Compact mixer pre into Zoom R16?
Re: Compact mixer pre into Zoom R16?
Postby Hugh Robjohns » Mon Aug 13, 2018 10:20 am
The 'like touching the end of a jack lead' comment strongly suggests to me that you have a system without a proper ground connection.
This is surprisingly common these days as more and more equipment uses class-2 (double insulated) wall-wart style power units.
Often, the recorder will pick up a solid ground when connected to external class-1 (mains-grounded) devices, like many powered monitor speakers, so you could experiment with connecting the R16 to something else just to get that solid ground connection.
Postby permanent_daylight » Mon Aug 13, 2018 4:12 pm
I think that might be an idea. The 3rd pin is plastic so not used (UK style plug). It may be the issue but is consistent across many buildings i've used it in. What would i connect exactly? I don't notice a specific ground pin screw like some devices have.
permanent_daylight
Postby permanent_daylight » Mon Aug 13, 2018 5:41 pm
would a ground lift work in the XLR path? https://www.amazon.co.uk/Hosa-GLT-255-Ground-Lifter-Adapter/dp/B00FC4YPL4
I'm just imagining the amusing site of a long rod of XLR connectors if i attach this to my fethead and then my external phantom power :headbang:
permanent_daylight
Postby James Perrett » Mon Aug 13, 2018 6:12 pm
Do you have any gear that is grounded that you could plug into the R16? It doesn't have to be in the signal path or even switched on - just connected.
Postby permanent_daylight » Mon Aug 13, 2018 9:18 pm
I see. Probably only guitar amps but I will check. I'm sure there would be something... as long as it uses the 3 pins I am guessing, not e.g. an effects pedal.
permanent_daylight
Postby permanent_daylight » Sun Aug 19, 2018 2:27 pm
Worked. Thanks.
I only have the 50kg option of my combo amp though.
Does anyone know a cable/connector device that does the same? Perhaps a preamp that is actually earthed for cheap if not?
permanent_daylight
Postby Hugh Robjohns » Sun Aug 19, 2018 6:50 pm
Postby James Perrett » Sun Aug 19, 2018 9:17 pm
Hugh Robjohns wrote:Here's one option:
https://www.soundonsound.com/reviews/gr ... ction-plug
One thing to check with products like this is that the ground is directly connected. Some have a high value resistor between the ground pin and the terminal as they're often intended to reduce static rather than as a direct ground connection.
Postby Hugh Robjohns » Sun Aug 19, 2018 9:54 pm
Indeed. The product in that review provides a solid ground, and I reviewed it because that is unusual. Most are intended for static protection and include a high value resistor, as you rightly say.
Postby permanent_daylight » Mon Aug 20, 2018 12:59 am
If that's just a connection straight to ground, why not just rewire a standard UK plug with a TRS cable? It seems like there's the same work either way (or in fact no soldering with most plugs). (Or will I die as a result lol)
permanent_daylight
Postby Hugh Robjohns » Mon Aug 20, 2018 1:28 am
The Groundology plug has non-conductive line and neutral pins, making it inherently safe under all conditions.
Wiring a ground lead into the earth pin of a standard mains plug would do the same thing but isn't inherently safe... And hence it's not an approach I can openly recommend on a public forum to people of unknown technical competence. But I do have some equipment here wired to ground using that kind of technique....
Postby permanent_daylight » Sun Aug 26, 2018 3:12 pm
Found out the studiospares valve preamp sells to next to nothing used...and has a ground pin. so should earth everything (and hopefully be useful for more gain much like OP suggesting). notice its impedance its super high (but engaging phantom lowers it) so might improve ribbons and dynamics a bit too.
permanent_daylight
Postby skynet888 » Mon Nov 05, 2018 10:16 pm
My 2 cents...
I have a Zoom R16 and record all my instruments direct to the unit mostly dry and or the odd wet track. After I recorded all the instruments to the Zoom I move my SD card from the Zoom to my computer and use the Reaper DAW to mix and add effects etc. For myself, this method works very well. Then if you wish, transform your finished WAV file to a MP3 file and upload to YOUTUBE. Or other Web based platform you would like to spot light your finished product.
and remember...clones are people too.... :geek:
Dave :)
skynet888
Postby dkelley » Thu Oct 15, 2020 10:27 pm
FYI, I own a Zoom R16 and recently moved to it being my primary recording/playback interface, as I've downsized from my 24 channel inline analog yamaha desk and dual m-audio 1010 systems... kind of overkill as I only work in my little home music room these days.
The R16 is pretty amazing. I record directly into reaper with it at 96k.... why 96k? low latency, and for some reason it pops and cracks and occasionally pauses connectivity for about 1 second when running at 44.1, so I went all out and it's solid as a rock for me at 96k as an audio interface.
I've used it for stand alone remote recording too and it's excellent.
But yes it's preamps aren't high gain, and can generate noise, and as I'm no longer using the very high end mic preamps in my old yamaha board, I needed to upgrade (specially for my ribbon mics).
So I recently rummaged through my projects drawers and found an ancient Tesla EJU-124 channel strip that had never been racked up. Never had the schematics for it to know how to rack it up or even what power requirements it had. I found that stuff online now though ok (thanks to google translate - nearly none of it is in English). So I finally finished a project I started a couple decades ago - and SUCCESS! 70db of good, transformer balanced mic pre, clean as a whistle, very low noise, with a switchable pultec type EQ if/when needed, as well as phase reverse option.
Putting THAT in front of my R16, with R16 input set nearly all the way off and the output maxed on the Tesla, setting gain as high as possible for the mic without clipping (fortunately there's a clip light in the output stage of the Tesla), and I get a ton of clean gain into my R16 and a nicer sound quality. It's not a high end channel strip, but it's vastly superior quality to the very simplistic stock R16 mic preamp circuits, which I took a look through when I was fixing a bad input jack connection on my R16 (boy I hate trying to read surface mount stuff).
So I can confirm that yes, you can put a higher quality, higher gain preamp ahead of your R16, and get much better S/N ratio and run much lower level mics and quieter sources, and the sound quality is honestly better with the R16 mic preamp level set to nearly off than cranked way up - I've noticed it loses low and high end as you crank the gain in the R16, so it's much more neutral, allowing the flavour of your dedicated outboard mic preamp to shine through.
Doesn't have to be so esoteric as my choice - it's just something I had around, and the kind of stuff I like to do as an engineer.
Cheers
dkelley
Postby Darren Lynch » Mon Oct 19, 2020 4:34 pm
Thanks for taking the time to contribute your thoughts to what is an old thread. During the Lockdown, I have been using the R16 more than usual. Them preamps are damn noisy! The form factor and portability are great.
Darren Lynch
