White noise from Yamaha HS8 monitors with UPS
Postby aviorrok » Mon Feb 19, 2018 7:06 pm
HI,
I bought a new UPS (Advice EX1200) and new monitors (Yamaha HS8) when the monitors connected to the UPS there is a low white noise from the monitors if I connect the monitors direct no white noise.
It's ok or I need to replace the UPS or the monitors?
Thanks!
aviorrok
Re: White noise from Yamaha HS8 monitors with UPS
Postby Hugh Robjohns » Mon Feb 19, 2018 7:39 pm
It sounds like your ups isn't producing sine-wave mains, and/or your active speakers are sensitive to noise on the mains supply... But it might be making sure of the safety earth continuity through the ups.
Which ups model is it?
Postby aviorrok » Mon Feb 19, 2018 7:45 pm
Hugh Robjohns wrote:It sounds like your ups isn't producing sine-wave mains, and/or your active speakers are sensitive to noise on the mains supply... But it might be making sure of the safety earth continuity through the ups.
Advice Excellent EX-1200
aviorrok
Postby Wonks » Mon Feb 19, 2018 10:37 pm
Not a lot on the web about it at all. Do you know if it is an always on-line device or does it only kick -in when power's lost?
It doesn't appear to be a particularly expensive unit, so unlikely to be an always on-line model or provide a true sinewave output when it is. In which case, it shouldn't produce any noise (except maybe RFI) with mains power available, but might cause noise when it's running on its batteries.
If you can find a data sheet for the unit online and link to that, then we might be able to tell you more.
Postby aviorrok » Mon Feb 19, 2018 11:21 pm
Wonks wrote:Not a lot on the web about it at all. Do you know if it is an always on-line device or does it only kick -in when power's lost?
I think it’s always on-line, when the monitors volume is on Min the white noise gone.
Here’s the web of the UPS company
https://www.advice.co.il/en/new-exclusi ... excellent-מערכת-אל-פסק-detail
aviorrok
Users browsing this forum: CS70, Kwackman, Ramirez
