Tascam US 20x20 interface!!!
Page 1 of 1
PostPosted: Wed Jan 09, 2019 6:15 am
by pyaar
Hi
Wonder if anyone here owns this interface and tried to figure it out:
I have a Tascam US 20x20 interface, and I'd like to see how can I route the headphone jacks so I'd be able to send different mix setting to each jack. I could do these settings with older interfaces I had in the past, but here from some reason I can't find how to tweak it, I tried to find it in the user manual, no luck - any thoughts?
Thanks
Re: Tascam US 20x20 interface!!!
PostPosted: Wed Jan 09, 2019 2:05 pm
by ef37a
According to this, https://www.soundonsound.com/reviews/tascam-us20x20
You can't. There are ten line outputs so it might be possible to route different tracks to those then drive a headphone amp?
PostPosted: Wed Jan 09, 2019 8:52 pm
by Music Wolf
I have a 16x08, which doesn't see much use. On that model you have a single mix feeding both the line out and headphones.
To use the multiple line outs you basically have to configure the unit as a multi channel mic pre with each mic directly feeding a line out.
PostPosted: Wed Jan 09, 2019 9:36 pm
by blinddrew
Music Wolf wrote:I have a 16x08, which doesn't see much use. On that model you have a single mix feeding both the line out and headphones.
I've used my 16x08 with different mixes going to different pairs of line outs (configured in Reaper) but as Dave's mentioned above, I think the two headphone outs are both on the same feed.
PostPosted: Wed Jan 09, 2019 9:39 pm
by Music Wolf
Yes, you are correct. I was thinking about direct monitoring where you cannot do this :headbang:
PostPosted: Wed Jan 09, 2019 9:43 pm
by blinddrew
Yep, so it does rather depend on how the OP wants to use it.
PostPosted: Fri Jan 11, 2019 6:44 pm
by pyaar
blinddrew wrote:
Music Wolf wrote:I have a 16x08, which doesn't see much use. On that model you have a single mix feeding both the line out and headphones downloader.vip/rufus/ appsync.biz/123movies/ ovo.fyi/gomovies/
my issue has beens solved!!!
______________________________________________
PostPosted: Sat Jan 12, 2019 12:20 am
by ef37a
How?
And...WHO are you calling "Has beens"? !!
Dave
