Bulk Digitizing Old Cassettes
Page 1 of 2
PostPosted: Tue Dec 04, 2018 7:38 pm
by Mobileman
A dear friend gave me about 100 cassettes that she used to record her favorite college radio station show in the 80's. The show means a great deal to her and she would like to preserve them for her lifetime on CD's. The quality is horrible. I think they were recorded with a cheap boombox. They sound like they're coming from a speaker that's under several thick blankets. I know that they will never be pristine, and she doesn't expect that, but I can't give her a handful of cassettes that sound that bad.
The music is Quiet Storm type R&B of varying production quality. I need help badly for the following reason.
There are far too many tapes to try to isolate problems (Spectrograph) and one tape might have tow nights worth of programming and one show is better than the other.
I wonder if there is a plugin(s) or preset in Adobe Audition that I can set up once and then just play the tape and get a better listening quality (not pristine).
If so, what would be the settings and how do I set it up so that it is active at the input and I don't have to transfer it and then run it again in order to process it.
I hope this is clear and I hope someone can help. This dear friend just retired and spends much time alone at home while crazies run the streets. This is one instance where music means more to someone than it probably should, but then again what is music for?
Re: Bulk Digitizing Old Cassettes
PostPosted: Tue Dec 04, 2018 8:49 pm
by desmond
*Personally*, I would just record the cassettes to files, with no processing at all.
Applying bulk processing (once you decided on what processing to do) is so quick, easy, and reversible, so it doesn't make much sense to try to apply processing in real time as you're recording the files. (I"m not even sure Audition can apply plugins on it's input, anyway... but other software can, depending on your platform.)
You can always do a few test recordings and play with them to decide how you want to process the files, but in the meantime, your computer can be recording in the background.
I recorded probably 50+ old cassettes of mine - I just set up a cassette deck and an old computer, set the cassette deck to auto-reverse (so both sides would play) and just left the computer to record for how long the tape lasts. When I'd come back, I'd put the next tape in and kick it off again. Once I have the raw recordings, I could choose how to edit/split/process/re-output at will, without ever changing the raw recordings.
PostPosted: Tue Dec 04, 2018 8:51 pm
by James Perrett
The secret to good cassette transfers is to tweak the playback machine for each tape so that it matches the machine that recorded the tape. Clean heads that have been demagnetised are essential - that under the bedclothes sound could simply indicate that your tape head needs a clean. Cotton buds and pure isopropyl alcohol are the best way to clean tape heads but I'd suggest keeping the alcohol away from the pinch roller as it may damage some pinch rollers.
You also need to adjust the azimuth of the tape head to match the tape - I find that the best azimuth setting is different for almost every tape. I try listening in mono to check the azimuth. If the treble disappears in mono then adjust the azimuth screw until it returns to its maximum.
Once you've set up the playback deck properly you'll probably find that you need very little processing although a little Aural Exciter (or Stillwell's Exciter JS effect in Reaper) can help to focus the treble and sharpen things up. Unfortunately there's no quick solution if you want decent cassette transfers. You may end up with a favourite processing chain but each tape will require slightly different amounts of processing.
PostPosted: Tue Dec 04, 2018 10:36 pm
by Tim Gillett
If the recordings are in fact as muffled as you describe there's little to nothing can be done. We can boost the treble hugely but it will also hugely boost the background noise treble as well, making them uncomfortable to listen to. This is not necessarily easy, rewarding work even for those of us who do it as a paid job.
But I'd ask myself: " If these recordings were really as bad as they seem, would the person who made them have endured listening to hours upon hours of them played back?" In many cases live recordings were terrible from the moment they were made, but sometimes not. So called "direct" recordings off radio using even just a cheap boombox could sound quite reasonable, and not badly muffled.
Possibly they're better sounding than you have experienced and it's mainly a less than optimal playback that makes them sound as bad as they do. James has some good advice on playing back the recordings optimally, capturing all the information, which in the world of expert "audio restoration" is like the First Commandment.
All the best with it,
Tim.
PostPosted: Tue Dec 04, 2018 11:11 pm
by Mike Stranks
Welcome to the forum! :thumbup:
Bulk standard processing across the board is always going to be a compromise, but you may be able to achieve something...
Check-out Izotope RX Elements. There are some good tools in there which may help. The Denoiser has an 'adaptive' setting which means it can alter parameters dynamically (to an extent) to suit the material.
I'm not familiar with Audition, but many editors/processors have a batch processing facility into which you chain various processes.
So:
* Digitise all the recordings making the adjustments that James has suggested, but don't apply any processing during the transfer.
* Set up a batch process of all the digitised files and include dynamic processing as part of the batch process.
Of course, make your digital copies of high quality - eg WAV, 24-bit, 44.1KHz - and keep that quality up throughout all subsequent processing. If you have to convert to MP3 make that the very last thing you do.
PostPosted: Tue Dec 04, 2018 11:55 pm
by Wonks
It might be worth using a high pass filter during the basic digitisation process to cut out unwanted low frequency noise. You'd need to try it on some of the tapes to see when it starts affecting the actual music, but a 12/dB octave slope starting at 40Hz should be pretty safe and make life easier later on.
If it's recorded via a mic from a radio, then there's probably not a lot of musical info below at least 60Hz, maybe higher if it's from a really small speaker.
PostPosted: Wed Dec 05, 2018 12:29 am
What they said....... Make the source the best you can by setting the playback machine and record with no processing (except, maybe, some HPF to get rid of stuff that might mess with the preamp) into the computer then do all processing on a copy of the original file.
PostPosted: Wed Dec 05, 2018 7:49 am
by ef37a
What they ALL said plus don't forget to backup the raw recordings, maybe at the end of each session? You have hours of work ahead of you, be a shame to lose it.
You can get a portable 1TB USB 3.0 drive for around £50.00 (stick some in a "cloud" as well but I don't trust 'em!)
PostPosted: Thu Dec 06, 2018 11:01 am
by ken long
Mobileman wrote:The show means a great deal to her and she would like to preserve them for her lifetime on CD's.
Then she shouldn't be putting them on CDs.
James' advice is the best on here. The muffled sounds may be the oxide on the heads or it may be the head alignment is way off. Those are the two things you should focus on. Yes there are tools for post processing but they won't restore that which was never captured.
PostPosted: Thu Dec 06, 2018 11:20 am
by ef37a
Ooo! I think CD is going to last this lady out? She could also dump them as 320k MP3 on a DVD and a USB stick. Between them I would bet that data would be readble for at least another 50 years?
PostPosted: Thu Dec 06, 2018 3:14 pm
If she's a technophobe, make three copies of every CD and she should be fine for a very long time.
PostPosted: Thu Dec 06, 2018 4:12 pm
by ken long
ef37a wrote:
ken long wrote:Ooo! I think CD is going to last this lady out? She could also dump them as 320k MP3 on a DVD and a USB stick. Between them I would bet that data would be readble for at least another 50 years?
Maybe. But if she hasn't got a player to read them in 50 years, the recordings won't be easily accessible.
File based formats, properly backed up, is the way forward. Cloud storage is a doddle to use nowadays.
PostPosted: Thu Dec 06, 2018 4:14 pm
by ken long
Sam Spoons wrote:If she's a technophobe, make three copies of every CD and she should be fine for a very long time.
CD-Rs have a life expectancy of ten years.
PostPosted: Thu Dec 06, 2018 4:30 pm
Well I have plenty much older than that which still work fine. According to this page, once burned they should last much longer (potentially 50-100 years). https://searchstorage.techtarget.com/definition/CD-R-shelf-life
PostPosted: Thu Dec 06, 2018 4:34 pm
by James Perrett
ken long wrote:CD-Rs have a life expectancy of ten years.
My personal experience is that good (ie Taiyo Yuden) CD-R's last at least 19 years with little or no degradation. This won't be true of all types of CD-R though. Taiyo Yuden's quoted life expectancy for these discs was 80 years. Mitsui claimed over 100 years for their discs but I had one batch start to fail after only a year or two.
I'd agree that CD may not be the best destination nowadays though - there are plenty of devices that will play from a USB memory stick so this may be more convenient but I like to have everything backed up in at least 3 different places if possible.
