Tape Splicing Block
Page 2 of 4
Re: Tape Splicing Block
PostPosted: Sat Nov 17, 2018 7:18 pm
by Folderol
ef37a wrote:Hacksaw a splicing block Hugh?
I think I would rather give a local engineer a decent drink and get it milled!
Indeed :o
My Bib one has only 60 and 90ish deg, and the slits are very fine - just enough for a razor blade. Rather than shaped edges to hold the tape it has two clips with cork pads.
Personally I preferred that, as an accidental {very slight} movement of tape or block doesn't move the tape just after you've cut it!
PostPosted: Sat Nov 17, 2018 7:34 pm
by Dan LB
Thanks for the info Hugh. Presumably 87 vs 90 really wouldn't be noticeable at 7.5ips on the 388. I'll make sure to look for block that has 60 and 87 or 90 degree slots.
It's been about 18 years or so since I've edited on tape and I’ve never edited multitrack.
PostPosted: Sat Nov 17, 2018 8:51 pm
by ef37a
Indeed :o
Yeah...LASERs mate!!
PostPosted: Sat Nov 17, 2018 10:22 pm
by James Perrett
Folderol wrote:My Bib one has only 60 and 90ish deg, and the slits are very fine - just enough for a razor blade. Rather than shaped edges to hold the tape it has two clips with cork pads.
That's why, as discussed earlier, the tape channel is slightly narrower and the bottom curved. This has the effect of holding the tape in place without needing the clips. I have a Bib splicing block as well as a standard one and I've always found the clips fiddly to use.
PostPosted: Sat Nov 17, 2018 10:27 pm
by James Perrett
Dan LB wrote:I will be using it to edit both stereo 2-track tapes recorded on a Revox A77 and 8-track 1/4” tapes recorded with a Tascam 388.
I've never found the need to edit multitrack tapes - if I need to use different sections of the multitrack I'd just record/mix the sections separately and splice the stereo master. Editing the narrow format multitrack would be more likely to cause discontinuities in the audio as the sections need to be lined up very precisely to keep the tracks continuous.
PostPosted: Sat Nov 17, 2018 10:29 pm
Dan LB wrote:Thanks for the info Hugh. Presumably 87 vs 90 really wouldn't be noticeable at 7.5ips on the 388. I'll make sure to look for block that has 60 and 87 or 90 degree slots.
The slight difference between the time each track passes the edit won't be noticeable, even with 8 tracks but with the 90 edit there may be a click as the edit passes the head. The 89º angle means the edit does not pass over the head in a single instant which usually is enough to avoid the click.
PostPosted: Sat Nov 17, 2018 10:52 pm
by Tim Gillett
Wondering why splice edit these days. Splice when it's needed of course, but why not use the DAW for any editing?
PostPosted: Sat Nov 17, 2018 11:13 pm
by Dan LB
Thanks James, I'd never thought of that! That makes alot of sense!!
PostPosted: Sat Nov 17, 2018 11:18 pm
by Dan LB
It's for a creative project I have in my head at the moment. It won't be the same for me if I do it in Pro Tools. It's also a bit of fun too really.
If it was a job i was doing for someone I'd most definitely do the edits in the box!
Dan
PostPosted: Sun Nov 18, 2018 2:06 am
by resistorman
Ah yes... undo was fragments of tape stuck on the control room window :lol: We did some astounding edits...
PostPosted: Sun Nov 18, 2018 10:31 am
by Brian M Rose
My first job was in a recording studio with old EMI recorders (as well as 16mm and 35mm optical)
And yes, it was all too easy to cut your fingers. The Studio Manager said that it didn't matter. As blood contained iron oxide it actually helped keep the edit quieter :lol:
PostPosted: Sun Nov 18, 2018 12:58 pm
by John Willett
Indeed :o
I always hated the Bib block as it did not hold the tape properly at the point you cut it and the tape sometimes curled up and you could not cut as accurately.
Personally I used to put two piesec of tape in the block - one on top of the other with both splicing pints on top of each other. The cut would then cut both sides of the cut identically and make for a much cleaner join.
With the EMIblock (and the like) the cuts were fine when new, but the slot tended to widen with use so each cut could be slightly different - which is why I liked to cut two at once so the join was perfect.
I remember seeing one block that had been screwed to the ytape recorder at LBC London that had actually been cut all the way through with use and the two halves would swivel separately - and more - the reporsers had actually cut a slot all the way through the recorder's top plate with use. :o
THough, personally, in the latter days, I moved over to the CAT tape splicer which was much better. :thumbup:
I still have it.
Canford Audio still sell single-sided razor blades and Chinagraph pencils - but nit the blocks, it seems.
PostPosted: Sun Nov 18, 2018 2:32 pm
by ManFromGlass
vague memory of being told that using a razor blade that had become magnetized could cause pops or clicks at the splice point. But then it was so long ago I could be making this up!
PostPosted: Sun Nov 18, 2018 2:35 pm
by Kwackman
ManFromGlass wrote:vague memory of being told that using a razor blade that had become magnetized could cause pops or clicks at the splice point. But then it was so long ago I could be making this up!
Nope, it was a real thing. I was that soldier more than few times!
PostPosted: Sun Nov 18, 2018 2:51 pm
by ef37a
Then they were cheapskates most grades of Stainless Steel are non-magnetic.
Re the cut tape "shifting"? I recall a splicer that had clamps lined with cork.
