passive and active monitors with monitor controllers
Postby Michael Bailey » Thu Dec 06, 2018 4:57 pm
Simple question, considering adding a set of the new Auratone passive monitors (Nashville made brand new), with the Drawmer CPA50 power amp in addition to a set of Eris 8 inch active monitors. So, I would need a monitor controller for switching back and forth. I am considering the Drawmer CMC2 to control both monitor sets, however one set is passive with the amp, the other of course is powered monitors. Can I do this without a problem? Main thing I just want to verify with experienced people that this form of mixing powered and passive monitors will work, I suspect it will work, just want verification. The controller will be fed by the monitor outputs of a Scarlett 2i2 and the Scarlett is hooked into a wonderful new I mac pro.
Michael Bailey
Re: passive and active monitors with monitor controllers
Postby Hugh Robjohns » Thu Dec 06, 2018 5:59 pm
Michael Bailey wrote:I am considering the Drawmer CMC2 to control both monitor sets, however one set is passive with the amp, the other of course is powered monitors. Can I do this without a problem?
Yes. No problem at all.
You'll need to match the levels of the two speaker systems so that you can switch between them without level jumps, and to do that you set a suitable reference level on your active speakers using the gain controls on them, and then adjust the power amp's volume knobs for the passive speakers to match.
Postby Michael Bailey » Thu Dec 06, 2018 6:34 pm
Thank you!!!!
Michael Bailey
Postby Michael Bailey » Thu Dec 06, 2018 6:38 pm
Thanks for the tips just what I needed to know!
Michael Bailey
Users browsing this forum: djangodeadman, MattWeth, Sam Spoons
