Can I run UAD plug-ins on Satellite without UA interface?
Re: Can I run UAD plug-ins on Satellite without UA interface?
Postby solidwalnut » Fri Jan 24, 2020 5:22 pm
CS70 wrote:
Just to make things more fun - it works also the other way:...
If I am hearing you correctly, you mean that it works only for you during recording, but not mixdown? I understand that all that's needed is the DSP to be anywhere, but the Apollo interface uses UAD DSP to process and then converts to analog-only out, correct?
I hope I'm wrong!
Thanks.
solidwalnut
Life's too short to think you're all that.
Postby ConcertinaChap » Sat Jan 25, 2020 2:23 pm
Just to confirm what Hugh said I had a satellite as well as an Apollo back when they were giving satellites away free if you bought an Apollo. I had both on my iMac but as an experiment tried running the satellite alone on my Macbook Air. Plugins worked fine in Logic, no issues at all.
ConcertinaChap
Users browsing this forum: Folderol
