Zoom H2N Pro - issues?
Postby JR » Wed Sep 19, 2018 1:31 am
Hello I have a newer Zoom H2N Pro
bought it back in August, i love the sound quality. I use it to record videos of myself.
So it is more less Dialogue specific
I use an external mic for it. LAV mic
i plug it direct in back.
Recently in my videos, It still does give me sound . However my sound recording is coming in very quiet. even the bars are quite small.
I use in WAV files.
I want to have top quality sound for Dialogue.
What would be the ideal settings to use?
As well what could be the issue of of level low. I have my MIC level at 100% but still very quiet.
What am i doing wrong? i even do a factory reset.
All the help on this.
Even give me specific settings for everything that give me top sound . that help me diagnose my problem thanks and look to your kind response
JR
Re: Zoom H2N Pro - issues?
Postby Sam Spoons » Wed Sep 19, 2018 9:54 am
Could it be a fault with the mic (make and model)?
Postby Hugh Robjohns » Wed Sep 19, 2018 10:50 am
Check the input mode is set correctly (external mic/line input rather than on-board stereo mics).
Check the recording level is set correctly and that the automatic gain mode is not engaged.
If the external mic has a battery, check that it is in good condition, or if you're using plug-in power from the recorder to power the mic make sure that is switched on.
Test the mic on a different system (eg the mic input of a laptop, for example...)
