How to tighten a loose butterfly catch
Postby mjfe2 » Tue Mar 13, 2018 5:02 pm
One of ours has become loose on a Boschma rack case. Is it possible to tighten the mechanism?
mjfe2
Re: How to tighten a loose butterfly catch
Postby zenguitar » Tue Mar 13, 2018 5:15 pm
I can't help with advice on tightening it.
But I was wondering whether a loose butterfly catch in London would cause a thunderstorm in the Amazon rainforest.
Yogi Berra
Postby Hugh Robjohns » Tue Mar 13, 2018 5:26 pm
Not usually, no.
In my experience it's usually necessary to drill out the rivets and start again with a brand new latch.
If the latch has become loose it's usually either because the hook(s) have been bent, or the retaining spring has lost some of its springiness. Neither are easy to repair, and in trying you're likely either to make things worse and/or weaken them further.
Postby Sam Spoons » Tue Mar 13, 2018 5:32 pm
zenguitar wrote:I can't help with advice on tightening it.
Only if it's yellow
Users browsing this forum: Funkyflash5
