recording a Brassband
• Page 1 of 2 • 1, 2
Goodmorning,
Someone aks me to record his brassband. they are playing music from Austria.
My idea is
drums is only a bassdrum, snare and cymbal
one mic for the bassdrum and 2 mics as overhead for the complet set
7 brass players on each side of the drums
2 mics on each side in ORTF
1 vocal
i do have a 8 canal focusrite interface.
Canal 1 Bassdrum
Canal 2 overhead drums left
Canal 3 overhead drums right
Canal 4 and 5 brass section left
Canal 6 and 7 brass section right
Canal 8 vocals
the question is what kind of mics for the brass section. small or Large diagram mics.
thanks for the help.
My idea is
1 vocal
Canal 1 Bassdrum
Canal 8 vocals
- Janneman
- Regular
Kind regards, Jan van Duren
Re: recording a Brassband
Morning Janneman, this thread might be useful if you've not read it already: https://www.soundonsound.com/forum/view ... 401#129780
Aural Reject is something of an expert in this field if he's still hanging around.
blinddrew - Jedi Poster
In theory if the band is well balanced and you’re recording in a reasonable room, you should be able to capture everything with a stereo pair plus one spot mic for the vocalist.
This technique can form the basis of your approach, but then give yourself a few options as well. For large ensembles I tend to use an ORTF pair plus an Omni A/B pair (at around 60cm) on one bar as my main array. This gives me options to balance a more direct (sometimes clinical) sound with more room (spacious) sound.
I’ll then think about where I need spots mics, either for balance/definition.
For the ORTF pair I’ll use either SDCs (MKH8040s) or MDCs (TLM193s) and for omnis MKH8020s.
Certainly the vocalist will need a spot mic, plus you may need something on any instrumental soloists. The drums may need one or two overheads and maybe something on bass drum depending on how balanced they are but you may not end up using them in the final mix.
Of paramount importance is the acoustics of the room.
Bob Bickerton - Frequent Poster (Level2)
http://www.bickerton.co.nz
I think Bob has nailed it.
You seem to be approaching this like a rock band and there's really no need. A stereo pair and a couple of spots for soloists is the way I'd go.
The Elf - Jedi Poster
I agree with Bob and Elf.
In fact I, also, like the ORTF + 60cm Omni pair approach.
Keep it simple - the band should be able to balance themselves and, in the right acoustic, you should end up with a great recording.
John Willett - Jedi Poster
Janneman wrote:My idea is...
Yes, that sounds an entirely reasonable approach to me. The other replies all make perfectly valid points if the band is well balanced internally, and keeping things simple is always a wise approach, but your approach is fairly simple and logical and should work well. It will also give you some useful options in the mix if necessary -- but you'll need to work hard with your mic placement and angling to minimise unwanted spill between sections and mics.
What we don't know, of course, is if you are recording a live public performance or a studio session -- and that would have a big impact on the best approach.
No hard and fast rules there. I've used both, and seen other engineers use both in different situations. Personally I tend to prefer small-diaphragm mics where possible, but sometimes the multi-pattern options on LDCs can be helpful. If spill is a problem, small-diaphragm mics will tend to give you cleaner results as their off-axis sound capture is less coloured than most large-diaphragm mics.
Hope that helps
Hugh Robjohns - Moderator
Thank you for a the replies. I missed that one whats allready on the site.
I was think about 2 mics in ORTF position aswell and 3 mics for the drums and ons for the female singer. Whats is the best distance from the stage and the height of placing the mics.
I own two Rode M3 mics. Will they do the trick?
different mics for the drums and female singer.
this will make it al lot easier to record.
The place is good, dry sound. and can close a hugh curtain to make the room smaller to give it better acoustics.
i've made a recording with a Tascam last Sunday. I was about 10 meter away from the band. In my ears it's not that bad at all. is it possible to post a fragment foor this group??
thank you all very much for the very quick replies.
- Janneman
- Regular
blinddrew wrote:Morning Janneman, this thread might be useful if you've not read it already: https://www.soundonsound.com/forum/view ... 401#129780
thank you very much
- Janneman
- Regular
Bob Bickerton wrote:In theory if the band is well balanced and you’re recording in a reasonable room, you should be able to capture everything with a stereo pair plus one spot mic for the vocalist.
thank you very much
- Janneman
- Regular
John Willett wrote:I agree with Bob and Elf.
thank you very much
- Janneman
- Regular
Hugh Robjohns wrote:Janneman wrote:My idea is...
What we don't know, of course, is if you are recording a live public performance or a studio session -- and that would have a big impact on the best approach.the question is what kind of mics for the brass section. small or Large diagram mics.
Hope that helps
thank you very much
- Janneman
- Regular
I'm quite a fan of the 4-mic Faulkner Array in these situations. See: .
Only other thing to add to the excellent advice already given is to give yourself plenty of headroom when recording/tracking
Mike Stranks - Jedi Poster
+99Hugh Robjohns wrote::D Really great to see you back posting with us Mike.
Sam Spoons - Jedi Poster
I've missed you Mike. Nice to hear from you again and hope you are well
Andy
Andy
zenguitar - Moderator
Yogi Berra
Yogi Berra
Yes, great to hear from you again Mike!
Will Rode m3 do the trick?
I will place the band in half a circle with the drums in the middle of the half a circle( on the outside) and the horns left and right.
- Janneman
- Regular
Janneman wrote:Will Rode m3 do the trick?
M3 is a good mic in its class, but it wouldn't be my first choice for a recording such as this. What other mics do you have, or could you borrow?
If you could afford them then the Rode M5s punch above their weight - I'm been quietly impressed with the bang-for-buck they offer. Of course, if you can splash some cash then there's a whole world of mics out there that would suit!
The Line Audio OM1 and CM3 are exceptional mics for the money - although you wouldn't really be advised to use the CM3 in ORTF as it's a 'wide' cardioid.
And another 'Welcome back' from me.
