Help! My new audio interface isn't picking up sig from mic!
Postby Gideon26 » Thu Nov 08, 2018 2:05 pm
I just received my first audio interface in the mail yesterday. It is the Behringer U-Phoria UMC404HD. I was going to hook up my mic (Excelvan BM-800) and do a quick test recording today, but when I had everything ready and plugged in I never got a signal from mic and wasn't recording anything. I am new to this sorta thing so I think it's a user error :tongue: and I must have done something wrong while setting up even tho I've tried to find the problem countless times. Is there certain steps I must take for it to work? Am I connecting things right? I am using Garageband on Mac OS (Mojave). I will try to give more detail but not sure what people need to know. I am 15 and just starting out, so I would greatly appreciate any help I can get.
Gideon26
Re: Help! My new audio interface isn't picking up sig from mic!
Postby Sam Spoons » Thu Nov 08, 2018 2:39 pm
Have you switched phantom power on? It's the switch marked +48V on the back. Can you play anything back through the interface? Can you play something from Garage Band through the interface (a virtual instrument maybe)?
edit :- welcome to the forum BTW :thumbup:
Postby Wonks » Thu Nov 08, 2018 2:51 pm
Hi and welcome to the forum.
Two main point to check:
1) The microphone requires 48v 'phantom power' to work. It is a capacitor mic, which has electronics inside to amplify the signal from the diaphragm. This is done by supplying 48v dc along two of the wires inside the XLR cable to the mic, with the 0v return connected to the cable screen.
(Dynamic mics don't need phantom power but have a lower output)
There is a switch on the back of the UMC to turn on the 48v dc power. This turns on the 48v phantom power to all 4 mic channels. Turn the input gain right down, connect up the mic, then turn on the phantom power, then turn up the mic gain. Turning on (and off) the 48v always gives a loud 'pop' so have the headphone and/or monitor sound turned down as well when you do this. Always best to have the 48v turned off when connecting or disconnecting mics. There is a small LED on the front of the UMC to indicate when the 48v power is on.
2) The mic is a 'side address' mic, that is, you speak/sing into the side, not the end, of the mic (as the Excelevan picturse imply). You also have to speak.sing into the correct side of the mic, and this is normally the side with the mic name on.
Postby ef37a » Thu Nov 08, 2018 2:58 pm
Sam Spoons wrote:Have you switched phantom power on? It's the switch marked +48V on the back. Can you play anything back through the interface? Can you play something from Garage Band through the interface (a virtual instrument maybe)?
Now, I say this with the greatest respect..You have bought an XLR to XLR microphone cable?
I ask because the BM-800 (had 2) does not come with one, it comes with an XLR to 3.5mm (1/8th inch) stereo jack plug. That will not work with the Behringer interface.
You should however be able to prove the mic out by using the supplied cable on the mac. I am sorry but I am not familiar with the mac's sound setup but many here will be.
Postby Wonks » Thu Nov 08, 2018 3:01 pm
Also, what cable are you using to connect the mic to the UMC? The mic seems to come with a (basically useless) XLR to TRS 3.5mm jack cable.
You'll need a male to female XLR cable to get the mic to work with the interface. Something similar to one of these: https://www.amazon.co.uk/C2G-Pro-Audio- ... LR+5m+-DMX
If you've tried using the supplied cable with a 3.5mm to 1/4" adapter (often supplied with headphones) plugged into a 'combi' input (combined XLR and jack socket), then it won't work because 48v power is only provided to the XLR connections in the connector. The jack is meant for instruments or line level inputs, and they really don't like being given 48v, so the connections for the jack input part don't have 48v on regardless of switch position.
Postby G-Doubleyou » Thu Nov 08, 2018 4:51 pm
Have you selected your interface in System Preferences/ Sound preference pane?
G-Doubleyou
G-Dub Studio G-fx 2011 15inch 2.0GHz quad-core i7 Macbook Pro, LPX 10.3.2
2.3 GHz quad-core i7 Mini
Postby Gideon26 » Thu Nov 08, 2018 11:29 pm
Yes. I had it on, but before I connected the mic.
I wasn't able to playback anything. I had my headphones plugged into the interface and could hear things from my computer but when I switched it to monitor sound from mic, it was just some static (not loud).
I don't have an instrument to play through it . I'm using it for recording audio dramas, doing voice overs, etc. So I only will be using mics.
Gideon26
Postby Gideon26 » Thu Nov 08, 2018 11:47 pm
Wonks wrote:Hi and welcome to the forum.
I had phantom power on, but I was very random in setting up my mic... meaning i had 48v on before connecting my mic, and the gain was probably up too :headbang:
My interface isn't even getting a signal from the mic, so whichever direction i speak into the mic, i will get nothing.
Gideon26
Postby Gideon26 » Thu Nov 08, 2018 11:53 pm
Yes. I have an XLR female to XLR male. (from my mic to the input on the interface.) I also have on on my mic boom arm (whatever you call it :P )
I used the mic (with a small power box that came with the set, I have the excelvan BM-800 kareoke set.) a week or two ago and it was fine, but it seems to have trouble with the UMC404.
Gideon26
Postby Gideon26 » Thu Nov 08, 2018 11:57 pm
Wonks wrote:Also, what cable are you using to connect the mic to the UMC? The mic seems to come with a (basically useless) XLR to TRS 3.5mm jack cable.
I'm using a male to female XLR cable. I didn't even think about connecting it with the TRS lol
Gideon26
Postby Gideon26 » Thu Nov 08, 2018 11:58 pm
G-Doubleyou wrote:Have you selected your interface in System Preferences/ Sound preference pane?
Yes. I've set it up on both input and output.
Gideon26
Postby Martin Walker » Fri Nov 09, 2018 12:13 am
Hi Gideon26, and welcome to the SOS Forums! 8-)
Your image above didn't originally make it successfully into the SOS Forums, because you inserted an imgur link between our two Img tags, so I edited your post for you so it appeared properly.
What you need to do in future is right-click on your desired image, choose the 'Copy image address' option, and then paste that between our two Img tags.
Postby Gideon26 » Fri Nov 09, 2018 12:44 am
Martin Walker wrote:Hi Gideon26, and welcome to the SOS Forums! 8-)
Oh ok will do. :thumbup:
Gideon26
Postby ef37a » Fri Nov 09, 2018 8:07 am
I cannot find any information on that kareoke set but I suspect it uses the computer's low voltage supply for the microphone, possibly via USB?
If that is the case that leaves three other possibilities. The UMC is not putting out 48V. Unlikely even for a Behringer! The XLR-XLR cable is faulty or the phantom power circuit in the mic is faulty and of the three I would say the last is the most likely.
The BM-800 and related mics ARE remarkable value and quite well made. My two also work well, not as sensitve as my Sontronics LDC but some 10dB hotter than an SM57. They also work ok on 48V or via a laptop jack (and I think are a better bet than many USB mics)
However, the forum pages were rife with other people having problems with the mics. Low levels, no level, noise. The QC it seems is not at all good and so it is very likely IMO that yours is faulty.
Do you own a digital multimeter? If not I strongly urge you to get one. Something around £20/$20 is easily good enough. Thus equipped you can test the cable for continuity and for the presence of 48V.
Or, the BM-800s are SO cheap you could just order another one (just the mic) and use that to test the system and proceed from the results obtained?
Postby blinddrew » Fri Nov 09, 2018 8:41 am
Do you have access to (via a friend or in an old box somewhere) another mic and cable you can use to test?
At the moment the problem could be in the mic, the cable, or the interface. The earlier you can shorten that list the quicker you solve your problem. :)
