What mic technique is used in this recording?
Re: What mic technique is used in this recording?
Postby george_vel » Fri Mar 16, 2018 1:35 pm
Hugh Robjohns wrote:Generally, the outriggers are in the same plane as the main pair, rather than significantly closer or farther away from the sources (to avoid timing problems).
Ok, I'll keep that in mind, thanks.
And what do you think about the mikes? Do you think Oktavas are good enough or Rodes are better?
Might be irrelevant question for a person who works with top-end brands, but I am not there yet :-)
george_vel
Postby Hugh Robjohns » Fri Mar 16, 2018 1:42 pm
I've never used the Oktava MK12 mics but they get many favourable comments -- and you can buy different capsules for them too, much like the Rode NT55.
I know Mike Senior is a fan of the omni capsules on the MK012, although I've heard him comment that the cardioid capsules can sound a but harsh on occasion.
Postby george_vel » Sat Mar 17, 2018 9:23 am
Since I can stretch my budget a little bit and I want to buy a second pair which is at least one step up from what I have now, I plan to do the following:
- buy a pair of matched omni capsules to be used with the Oktavas I currently have;
- buy a pair of either Beyerdynamic MC-930 or Shure KSM-137, to be used as main cardioids pair instead of Oktava’s cardio.
Based on your experience, which one would you recommend (Beyerdynamic or Shure) for the applications I make, i.e. a capella or choir and piano?
george_vel
Postby wireman » Sat Mar 17, 2018 10:54 am
I don't know about the price tradeoff but alternatively the KSM-141 would get you cardioid and omni patterns. I have not used that microphone for your application, others could comment on how sensible this might be.
wireman
Postby george_vel » Sat Mar 17, 2018 11:48 am
wireman wrote:I don't know about the price tradeoff but alternatively the KSM-141 would get you cardioid and omni patterns. I have not used that microphone for your application, others could comment on how sensible this might be.
KSM141 is not directly comparable to MC930, and having already omnis alternative, I am keen to have a comparison of MC930 against KSM137.
george_vel
Postby Hugh Robjohns » Sat Mar 17, 2018 11:53 am
george_vel wrote:KSM141 is not directly comparable to MC930...
Obviously... But it would give you more options if the budget allows -- and there may well be times when having access to four omnis could be more useful than two omnis and two cardioids...
I haven't used the Shures myself, but PW gave them a good review and Shure mics are usually very good.
https://www.soundonsound.com/reviews/shure-ksm137-ksm141
I have used the beyer mc930s and I liked them a lot.
Users browsing this forum: CS70, Sam Spoons, Tim Gillett, Wonks
