Focal Shape Twin/Shape 65 vs Neumann KH120?
Re: Focal Shape Twin/Shape 65 vs Neumann KH120?
Postby Hugh Robjohns » Tue Aug 21, 2018 9:50 pm
dickiefunk wrote: This means I have a lot of headroom left!
This means your gain structure might not be correctly optimised! :lol:
Postby dickiefunk » Tue Aug 21, 2018 10:20 pm
Could you offer any advice if this is the case?
dickiefunk
http://www.richardpenrose.com
Postby Hugh Robjohns » Wed Aug 22, 2018 11:02 am
Your reference level position for the monitor volume control should be about 2-o'clock, rather than under 12-o'clock. That will optimise the signal levels through the monitor controller, minimise stereo tracking issues, and avoid having too much headroom in the speakers to deafen you if something goes wrong and you get full level noise!
Reduce the input sensitivity of the Neumanns to the 94dB setting if necessary to maintain a sensible reference acoustic level in the room.
It sounds like the hiss is coming from your subwoofer, and I presume that is applying high-pass filtering for your Neumanns. If so, you may need to optimise the signal levels through the sub to maximise the signal-noise ratio.
Alternatively -- and this would be my preference -- feed the monitors directly from your monitor controller with a full-range signal and split the output to feed the sub directly. Then adjust the sub's low-pass filter to bring it in under the Neumanns and balance the level as necessary.
Postby dickiefunk » Wed Aug 22, 2018 8:40 pm
Hugh Robjohns wrote:Your reference level position for the monitor volume control should be about 2-o'clock, rather than under 12-o'clock. That will optimise the signal levels through the monitor controller, minimise stereo tracking issues, and avoid having too much headroom in the speakers to deafen you if something goes wrong and you get full level noise!
Hi Hugh,
Thanks for the info, very helpful :thumbup: Yes I would have the reference level of my interface set at around 2 o'clock and have the Neumanns set to 94dB if I was purely using them for myself to mix on. However, I sometimes have bass players and drummers in who like it louder and want to be able to feel the sound more hence having them set to 100dB with the ability to turn them up more when needed.
I've been in communication with Eve Audio and they have been very helpful with prompt replies. They have tested and measured the TS108 with the KH120's themselves and have said turning up the System Volume on the TS108 does not add any hiss to the KH120's but what the Focusrite does is out of their knowledge.
However, when I turn the System Volume up past 50% on the TS108 there is a noticeble increase in hiss through the KH120's
I'm not sure how the Focusrite Saffire Pro 24DSP could be responsible??
Any thoughts?
dickiefunk
Postby Hugh Robjohns » Wed Aug 22, 2018 8:49 pm
Regarding your bassist and drummer... Why compromise your everyday performance? Set the monitor gain structure correctly for your normal use, and then flick the sensitivity switches up a notch or two when your chums come over! :-)
As for the focusrite, if you are running the outputs with some digital attenuation you are compromising the signal-to-noise ratio of the output converters, and that could possibly be your source or audible noise....
I'm not clear from wha you've said whether the noise is coming from the sub, or from the interface and being made more audible when you turn the sub up.
If you hard bypass the sub, is the noise level the same?
Postby dickiefunk » Fri Aug 24, 2018 1:01 pm
Thanks Hugh. I've been busy trying your suggestions and have also been speaking to both Eve Audio and Focusrite tech support (who have both been extremely helpful :clap: ).
1/ When I bypass the sub and plug the Focusrite Saffire directly into the KH120's I'm getting roughly 50% more output with no increase in hiss. However, when I turn the Saffire's master volume up beyond 50% I get an increase in hiss (like when turning the System Volume up on the EVE TS108 sub beyond 50%).
2/ If I plug into the EVE TS108 before the KH120's and have both the Focusrite master volume set to 50% and System Volume of the EVE set at 50% I get no increase in hiss but the overall volume is 50% lower. However, now if I increase the Focusrite's master volume to 100% I'm not getting an increase in hiss this time and am getting the same output level as when plugging the Focusrite (master volume set at 50%) directly into the KH120's :thumbup:
There doesn't seem to be a fault just the gain staging has changed :?:
dickiefunk
Postby dickiefunk » Fri Aug 24, 2018 1:31 pm
I also bought SOS yesterday and read the Focal Shape Twin's review and it does look very good and was a very interesting read. However, I'm not sure it's really going to be much if any of an upgrade over my KH120/Eve TS108 setup?
Really I'd love something like the Unity Audio Super Rock's, Rock mkIIIDSP or Neumann KH310 but those cost more than my current monitoring setup!
dickiefunk
Postby Hugh Robjohns » Fri Aug 24, 2018 2:29 pm
dickiefunk wrote:When I bypass the sub and plug the Focusrite Saffire directly into the KH120's I'm getting roughly 50% more output with no increase in hiss.
This suggests that the sub is attenuating the signal (obviously) and is the main source of hiss...
If you raise the gain of the whole system you will be more aware of the quiescent background hiss -- what's important is the signal-to-noise ratio... and to ascertain that you need to work with a constant acoustic output level. The test you've described is not that helpful and quite misleading I fear.
As I said earlier, optimising the gain staging is key....
Postby morespinach » Sat Jun 27, 2020 11:43 pm
Heard Shape 65 today in the same setting as HEDD Type 07. No way are these in comparison. I’ve read professional reviews where these two and ELac Navis were compared and Focal 65 was given glowing scores. Can’t trust these pros then. The Focals have a drab, boring, basic monitor tonality. The 6.5” woofers are totally lost on me as there’s no bottom kick. The HEDDs on the other hand have a full bodied sound, and Elac of course is in the consumer space so has a more rich bodied general sound with great clarity and warmth. I’m surprised Focal has launched this stuff. Probably only for the studio wonks.
morespinach
Postby blinddrew » Sun Jun 28, 2020 10:15 am
morespinach wrote:The Focals have a drab, boring, basic monitor tonality.
Not sure I understand your point here. A good monitor should be flat and not impart any of its own sound. The purpose is to allow you to listen to the mix as accurately as possible, as opposed to a HiFi speaker, which is designed to flatter the source.
morespinach wrote:Probably only for the studio wonks.
Well, it is marketed as a studio monitor.
Postby Hugh Robjohns » Sun Jun 28, 2020 10:23 am
I believe the poster is a 'stereophile' and clearly has a hi-fi perspective on things.
Postby kjnilsson » Mon Jun 29, 2020 9:31 am
I have the focal shape twins and am really happy with them. Never tried the others so can't comment on sound quality but the focals seems really accurate to me. Certainly my mixes improved almost instantly when I got them.
Yes you have to be careful with the knobs at the back, that is a bit annoying but the standby feature isn't causing too much annoyance. It takes quite a while for them to enter standby and you can see it is enabled by the red light at the front. Useful for when I forget to turn them off etc.
kjnilsson
Postby kjnilsson » Mon Jun 29, 2020 9:34 am
I should really have checked the dates of the original post
kjnilsson
Postby Hugh Robjohns » Mon Jun 29, 2020 11:26 am
