Focusrite Saffire pro 26 and 56.. do you get much latency?
Postby wired4sound » Fri Mar 16, 2018 8:57 am
Hey people
Im looking at possibly purchasing a 2nd hand Saffire pro 26 or 56.
I've noticed the firewire port also doubles as a Thunderbolt port.
I have a late 2011 MacBook pro with 2.5 GHz Intel Core i7. It's still not bad at all.
My questions are:
what kind of latency can I expect when tracking with this interface?
Is it even necessary to use Focusrite's mix control software to achieve very low latency or can I just use Pro Tools for my cue mixes?
Would using firewire as opposed to Thunderbolt make much difference in terms of latency?
The pro 56 seems v good value with 8 onboard pres including the 2 liquid pres.
I also noticed that the Scarlett 18i20 only runs on USB. Would that provide any better/worse performance over firewire or thunderbolt?
Interested in thoughts.
wired4sound
Re: Focusrite Saffire pro 26 and 56.. do you get much latency?
Postby ef37a » Fri Mar 16, 2018 9:07 am
I shall follow this thread. Focusrite AI are often praised for their pre amps but not often for low latency.
Might there be firm and software updates?
Postby Dave B » Fri Mar 16, 2018 10:06 am
I have a 56 and a 24 and used to have the original old 26 (the shiny one) before that. The 56 is the main studio io and the 24 was bought to be a Mainstage interface for my 2010 MacBook Pro.
I'm sure someone can give you precise figures for the latency, but I find that the buffer size is the real overriding factor in determining that. Beyond that, they work just fine. Latency is only really an issue for virtual instruments - monitoring can be done via the unit / mix control, and anything like overdubbing is more a function of the DAW.
I don't use PT so can't comment on the cue mixes. I've used the DAW (Logic) and mix control quite happily.
Dave B
Postby James Perrett » Fri Mar 16, 2018 11:36 pm
wired4sound wrote:Would using firewire as opposed to Thunderbolt make much difference in terms of latency?
These are Firewire only - I'm fairly sure Thunderbolt wasn't available when these came out.
Postby OneWorld » Sat Mar 17, 2018 3:51 pm
I used a Liquid 56 for several years, utterly reliable, and I used it with a latency down to 32 samples. Depending on what VSTs I had loaded, it did struggle when I was down to 32 samples, so for the main part settled on 64 samples.
I 'upgraded' to an RME Fireface 800, as they are supposed to be top dollar as regards latency, and use Firewire800, but I can only get down to 48 samples. And like the Liquid56, it is happier at 64 samples. So I can hardly distinguish the difference.
I was going to sell the Liquid 56 but am keeping it as a backup, in case the RME goes pop (hope I'm not tempting providence there)
I found the Focusrite gui/mixer perplexing and think the RME TotalMix even more so, though in the defence in both cases, signals can be routed here there and everywhere.
I am quite sure the Firewire does not double as a Thunderbird interface, it is a standard FW400 connector
OneWorld
Postby dickiefunk » Sun Mar 18, 2018 9:25 pm
There is an ongoing comparison test here :-
https://www.gearslutz.com/board/music-c ... -base.html
The Focusrite Saffire Pro 24 actually compares very well and the ones that are a noticeable step up in low latency are higher end RME interfaces, Lynx Aurora 16 and Presonus Quantum.
dickiefunk
http://www.richardpenrose.com
Postby Studio Support Gnome » Tue Mar 20, 2018 2:24 am
I play guitar live thru one,
what Feckin latency ???
you know what the difference between 6ms and 8 ms is ?
equivalent to sitting 24 inches further from your speakers.
Users browsing this forum: Zukan
