Mac High Sierra and above avoidance tactics needed
Page 1 of 2
PostPosted: Wed Dec 26, 2018 5:53 am
by Howdy Doody Time
I have an old iMac (2011 2.5Ghz i5 which has been great but struggles a bit under load these days. I also have a 2015 2.9 Ghz Retina MBP but this is problematic lately due to (I think) High Sierra, but might have viruses. On the MBP I cannot seem to get MacKeeper to install - it just gets terminally stuck. Sophos will not get past the "Allow" button in security and it seems High Sierra will not allow these things to work - the "Advisory" doesn't work either.
I want to buy a new Mac but I do not want High Sierra or anything later - too much trouble. So many things are having problems with High Sierra. Can I get a new Mac and somehow port all my existing software from the old iMac over to it. Or should I cut my losses, ditch Mac, and do a complete re-start on a high end PC - and if so which PC would you recommend?
Many thanks and Happy New Year.
Re: Mac High Sierra and above avoidance tactics needed
PostPosted: Wed Dec 26, 2018 8:56 am
by ef37a
I know nothing of macs and keep ALL Apple ***p off my PCs but I want to follow this.
#That's me in the corner, losing my.......# !
PostPosted: Wed Dec 26, 2018 9:58 am
by Janneman
You dont need mackeeper. OSX is doing the most things without mackeeper. You better use gatekeeper from Apple self. Is standard in OSX. Search the net for it.
PostPosted: Fri Dec 28, 2018 9:41 pm
by John Willett
Mac Keeper is bloat wäre and, from what I have read, pretty evil.
On my new Mac I did everything as a fresh install - worked great.
On my old Mac, after I had copied over all files, I Blätter it completely and reset it as if it was a brand new machine and gave it to the wife.
PostPosted: Sun Dec 30, 2018 2:40 am
by Howdy Doody Time
Mackeeper is ditched - thanks. Sophos seems to have installed, but it's unusual, in that it has no front end except for something that lives at the top of the screen and has no option for "Scan Now" (I'm in the 30 day trial period by the way)
I'm no computer geek, I want to read the news, check facebook, run Nuendo 8 and Reason 10. That's it. But OSX seems to change faster and more frequently than vendors can keep up with. I lost my old MS Office on my Macbook Air (my only non musical Mac) by updating to Mojave and while I understand the need to go completely to 64 bit, it is unnerving to realise that you can suddenly be without your must-have studio apps.
Hence the request to understand whether it's possible to port everything including the OS and all settings, drivers etc over to a brand new machine.
I never really recovered from the loss of M-Audio Profire when Firewire got suddenly ditched, until RME Digiface USB appeared, and I don't want any more of that trauma. Luckily my Firewire stuff wasn't top end expensive - as it was for at least one other person on this
forum.
I'm currently looking at changing out, or having repaired a hefty power supply unit for a rack of Sony converters assembled in 1990, which drops the 5V supply but not the +15V or -15V supply when all 16 channels of converters are connected. This happened after a fishy smell from the unit became apparent.
I'm confident the PSU can be replaced or repaired, but the point is this kind of longevity from hardware boxes stuffed with capacitors, diodes, IC's, resistors, transistors and transformers solidly out performs that of OSX. It wouldn't be so worrying if the entire software setup could just be ported over to new hardware.
PostPosted: Mon Dec 31, 2018 2:58 pm
by John Willett
You can import everything from a previous Mac to a new one by using TimeMachine and everything is there on the new Mac.
However - when I bought my new MacBook Pro a few months ago, I found it better to do it all as a fresh install.
I copied all the files to a hard drive and copied them over and re-installed all the programs/apps.
This made for a much better machine as doing it from TimeMachine also brings over odd stuff that you may not want anymore.
PostPosted: Mon Dec 31, 2018 3:00 pm
by Wonks
John Willett wrote:You can import everything from a previous Mac to a new one by using TimeMachine and everything is there on the new Mac.
Except when it doesn't work and you waste hours trying to make it work. Speak to Matt Houghton who had a most painful experience recently!
PostPosted: Mon Dec 31, 2018 3:17 pm
by Watchmaker
DevOps has come to a dead-end, proving that the notion of endless progress is a myth. I plan to keep plugging away with my Yosemite build until I have no other option. After that I'll probably go live acoustic and be done with it.
fwiw, don't even think about migrating to WIN10 and above unless you really want to be disappointed. Having your OS be SAAS and provided by a company that is both poorly run and a quasi-intelligence agency has proven to be the bad idea everyone knew it was to begin with. The October update debacle wasn't a one off.
I think your plan to stick with what you have is solid. g'luck!
PostPosted: Mon Dec 31, 2018 4:23 pm
by Ariosto
I would second that as I tried Time machine and it was a hopeless nightmare. It doesn't work.
PostPosted: Wed Jan 02, 2019 8:26 pm
by G-Doubleyou
Ariosto wrote:I would second that as I tried Time machine and it was a hopeless nightmare. It doesn't work.
Use an app that makes a disc image, like Carbon Copy Cloner.
PostPosted: Thu Jan 03, 2019 12:51 am
by Mudbucker
Howdy Doody Time wrote:I want to buy a new Mac but I do not want High Sierra or anything later - . Can I get a new Mac and somehow port all my existing software from the old iMac over to it.
Macs cannot use an OS older than the one that Apple installed. So new Macs shipping with High Sierra or Mojave cannot use Sierra or older.
The rest of the software can be brought over.
PostPosted: Thu Jan 03, 2019 4:22 pm
I'm not sure that's quite true, AFAIK you can install an older OSX version but, probably, not one older than the first version a computer model shipped with, some models last for two or three OSX revisions and you should be able to install the earliest OSX on all those computers.
Obviously there are issues when the older OSX has no drivers for the newer hardware but that applies to Windows and Linux too.
PostPosted: Fri Jan 04, 2019 11:38 am
by Howdy Doody Time
Many thanks to everyone.
In the end I bought a second hand iMac with High Sierra already installed, but with a faster processor, and more memory. I was afraid that drivers would be an issue. Now to try to get everything across. I like the idea of a carbon copy app. I will check that out.
Thanks again!
PostPosted: Fri Jan 04, 2019 12:41 pm
by Kwackman
Congrats on the new computer.
I think this was discussed elsewhere, but it MIGHT be better to try doing fresh installs of programs rather than copying everything across? It means any old unused bits won't clog up your drive? YMMV.
Whatever you do, good luck with the new toy!
PostPosted: Fri Jan 04, 2019 3:54 pm
by John Willett
Kwackman wrote:Congrats on the new computer.
I agree - this is what I did when I got my new Mac. :thumbup:
It *does* work much better this way. Especially as any little (or large) bugs that may have crept in over time don't get copied over.
When I got my 2nd Mac I copied everything over via TimeMachine - it worked fine, but I did feel that some nasties had been copied over as well. When I got my 3rd Mac a few months ago, I did a complete fresh install and it works much better.
On the old Mac (Mac #2) I did a complete Blatt! (with help over the 'phone from Apple) and set it up as if it was a brand new computer and gave it to the wife to replace her ancient PC (which was taking 5 or 10 minutes to boot up).
