts to create a pressure build-up in front of the diaphragm for on-axis sound sources, and that results in an HF shelf boost between about 2 and 8kHz for a 40mm sphere. (Bigger spheres exhibit the same effect, but starting from a slightly lower frequency, and vice-versa. The classic Neumann M50 used a 40mm sphere.) The pressure build-up accentuates the detail of sources in front of the mic and makes them sound a little closer and more focused with crisper transients.
But the sphere also increases the front-back attenuation so affects the polar-response in a frequency-selective way, essentially turning the mic more towards a sub-cardioid or even cardioid at the higher frequencies. This also reduces the HF content from off-axis sources (obviously) and that makes the mic more spatially selective, increasing the stereo width and -- significantly -- altering the direct/reverb balance. It is this last aspect which lies at the heart of the claim that it makes the mic more suitable for distant miking -- but it's only a marginal benefit. You might get way with positioning the mic a foot or two further away than without the APE for a given perspective or direct/ambient ratio.
APEs are useful tools to have in the toy box, but not essential by any means.
Postby Ramirez » Mon Feb 19, 2018 1:26 pm
Excellent, thanks Hugh. I might order a couple.
Re. the cost - it's more that the OM1 are so cheap rather than these being too expensive!
Although I don't quite get:
Hugh Robjohns wrote:If it was just an on-axis boost you could replicate the effect with EQ... but it does rather more than that.
Surely a typical EQ boost does not differentiate between what was on or off axis?
Ramirez
Postby Hugh Robjohns » Mon Feb 19, 2018 4:13 pm
Ramirez wrote:Surely a typical EQ boost does not differentiate between what was on or off axis?
Yes, quite. I should have said, if it was just an HF boost it could be replicated with EQ -- it is the fact that on-axis get's brighter while off-axis gets duller is what gives it the useful characteristics.
Postby mjfe2 » Fri Feb 23, 2018 1:58 pm
Fascinating looking product - has anyone tried them yet? I'm wondering if they'll work on other mics e.g. KM183
Neumann's own spheres cost around £90 each...
mjfe2
Postby Sam Spoons » Fri Feb 23, 2018 4:27 pm
Postby Hugh Robjohns » Fri Feb 23, 2018 4:34 pm
It's not big enough! The Linear Audio OM1 has a 20mm diameter whereas the KM183 has a 22mm diameter. You could try boring the hole out a bit... but I don't know how brittle or fragile the 3D printed material is.
In any case, the KM183 is equalised for the diffuse field, giving it quite a hefty HF lift in the near field. Adding a sphere would emphasise that even more which might not be very helpful unless the mic was quite a long way from the sound source... which isn't normal practice when using an omni mic.
Postby Sam Spoons » Fri Feb 23, 2018 5:02 pm
They do a range though, including the one I linked to which fits 22mm ø mics like the KH183....
Postby Aural Reject » Fri Feb 23, 2018 5:09 pm
Sam Spoons wrote:They do a range though, including the one I linked to which fits 22mm ø mics like the KH183....
Potentially more use with some of the Neumann modulars that don't have the HF lift of the KM183.
Aural Reject
Postby Hugh Robjohns » Fri Feb 23, 2018 5:13 pm
Oh... didn't spot that! :blush:
Postby mjfe2 » Fri Feb 23, 2018 5:23 pm
Yes I've just discovered there's a whole range!
I realise the KM mics are already diffuse-field equalised but I was hoping to use them in a Decca tree arrangement on an orchestra. I understand the original tree mic was the KM53, then they moved to M50s. Is the M50 capsule equalised in any way before the sphere is applied?
I note that Schoeps recommend their own spheres even on the MK 2XS omni capsule which is why I thought it was at least worth a try on the 183s!
mjfe2
Postby Hugh Robjohns » Fri Feb 23, 2018 5:57 pm
mjfe2 wrote:Is the M50 capsule equalised in any way before the sphere is applied?
You can't separate the sphere from the capsule in the M50, and the published plots show a 5dB HF boost which is consistent with the effect of the sphere alone. It is claimed to have a flat response in the diffuse field.
I agree it's certainly worth experimenting with APEs (spheres) in a Decca Tree configuration, but just be aware of the potential for a bright high-end in situations where the acoustic is dry and the Tree is close.
Postby forumuser840717 » Fri Feb 23, 2018 11:24 pm
The texturing and imperfectly spherical nature of the surface will probably have an effect but it's unlikely to be particularly audible. In an ideal world, though, it should have a smooth surface.
What's more important than relatively small imperfections in the surface is that the APE fits properly to the mic - no big air gaps and a smooth edge around the hole where the mic pokes through the APE. If the edge of the hole is nibbled/chipped where it's in close proximity to the capsule then you can get audible effects and an uneven/variable modification around the polar pattern. Whether or not that's a problem would depend upon how accurately calibrated is the mic in the first place and how sensitive you are to very small variations in sound. Chances are that without a reference point to compare with it might not be problematically audible anyway.
forumuser840717
Users browsing this forum: twotoedsloth
