Can I run UAD plug-ins on Satellite without UA interface?
Re: Can I run UAD plug-ins on Satellite without UA interface?
Postby solidwalnut » Fri Jan 24, 2020 5:22 pm
CS70 wrote:
Just to make things more fun - it works also the other way:...
If I am hearing you correctly, you mean that it works only for you during recording, but not mixdown? I understand that all that's needed is the DSP to be anywhere, but the Apollo interface uses UAD DSP to process and then converts to analog-only out, correct?
I hope I'm wrong!
Thanks.
solidwalnut
Life's too short to think you're all that.
Postby ConcertinaChap » Sat Jan 25, 2020 2:23 pm
Just to confirm what Hugh said I had a satellite as well as an Apollo back when they were giving satellites away free if you bought an Apollo. I had both on my iMac but as an experiment tried running the satellite alone on my Macbook Air. Plugins worked fine in Logic, no issues at all.
ConcertinaChap
