Audio Technica AE3000 Microphone
Postby GRAHAM99 » Fri Jul 20, 2018 6:11 pm
I have the opportunity to buy an Audio Technica AE3000 mic.
Has anyone had any experience of one?
GRAHAM99
Re: Audio Technica AE3000 Microphone
Postby Hugh Robjohns » Fri Jul 20, 2018 7:48 pm
Postby GRAHAM99 » Fri Jul 20, 2018 7:52 pm
Thanks for that!!!
Not been able find much info about the mics on line.
GRAHAM99
Postby Hugh Robjohns » Fri Jul 20, 2018 10:00 pm
Nor me, and I've never actually seen one let alone use one!
It appears to be a pretty flat and smooth electret LDC with cardioid pattern, but it's primary strength is its very high SPL capability 149dB, or 159 with pad switched in), making it a good choice for loud guitar cabs, brass, close drum mics, etc.
Self-noise is a little high for an LDC at 11dBA, but not a problem for the intended role with loud sources, and still much less than most SDCs. Sensitivity is sensible at 7mV/Pa.
All in all, it looks like a good mic for loud things! :-)
Postby GRAHAM99 » Sat Jul 21, 2018 8:51 am
I was after another mic for guitar cabs so might be tempted!!
I take it it would not need phantom power?
GRAHAM99
Postby blinddrew » Sat Jul 21, 2018 9:18 am
Specs say phantom power in the usual 12-52V range.
Postby GRAHAM99 » Sat Jul 21, 2018 10:21 am
Thanks for that!!
GRAHAM99
Users browsing this forum: Sam Spoons
